Question about Epson Stylus 1400 InkJet Photo Printer
Epson Stylus Photo 1400 end of service life - Epson Stylus 1400 InkJet Photo Printer
mesaiah
  • 4 Answers
SOURCE: service life has ended on my epson stylus r320 photo printer
1.Turn off the printer.
2. Press the maintenance and the stop button simultaneously.
3.Turn on the printer again while holding the maintenance and the sop button.
this will reset the printer.
Posted on Nov 15, 2007
Lonewolf1038
  • 6 Answers
SOURCE: epson stylus photo r320 ink pad relacement
Here's 3 things you can do to get around this...depending if your printer is new and still under warranty or not (do NOT void your warranty!).
I have used all 3, but the third one was a lifesaver (AND money-saver!). About once a year I have to reset the printer using #2, but other than that....#3 is the greatest!!!
1. Try resetting it by, unplugging the power cord then while holding down the POWER STOP and MAINTENANCE buttons simultaneously while replugging the power cord caused a reset to zero on the counter. You will still have to replace the pads or redirect the waste ink tube to a receptacle on the outside of the printer, hope this helps?
2. If you go to inkjetprinterhelp.us there you will find the ssc service utility. Once you open the page click on the service utility and then choose the english version unless you can spk russian.If you then scroll to the bottom of the page and install the prog. Once you have installed the prog you will get the ssc utility logo in your bottom tray. Right click the icon and then select reset protection counter from the protection counter drop down. Once you have done this restart your computer and this should reset the system.
3. INSTALL AN EXTERNAL WASTE TANK and forget all about those gunky ink pads forever!
On the left rear of these printers is a small trapdoor held by a single screw.
Remove it, look inside (down and to your left) and you'll see the waste ink tube.
The tube is free at one end, and with a suitably curved piece of wire you can hook it and wangle the end out through the opening (you may dislodge a small piece of plastic in the process -- just put it back where it was, it's only a vibration damper.) I found the tube to be rather short....so I added an extension since I do not have room directly behind my printer for a container. I used the tubing you use with oxygen tanks or fish tank bubblers. They also make a little plastic connector so you can join the two together.
At this point, you're almost there.
All you need now is a suitable container for the waste ink, and I drilled a small hole in the trapdoor cover so you can put it back on without pinching the tube (or you could just leave it off.)
The container is a small square one with a snap-on lid, approx. 60mm square and holding about 150ml -- they're sold in sets of three for a few cents and are for making ice-blocks etc. in your freezer. Any small container will work.
Make a hole in the lid (slightly larger than the tube to let air escape) insert the tube and forget about the internal pads forever.
I've had mine in place for almost 2 yrs now and it works like a charm. If you need photos, let me know and I have a couple I can send you.
Posted on Jul 01, 2008
Thanks for your selflessness Steve H. describing the RESET procedure for the Epson R300 by simutaneouly depressing the POWER, STOP and MAINTENANCE switches.
I checked with Epson, via telephone, and they recommended going to an authorized dealer for ink pad replacement (approximately $100) or buy a new printer ( $150 - $250).
After completing your suggested RESET procedure successfully - I went a step further and mopped up the excess ink that was evident on the 'black ink pad' which was saturated with black ink. I used Kleenex which seemed to mop up the excess BLACK ink nicely, and continued this mopping procedure until there was no evidence of black ink on the Kleenex. There was very little evidence of spilled ink on the color pads.
Time alone will tell. So thanks again Steve - you saved me $100 to $200.
Oh yeah! I LOVE this printer.
Posted on Aug 21, 2008
websnail
  • 419 Answers
SOURCE: reset ink-pad counter on epson stylus photo 1400
The simplest way to do this is to grab a copy of the A10_IPR utility that Epson distribute to their customers...
The utility is available to North American customers if you register no this site page http://www.epson.com/ipr/
The utility is also know to be available in the wild if you search for "waste ink ipr".
Just remember to scan any download using a virus and malware scanner before you attempt to use it as some utilities contain trojans or similar nasties.
Hope that helps.
Posted on May 12, 2009
SOURCE: service required for EPSON STYLUS R230
service required
Posted on Jul 28, 2009
Hi Ya! I was looking out for the solution of the Epson 1400 printer having black toner shows pop-up message; which displays "Consumables near end of service life". "Prepare the following...
If a consumable product reaches the end of its service life, the product stops printing and displays the following messages in the LCD panel or the window of EPSON Status Monitor 3. When this happens, the product cannot resume printing until you replace the depleted consumable products.
The photoconductor unit comes to the end of its service life. Even if this message is displayed in the LCD panel, you can continue to print for a short time by pressing the B&W Start or Color Start button on the control panel. The message in the LCD panel changes from Replace Photoconductor to Worn Photoconductor.
Mar 22, 2011 | Epson Stylus Photo 1400 Printer
My Epson Stylus Photo 1400 has the paper and ink LEDs flashing alternately and the message 'Parts inside your printer are at the end of their service life' comes up when trying to run a nozzle check. Is...
When you see this message you need to replace the parts or buy a new printer. It cost more to replace those parts that a brand new printer. All Epson's are like this . I had 4 Epsons and all 4 done this same thing. They are great printers but unfortunately they are like this.
Aug 10, 2010 | Epson Stylus 1400 InkJet Photo Printer
I need to change the rpinter head of my epson photo stylus 1400
I found the best solution. Same for me! They made it for the Yellow print head comes first dead. The fast way to cure as IMPOSIBLE to disasemble the mechanism. Is to throw away in metal and plastic waste! Just to buy HP...They have cheap price head replacement and in 4 seconds you can change them! K8400 is the best and you'll never will see end of life...almost eternal! Epson IS MADE FOR FAST END OF LIFE PRINTHEADS and NOT REPAIRABLE! It's loke a Lada car!! LOL!
Apr 29, 2010 | Epson Stylus 1400 InkJet Photo Printer
How to reset waist ink counter
The printer is out of warranty,you should contact epson express centre for a replacement if you have the prove of purchase.
Jun 03, 2009 | Epson Stylus R290 InkJet Printer
Reset ink-pad counter on epson stylus photo 1400
Hope that helps.
May 12, 2009 | Epson Stylus Photo 1400 Printer
R2400 EPSON PROBLEM
Yikes... lot of these lately..
The solution in this thread will provide the answers you need.
http://www.fixya.com/support/t1544015-epson_r_2400_top_trashcan_light_ink
Feb 02, 2009 | Epson Stylus Photo R2400 InkJet Printer
Service required for EPSON STYLUS R230
http://www.efillink.com/Support/HowToWasteInkDrainR200.html
Sep 25, 2008 | Epson Stylus Photo RX700 All-In-One InkJet...
Epson Stylus  1400 InkJet Photo Printer Logo
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
