Question about Fahrenheat Electric Convector Baseboard Heater, 240 Volt
Electric baseboard heater noise
The heater is noisy digital Honeywell thermostat
hotuna
  • 288 Answers
SOURCE: Electric baseboard heater
You need a meter, it will be hard without this! If you have 220v in the wall, then think of it like this; each wire is 120v. Test to each other, you get 220v. The thermostat is a double pole, you said. So think of it like this, its an adjustable temperature controlled switch that lets electricity through at the temp. you set it at. If you have 120v from one wire connected to one end of the element, and the other 120v connected to the other end of the element, then it will work. DO NOT CONNECT THE 120V TOGETHER. IT MUST GO THROUGH THE ELEMENT FIRST. The thermostat should be between the power from the wall and the element, to control the temperature.
Posted on Jan 09, 2008
galaxian
  • 14 Answers
SOURCE: thermostat for baseboard heaters in series
The heaters need to be wired in parallel so they all receive the same voltage. If wired in series the first heater will receive proper voltage and the next heater will receive reduced voltage (Voltage Drop across first heater) and so on (Ohm's Law). You may want to have an electrician help you so you don't get electrocuted or burn up your heaters or your house. Hope this helps!
Posted on Dec 10, 2008
muttandjeff
  • 359 Answers
SOURCE: BASEBOARD HEATER NOISE
HOW ABOUT THE MARTIN HEATERS I LIKE THEM BUT DONT USE THEM THAT HIGH
Posted on Dec 23, 2008
advacak
  • 125 Answers
SOURCE: electric baseboard heater hums while running
is a 60 cycle hum, resonating with the power. check screws that mount it nothing to really worry about
Posted on Dec 31, 2008
  • 92 Answers
SOURCE: dimplex baseboard heater wiring
no does not matter but you must have a ground leg
Posted on Feb 24, 2009
How to set heat for baseboard heat
They use a 120v thermostat you should be able to buy one wherever you bought the baseboard heaters. Be aware those heaters costs a lot of money to run and dry out your house like a desert buy a few room humidifiers when you get the thermostat. Make sure you use the correct size wiring to the baseboard heaters and the Tstat if you undersize the wires for the breakers involved you'll more than likely cause a electrical fire.
Oct 01, 2014 | Honeywell Heating & Cooling
Need a thermostat for model no hz-514
How about a free replacement heater?
There has been a recall since 2002 on some Honeywell portable baseboard heaters. Check this link, or call Honeywell ASAP. The ON/OFF switch failed (with a burning plastic odor) on my HZ-514.
http://www.cpsc.gov/en/Recalls/2002/CPSC-Honeywell-Consumer-Products-Announce-Recall-of-Moveable-Baseboard-Heaters/
"Consumers should stop using these heaters immediately, unplug them, and contact HCP at (800) 290-8495 between 8 a.m. and 10 p.m. ET Monday through Sunday or log on to the company's website at www.honeywell.com to determine whether their heater is part of the recall."
I hope this is a solution for you, and you are safely warm again in the near future. need-thermostat-model-no-hz-514-gwybjxudtwjfkyidrgix5fxs-4-0.jpg CPSC Honeywell Consumer Products Announce Recall of Moveable Baseboard...
Feb 03, 2013 | Honeywell HZ514 Baseboard Heater
MY APARTMENT HAS ELECTRIC WATER BASEBOARD HEATING SYSTEM, I found out the heat cannot be turned off even I disconnect the honeywell thermostats (only one on the wall for the whole unit - living room and 2...
Okay couple questions here because either you have hot water baseboards or you have electric baseboard heaters.
- if the system is a hydronic baseboard heater fed form main boiler, usually this means your space heat is controlled by a zone valve which the zone valve is controlled by your thermostat.
-if you find the zone is controlled by a zone valve than it is possible the zone valve is defective causing hot water to bleed past the zone valve even though your t-stat is telling it to close.
- first find out what excatly the baseboard is heated by either water or electricity
-next personal message me and I can walk you through it
May 29, 2017 | Honeywell Heating & Cooling
DPDT thermostat for Singer baseboard heater.
as close as I've found
http://keithspecialty.com/k/67-411.htm
http://www.heater-store.com/specialty-thermostats_91_ctg.htm
Nov 02, 2009 | Honeywell Programmable Thermostat Heater
Honeywell HZ517 Electric Baseboard Heater not powering up
first.... did they work in the past?? if so... you may have a defective thermastat. if not, usually it is a incorrect wiring problem. wiring in two baseboard heaters to one thermastat can be tricky if you do not know what you are doing. baseboard heaters by design seldom go bad.... if wired correctly the problem could be a defective thermastat or safety limit switch.
Feb 09, 2009 | Honeywell HZ517 Baseboard Heater
Replace three wire thermostat with four wire thermostat
From the two red and two black wires (and the specs in the pdf), your new thermostat sounds like it's designed to directly control the line voltage (120 or 240) to the heater. That's the usual way baseboard heaters are controlled.
Could your wires be red, black, and (old, yellowed) white, the standard colors in a 3-wire power cable? Just the red and black should be enough to control a 120-volt heater so I don't understand what the white would have been used for. If it were my heater I'd take off the cover(s) -- with the power off, of course -- and find out what those wires actually connect to.
Jan 26, 2009 | Honeywell Programmable Thermostat Heater
Honeywell T86A3006 24V Class 2 Round thermostat 8020
The honeywell tradeline thermostat would work as a direct replacement (no mercury in the new ones), however if your using just heaters and no cooling system off of it, you could Heat only thermostat from honeywell that would replace your unit as well. Both at available at Ace Hardware with the heat only unity being roughly 7 dollars cheaper.
Jan 14, 2008 | Honeywell CT87B ROUND HEATING&COOLING...
Fahrenheat Electric Convector Baseboard Heater, 240 Volt Logo
50 people viewed this question
Top Fahrenheat Heating & Cooling Experts
butch welch
paulcarew
Are you a Fahrenheat Heating and Cooling Expert? Answer questions, earn points and help others
