Question about LG LRSC26980 25.2 cu.ft. TV Refrigerator with FM Stereo: Titanium
Manual refrigerator demo 0n unable to shut off
My samsung control on the freezer is displaying OF OFseems ice maker is off I pushed the power freeze by accident and can't get back to regular display
0F 0F on a Samsung refrigerator display indicates that your unit is in DEMO Mode. In DEMO mode, the lights work, but the refrigerator/freezer, fans, etc. will not operate (this mode is for display/retail purposes in appliance stores). Unfortunately, Samsung does not include any info re: DEMO mode in their user manuals.
To exit DEMO mode and return to operating mode, you will need to push 2 display buttons simultaneously for ~ 3 seconds (you'll hear a small chime, then the display window will display the freezer/fridge temps and will then be out of the 0F 0F DEMO mode). The 2 display buttons that you have to press simultaneously will depend on the model of Samsung refrigerator that you have.
I have a Samsung RF18HFENBSR model (french door, bottom freezer, display at top center of fridge compartment). For this model, you press the Power Freeze & Freezer buttons at the same time to enter/exit DEMO mode).
You might try googling Samsung XXXXXXXXXX Demo Mode, where XXXXXXXXX is your model number, and you may find the display button combo for your model. If not, then you can probably get the combination from Samsung support to return your unit to normal operating mode. Your appliance store may also have that information.
Sep 10, 2017 | Samsung Refrigerators
It won't turn off even though the programme has been set too
Timer doesn't turn lights on?! - 420 Magazine
www.420magazine.com > ... > Growers Forums > Grow Lighting
May 26, 2013 - 9 posts - ‎3 authors
Hey so I've always turnd my lights on/off manually, but now me and my gf ... Ya, I had it working with a stereo and a heater, but it won't turn my ...
Timer won't turn off using OK button. ' Apple Support Communities
discussions.apple.com > Support > Apple Support Communities
AppleApr 6, 2014 - 0n my iphone 4 when timer is finished counting down, unable turn offusing 'ok' button. Have to use on/off switch (top right) to silence.
How To Fix Dryer That Won't Shut Off ' Dryer Repair
Jan 08, 2016 | Hardware & Accessories
Display shows OF and OF
Your refrigerator is in Demo mode, which also shuts off your compressor.
To get out of demo mode, most of the older Samsungs are programmed so that if you press and hold the top left button and the one directly below it (for about 5 seconds or so until you hear a ding), the unit toggles out of demo mode.
Aug 14, 2015 | Samsung RF4287HA
Where is the on-off power switch to the ice maker 0n the elite kenmore bottom freezer refrigerator?
On the side of the icemaker, there is a thick stainless steel wire or "bale" that is pushed up by the ice so the bucket doesn't overfill. Gently raise this wire while grasping the bottom of it and lift up until the wire stays in the upright position. This shuts the icemaker off.
Feb 05, 2015 | Kenmore Refrigerators
How do you stop demo mode on lexibook junior tablet? just bought it for xmas and wont let us do anything but keeps playing demo video over and over
Your tablet is stuck in demo mode, to reset the demo mode shut off the tablet, keep pressed at the same time power+volume up buttons, the tablet will boot in recovery move, the last selection of the menu is the demo mode feature 0n/off
Dec 29, 2014 | Tablets & eReaders
How do I turn off demo mode on my frigidaire refrigerator model# FRT18B5JW?
Hello friend, thank you for your inquiry!
I understand that your Frigidaire refrigerator has been plugged in for 24 hours and is still not cooling. I would recommend you adjust the setting to a colder setting to see if that would jump start the compressor. I have reviewed your appliance and I was unable to locate a demo mode for your appliance. You can also attempt to perform a reset which is unplugging the appliance for roughly ten minutes and then plugging it in. I hope this is helpful. -Matt
Sep 13, 2014 | Frigidaire Refrigerators
Taking samsung out of demo mode
The manual doesnt mention nothing about "demo mode", therefore try just to pull the power (turn off) wait 5 minutes and then turn it on again.
Jun 20, 2014 | Samsung RF4287HARS French Door...
RT50 control panel not responding
It still sounds like the child lock is on since that prevents accidental setting changes on the refrigerator's control panel.The following will NOT work if the child lock function is activated: Freezer Temp Button Fridge Temp Button Power Freeze Button Power Cool Button Ice Type Button Water Button Ice maker Water OR it may be in Cooling Off/Demo Mode. Cooling Off/Demo Mode is a feature used by retailers to display the refrigerator without running the compressor. If your unit is not cooling, and the bars are constantly scrolling up and down the temperature, check your manual for reset advice
Mar 31, 2014 | Samsung Refrigerators
Ice maker stopped making ice water leaks from the device used for getting ice cubes
you need to replace the water valve (usually Blue) 0n the back of the unit as its stuck in the open position shut the water inlet before you disconnect anything.
Jun 16, 2011 | Whirlpool Refrigerators
Hi - I just moved and when I hooked up my 2003 Panasonic SC-AK100, it stays in 'demo' mode and won't shut off completely...after showing "goodbye" and apparently shutting off, it comes back on...
http://www.retrevo.com/support/Panasonic-SC-AK100-manual/id/356ag917/t/2/
Page 12:
A demonstration of the display is shown if you have not set the clock.
You can reduce the power consumed in standby mode by turning it
off.
During standby mode
Hold down ['square icon'/-DEMO] until "NO DEMO" is displayed.
Every time you hold down the button:
NO DEMO (off)↔DEMO ON (on)
To show a demonstration of the display
Hold down ['square icon'/-DEMO] until "DEMO ON" is displayed.
Jan 16, 2011 | Panasonic SC-AK100 CD Shelf System
Refrigerators Logo
14 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
