Question about Staples TXC122ACC Cross-Cut Shredder; 12 Sheet
Txc122a power light is on but will not shred - Staples TXC122ACC Cross-Cut Shredder; 12 Sheet
How to restore shredding capacity?
Access the mechanism and spend some time picking out all the bits of paper jammed in it.
Aug 22, 2016 | Office Equipment & Supplies
My shredder won't shred
If the motor will not run, then probably there's paper clogged in the shredder. Turn over the shredder, after unplugging the power cord, and remove the papers.
If the motor will run but not shredding any paper, then the drive gear has broken teeth. This is not usually worth fixing.
Hope this helps.
Mar 27, 2015 | Shredder Office Equipment & Supplies
No power. worked perfectly last shred. Now no lights illuminate when switch is on,
Does the outlet it's pluged into have power? check with another appliance. If power could be a number of things, plug connection to cord, connection inside, switch. Did the shred actually finish or did it stall and still som inside?
Mar 17, 2015 | Office Equipment & Supplies
My Black & Decker Shredder #BD-61 all of a sudden does not work. I used it tonight, but the next time I tried it does not work. The lights come on in both positions, but
On some shredders when both the forward and reverse LEDs are on it can indicate either a jam or a full receiver bag/ container (the area that the shredded paper is fed into).
Try the following steps:
  1. ) unplug the power
  2. ) open up the shredder (see 1 on diagram)
  3. ) empty out all the shredded paper (see 2 on diagram)
  4. ) check that the shredding jaws (both the entrance and exit) are clear of any shredded material (see 3 on diagram)
  5. ) put everything back together
  6. ) plug power cord back in
  7. ) force the shredder into reverse (see 4 on diagram)
Hopefully you should hear your shredder motor running. If it is switch it to automatic and try shredding again
Jan 24, 2015 | Shredder Office Equipment & Supplies
Problem with txc122a
If you just bought it yesterday, take it back to where you got it from and see if they will honor the warranty.
Nov 19, 2013 | Office Equipment & Supplies
Anti jam light is on unit will not run
The "anti-jam" light actually is a jam light and it is notifying you that the shredder is jammed. If you turn off the power and examine the shredding unit you will find shreds of paper stuck in the mechanism. Removing all of the shreds will get your shredder back in operation and the anti-jam/jam indicator will be off
Apr 15, 2013 | Office Equipment & Supplies
Parts manual for SPL-TXC122A
I need a plastic gear for the Staples SPL-TXC122A Does anyone have one?
Apr 06, 2013 | Staples TXC122ACC Cross-Cut Shredder; 12...
Spl-txc122a
The motor runs reverse even when in Auto mode, how do I fix it, and why did it happen
Mar 27, 2013 | Staples SPL1506X (CrossCut) Shredder
Shredder
your best bet will be to call Fellowes at 1-800-945-4545 we will be more than happy to assist you.
Mar 30, 2008 | Office Equipment & Supplies
Ford mondeo td
Your Power steering pump may be loose. This may be reason for the belt shredding and will make the new belt shred too pretty soon.
Nov 24, 2007 | Car Audio & Video
Staples TXC122ACC Cross-Cut Shredder; 12 Sheet Logo
Top Staples Office Equipment & Supplies Experts
 Bob Buchholz
Bob Buchholz
ray gallant
Are you a Staples Office Equipment and Supply Expert? Answer questions, earn points and help others
