Question about Metrologic Instruments Computers & Internet
Barcode scanner stopped working
My barcode scanner stopped working. I get a message," Device has malfunctioned and windows will not recognize it." After I unplug and replug in the scanner, the light on top blinks green once and it beeps once, but there is still no laser light and the message keeps repeating itself.
SOURCE: ms9520 buzzez and then will not scan
The Razzberry Tone is what I'm hearing. Acording to the trouble shooting I should return the unit for repair. Thanks for you help!
Posted on Jun 07, 2007
SOURCE: Metrologic Keyboard Wedge Barcode Scanner (MS5145)
I found a solution. The scanners needed to be reset to default. (via the manual) Thx anyway. Didn't know they could be configured for use without a kboard... That definately bit me once.
Posted on Aug 23, 2007
  • 25 Answers
SOURCE: Barcode scanner scans and beeps, but will not put the numbers in the computer
There is more than one way for that imager to send data to the computer. Are you using USB, serial, or is there a little box that goes between your existing keyboard and the PC that accepts the scanner connector?
Posted on Jan 05, 2008
thesuperdude
  • 97 Answers
SOURCE: scanner beeps but doesn't enter data into system
Have you scanned the configuration barcodes on the manual? For example if you are using keyboard wedge cable, you will need to scan the keyboard wedge barcode from the manual. Page 20.
http://www.handheld.com/download.aspx?download=/data/ffdefe60-2c7a-423f-a204-ee2450b7c4d9.pdf&filename=IT3800PDF+Linear+Imager+PDF
Posted on Apr 02, 2009
  • 74 Answers
SOURCE: 4 beep error when scanning barcode
The four beep error is a communications error. Usually it indicates the scanne is not configured properly. If the scanner is connecting with the CBA-K01-S07PAR cable and you are using a PS/2 keyboard you should have scanned the IBM PC/AT barcode from Adobe page 56 of 342 of the LS2208 Product Reference Guide.
If you do not have a PS/2 keyboard attached and are using a USB to PS/2 adapter you should scan the IBM AT Notebook from that same page. If the scanner does not start working immediately you may have to reboot your system. If the scanner still does not work the CBA-U01-S07ZAR USB cable might be a better choice.
If you are not connecting with either of these cables and are still getting the four beep error a call to the Motorola support center may be in order. Their phone number is 800-653-5350.
Posted on Oct 23, 2009
Usb port open error
Does it work on other POS machine? That is to verify any hardware issue with the scanner. If it works, does other scanner works on this POS machine? Sometimes unplug and replug some USB cable in or some of the cable in between the POS and scanner will make it work. If those do not work, try to check the server for POS connection and see whether they can see that POS system. Use your store control application to reset that POS machine before you refresh the software or operating system on that.
Sep 11, 2012 | Datalogic Magellan 1100i Barcode Scanner...
Got a Sumvision External 2.5 Hard drive for over a year now and today i pluged it in as normal and got the following error messages - using windows 7 also tried it in XP and it doesnt recongise the hard...
Hook up that external hard drive to another computer that you know for sure the USB ports work properly. If you still get the same error message or the drive is not recognized then that means the hard drive is bad.
If the hard drive is recognized properly and you can access the files then that means its an issue with the operating system.
May 14, 2011 | Computers & Internet
Cab't get computer/application to recognize the scanner
This is an older model handheld that utilizes either and RS-232 cable or Symbol Synapse cable to link to a PC. If the model you are using is cordless, then there should be a dock that is used to connect to your PC.
Most computer peripherals using RS-232 connections require a driver install to the PC in order to recognize the input from the device. Upon successful connection of the handheld or dock to the PC with driver installed, the unit should work as long as there is no physical malfunction to the unit.
The driver utility support the p470 models can be found here:
http://support.symbol.com/support/search.do?cmd=displayKC&docType=kc&externalId=11585&sliceId=&dialogID=227820981&stateId=1%200%20227814895
This unit is only supported by Windows 2000 or Windows XP environments.
Regards,
Dan
IT Professional
May 04, 2011 | Symbol P470-SR1211100FB Handheld
How do i re install my web cam
HELLO SIR JUST CLICK THE "START" BUTTON AND GO TO "CONTROL PANEL" ON THE LEFT SIDE OF THE WINDOW , AND ON THERE CLICK "add or remove programs" AND A NEW WINDOW WILL BE OPEN.AND WAIT FOR FEW SECOND TILL IT LOADS. SEARCH FOR YOUR WEB CAM DRIVER OR MANUFACTURER NAME ADN CLICK ON "CHANGE OR REMOVE" OPTION ON THE LEFT CORNER OF THE SELECTED TAB .JUST FOLLOW THE STEPS AND UNISNSTALL IT AFTER UNINSTALING JUST RESTART YOUR SYSTEM( THIS IMPROVES CRASHES BEFORE INSTALING THE NEW DRIVER) , AND WHEN THE SYSTEM RESTARTED UNPLUG THE DEVICE FROM THE USB SLOT AND WAIT FOR 2 SECONDS, THEN REPLUG THE DEVICE , U WILL SEE A BALLON TIP IN THE LEFT CORNER OF YOUR WINDOWS TASKBAR " new device found" IT WILL ASK TO INSTALL THE NEW DRIVER INTO YOUR PC , COMPLETE THE PROCESS AND REPLUG THE DEVICE RESTART THE WHOLE SYSTEM AND NOW YOU ARE READY TO USE THE DEVICE.
REGARDS
Jan 25, 2011 | Computers & Internet
When i connect my pen drive to the pc,it says "USB Device Not Recognized. One of the USB devices attached to this computer has malfunctioned and Windows does not recognize it"
please you can try a diferent usb port.
if that dont work, then shut down and resart your system with device plugged in.
if it still don't work, reinstall driver if device isn't plug and play
Jan 09, 2011 | Computers & Internet
I dint get connection with my pc. to my USB.. it is not recognizing
Does some other USB device work properly when connected to the USB port that you are trying to use with your Transcend Barcode Scanner?
Did you try to connect the Transcend Barcode Scanner to some other computer? If so, did the other computer recognize it?
If the Transcend Barcode Scanner is "brand-new", did the packaging for it come with a CD-ROM that you need to use -before- trying to connect the Transcend Barcode Scanner to your computer?
Aug 19, 2010 | Computers & Internet
Can't figure out scanner
with most barcode readers you need to configure it before you can use it, this is usually done via a barcode book whiich configures everything that the gun can do....everything from how it communicates with the pc, to the types of barcodes it can scan
Jul 01, 2008 | CIPHERLAB Computers & Internet
Locked Metrologic MS9520-37 (keyboard wedge) after unintentional programming
You programmed it for usb interface, but the scanner is keyboard wedge. Try pointing the scanner at the "recall defaults" barcode in the manual as you plug the scanner back in.
Feb 12, 2008 | Metrologic Instruments Voyager MS9520...
Computers & Internet Logo
51 people viewed this question
Top Metrologic Instruments Computers & Internet Experts
Gareth Cockram
Gareth Cockram
xak_tay98
Level 1 Expert
Daniel Dollive
Daniel Dollive
Are you a Metrologic Instruments Computer and Internet Expert? Answer questions, earn points and help others
