Question about Stihl HT101 Pole pruner
Change gas filter in tank - Stihl HT101 Pole pruner
  • Stihl Master
  • 1,807 Answers
Hook out the fuel line and filter with a hooked rod, pull off the filter and push new one onto the pipe
Posted on Mar 07, 2015
2006 dodge stratus looses power after running for a while
either your fuel filter or fuel pump is clogged from all the debris from the gas tank , you are going to have to change out the filter or empty your gas tank and pull your fuel pump out and change your filter on your pump out.
Dec 06, 2012 | 2006 Dodge Stratus Sedan
1996 f250 with 5.8 eng when i change over to front tank it pops jerks and stalls
Sounds like old gas, or water in this front tank, could also be fuel filter if each tank has seperate filter. If gas is old remove if not old check/replace filter.
Jul 01, 2012 | Cars & Trucks
Where is the gas filter
The gas filter is inside the gas tank. If you're wanting to change the filter, first remove all gas from the tank.
Next, remove cover and probably the air filter so you can see the fuel lines.
Use a needle nose pliers to grab the filter through the tank opening.
Some chain saws have 2 lines coming from the tank. Give a little tug on the gas filter to see which line it is attached to inside.
You will have to remove the line at the other end where it attaches to the pump or crankcase.
Pull the filter and line up and out of the tank. Put on a new filter and pull the line back to the nipple it was attached to.
Push down on the filter to seat it in the opening.
Depending on the make and model of your chainsaw, some have washers under the filter that seat against the inside of the fuel tank. Be sure to press this kind to seat it.
Hope this helps. If it does. I'd appreciate a 4 thumbs up. Thanks,
Handie Andie
May 12, 2011 | Garden
Mazda mpv1994//where is the gas filter located? is it hard to change out?
the gas filter is located on the gas tank its not that hard to change but can take awhile to do only cos u have to take the tank off
Apr 18, 2011 | 1994 Mazda MPV
Change fuel filter in a 2006 Chevrolet Uplander
prev.gif next.gif Fuel Filter The fuel filter is part of the fuel tank module. (in the fuel tank)
It's kind of difficult to drop a fuel tank and replace the fuel tank module due to the weight and danger of gasoline catching fire or exploding.
Jul 19, 2010 | 2006 Chevrolet Uplander
Where is the fuel filter on a 97 breeze
FUEL FILTER IS LOCATED ALONG THE BACKSIDE OF THE FUEL TANK UP NEAR WHERE THE LEFT TANK STRAP BOLTS TO THE BODY/FRAME..YOU HAVE TO DROP FUEL TANK DOWN TO REPLACE FILTER..A LITTLE TRICKY TO GET AT..RECOMMEND A REPAIR SHOP IF YOU ARE NOT EQUIPPED TO DO THIS
Jul 04, 2009 | 1997 Plymouth Breeze
I empty gas tank and put new gas. could it be something is clogged?
It is a myth that sugar will mess your car up. Sugar does not dissolve in gas, it will just sit in the bottom of the gas tank. You will need to drop the tank and have it cleaned, and replace the in-tank fuel filter, but anything upstream of the fuel filter will be okay.
May 28, 2009 | 1999 Mazda Protege
Fuel pump fuse
replace fuel pump /fuel filter/screen/keep enough gas in tank at least 1/2 tank of gas at all times and change gas filter at 10,000 miles
Mar 24, 2009 | 1999 Chevrolet Silverado 1500
Changing a fuel filter and fuel pump on 1994 Beretta
The fuel pump is inside the gas tank. The filter is next to the tank in-line of the fuel hose.
Feb 15, 2009 | 1994 Chevrolet Beretta
Stihl HT101 Pole pruner Logo
118 people viewed this question
Top Stihl Garden Experts
Joseph Mueller
Joseph Mueller
brotherscott
Level 1 Expert
ray gallant
Are you a Stihl Garden Expert? Answer questions, earn points and help others
