Question about Michael Kors MK5060 Watch
Unable to snap back on watching after replacing battery
Bangle
What is the correct battery for replacement?
you need to take a pocketknife and look for a lifting spot around the outside edge of watch and carefully pry the back up. Most likely it is a 377 or 364, but you will not know until you look.
Aug 29, 2011 | Anne Klein AK Gold Tone Bangle Watch...
The strap is buckled at one of the hinges on the stainless steel bangle this has happened before and the jeweller fixed it within minutes. does anybody know the technique of how to fix it? thanks mandy
mcdevito75 here, Hi Mandy, a special Spring bar remover / installer tool is needed then the spring bar itself, the spring bar holds the band onto the watch, best bet, return to the jeweler for repair.
Oct 16, 2010 | Gucci 112 Twirl Small Mother Of Pearl Dial...
Stem and crown have come out of my gucci watch how do i replace it?
If your Gucci watch is Quartz, or even Windup, it"s best to see a jeweler to identify any possible problem causeing the stem and crown to come out of the watch. Mike D 75
Jun 08, 2010 | Gucci 1400 Series Bangle Stainless Steel...
Hi My daughter has a silicone bangle watch which has been fiddled with and has lost the time. We can only see the word 'sports' along with a 60 second timer in the display window. Do you have instructions...
I couldn't find any guide to the watch but perhaps you could try the following:-
Apply pressure to the edges at the top and bottom of the watch (looking for hidden buttons).
Is it possible to pop the mechanism out of the bangle, if so the setting buttons may be on the reverse.
Mar 05, 2010 | Watches
What do you use to snap on the back plate of a wristwatch
Tools are available from many watch suppliers, one is Jules Borel, jborel.com, best to get a new gasket and mabey a spare if you wear this in the water then a new crown or crown seal also.
Jun 11, 2009 | Casio Sea-Pathfinder SPF40-1V Wrist Watch
Replaced battery in my Burberry watch, back cover won't snap on
I have the same problem. Did you guys find how to do it? Please let me know. M
Mar 26, 2009 | Timex 27191 Wristwatch
How do I open my gucci watch to change batteries?
Get a #0 1.6mm precision Phillps screwdriver (these are brittle) or similarly strong, thin piece of steel.
Hold the watch upside-down across your index finger while gripping the straps tightly between your index finger and thumb on one side, and index finger and middle finger on the other (ie. squeeze the strap around your index finger).
On the underside of the watch, stick the tip of the screwdriver under a square slot where the watchband is connected at an angle perpendicular to the strap. Firmly pry upwards on the cover on one side, then the other, until the cover pops off.
The battery is a Renata 379.
To put the cover back on, align the square slots precisely with the ends of the straps (keep these out straight), then firmly push the cover straight down until it "snaps" shut.
Dec 31, 2007 | Watches
Michael Kors MK5060 Watch Logo
24 people viewed this question
Top Michael Kors Watches Experts
Ansel Alberto
Ansel Alberto
ray gallant
Are you a Michael Kors Watch Expert? Answer questions, earn points and help others
