Question about Konica Minolta bizhub 350 All-In-One Laser Printer
Error code C-3851 - Konica Minolta bizhub 350 All-In-One Laser Printer
  • Konica Minolta Master
  • 6,680 Answers
Sir/Mam,
On the right side of the machine just below the scanner section (The part with the big glass) is a cover next to where you connect the Ethernet cable. Remove the cover, with the machine on use a small screw driver and gently depress the small black switch. The machine is going to go thru some screens when you see the screen with the copiers on it to the left on the screen in the middle you will see a "." when that is displayed press 3. The code will come back but now press the Utility/Counter button, you should see a button that says Maintenance Mode press that, see Trouble Reset press that and the machine will again will go thru warm up procedure, you will see the "." DO Nothing! The machine should go to "Ready to Copy" if the code comes back. Have a technician look at it DO NOT CONTINUE TO RESET the code is for the Hot Part called the FUSER. It can catch on fire! And that will ruin a perfectly good day!!!!
Posted on Jan 24, 2016
Error code 3851
http://www.fixya.com/support/t24839625-error_code_5351
Jan 30, 2015 | Konica Minolta bizhub C250 All-In-One...
Wiring diagram 8330-3851
If you Google airxcel.com, you should get some options. to get either their literature or tech support and they should be able to help you.
Jan 23, 2013 | Coleman Shroud Rv Rooftop Rvp Mach 3 Air...
Heng Long,Model 3851-2
Really do you think that this is one answer?
Really are you an Expert? All users deserve respect, do not need their taunts.
Aug 06, 2012 | HL 1/10 4wd Electric Speedy Mad Truck...
Security code locked
codigo de desbloqueo radio a 3851 audiobahn
Oct 11, 2011 | AudioBahn A3851 Car DVD Player
I want the instruction manual for an ACER Iconia Tab A500.
Please follow the link given below you will find the manual page http://support.acer.com/us/en/product/default.aspx?tab=1&modelId=3851
Jul 17, 2011 | Computers & Internet
C 3821
Hi geosegr,
Can you confirm the code is C-3821.
Because it's not one that I recognise.
There are only two C-38xx codes, they are C-3851 and C-3852.
Both of these codes relate to the fusing section.
If it were me, I'd have a look in the fuser area to make sure there is no paper stuck. Then you'll need to reset the code. To do this,
Turn OFF the Main Power Switch.
Turn Main Power Switch ON while pressing the Utility/Counter key.
Touch [Trouble Reset].
Check to make sure that [OK] is displayed and the it has been reset.
After turning off the Main Power Switch, turn it on again more than 10 seconds after and check if the machine starts correctly.
If the fault code reappears, you'll need to get an engineer to look at it.
Hope this helps
Jan 28, 2010 | Konica Minolta bizhub C250 All-In-One...
My printer is showing a code c-38-51 and will not work
Hi, C-3851 is related to the fusing unit. Specifically, the lower roller is at an abnormally low temperature. Unfortunately you cannot reset the code in a normal manner. Konica Minolta, for health and safety reasons, make fuser related codes engineer resetable only.
I'd rather not post the procedure here, so drop me a private email and I will advise on the procedure.
Regards
Tam
Mar 20, 2009 | Konica Minolta bizhub 250 All-In-One Laser...
BizHubC253 error code c3821
This error also occurs after a paper jam or a steep power change. If error continues after doors were properly closed and the printer was turned off and on again, it'd be necessary to reset the printer and release it from trouble status.
Turn off the main switch (1/0 botton) but keep the control panel on. Wait 10 seconds. Press and hold Utility Counter botton on the Control Panel while turning on the main switch. Hold it until a white screen with a black dot over the upper rigth corner appears, then release it. Wait for a "trouble reset" botton on the control panel and then manually click on it. You'll see an arrow pointing to an "OK". Now turn off again the main switch, wait 10 seconds, and turn it on. Error must be gone.
May 03, 2008 | Konica Minolta bizhub C250 All-In-One...
Malfunction Detected C-3851
C3851: Abnormal Low Temp. (Heater)
Restart, holding utility key down and do troble reset, if everything is ok, the machine will work again, if not, call for service
Dec 18, 2007 | Konica Minolta bizhub C250 All-In-One...
Konica Milota Bizhub C250 Error Message
First power off the printer completely. Then power it back on while holding the UTILITY/COUNTER button. You will see the minolta logo, then you will see a troubleshoot reset button. Press it, you will see an OK result. Power off the printer again, then power it back on without holding the button and everything should work.
Aug 13, 2007 | Konica Minolta bizhub 250 All-In-One Laser...
Konica Minolta bizhub 350 All-In-One Laser Printer Logo
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
