Question about Plumbing
Buck stove blower
Im trying to bypass a buck stove thermostat that is no longer made. the thermostat that went bad is a control products part#p99001011 and is no longer sold. the blower motor is a fasco part#d1139 3 speed motor. from the wall plug I have a black , white, and green wire the green being grounded to the stove. to the motor I have a red,white, black, and blue wire available to hook up. my question is which of the plug wires (black, and white) do I hook to the motor wires (red,white, black, blue) to successfully bypass the thermostat and keep the motor on?
Cerfer39
  • 709 Answers
SOURCE: wiring ceiling fans to wall switch
Hi Bigelow,
You need two switches.  It sounds like the Electrician set up the junction box for two circuits(Lights and Fans).  i say this because your supply has 4 wires, Red , Black, White and Bare. We may be able to oversome this with one Lutron Switch. Allow me to investigate, and I will be back.
Posted on Oct 29, 2007
johnny5846
  • 379 Answers
SOURCE: 1998 dodge ram 1500 4x4 stereo wiring
glad you posted what colors you do have , cause 2 resources didn't match ,actually 3 , i did find a match to your colors was a 97 year model premium radio, so we have a match .....
black/ light green = ground
dark green = left front spkr +
purple = right front spkr +
blue/white = right rear spkr -
brown/blue = left rear spkr -
brown/yellow = left rear spkr +
blue/orange = right rear spkr +
black/yellow = park lamps
brown/red = left front spkr -
orange = dimmer signal
pink = fused battery +
green/red = radio choke relay
red/white = fused ignition
blue/red = right front spkr -
cheers
djmac62 is also an excellent answer
Posted on Jan 10, 2009
farfield
  • 462 Answers
SOURCE: replacing blower motor in furnace w/Fasco brand #D727
Some one missed the wiring diagram. I believe its like this:
L1 = Line 1 = (Hot all are same thing)
Black Hi
Blue Med
Red LO
Now usually the black is for AC and connects to a normally Open (NO) contact on the blower relay.
The heater speed (either red or blue) go the the normally Closed (NC) on the blower relay and on one side of this wire or contact on the relay it goes to the heating blower thermostat on the furnace.
The remaining wire (blue or red) you tape off.
L1 also feeds the Run Capacitor on 1 side and the Brown wire feeds the opposite side
The white wire is Neutral and goes to the neutral on the main line.
If this helps you please rate me accordingly and good luck.
Posted on Mar 13, 2009
  • 334 Answers
SOURCE: The pump is a three wire single phase. My inputs
You need to connect the green and black wire to a ground. The other two wires got to the two hot wires from your power. It does not matter which ones are connected as long as the ground is correct.
seth
Posted on Jul 18, 2009
agent91
  • 2100 Answers
SOURCE: how do I change the electric wire in a franklin
You have 4 wires coming out of the fuse box , one white , one bare, one black, one red, right? The fuse is a double pole, 220 volt, ?30?amp, guessing, and you are now wiring up to a 110 volt, motor which needs 20 amps, so, remove one wire from the breaker, red or black, shut it off first, pull the wire off, tape it and mark it what it was. leave the red wire on there, or the black, it doesn't matter, Now you have one hot, one ground, one neutral, hook them up to the pump, the box on the pump has screws, one silver, one brass, the brass is always hot, the colored wires are always hot, The silver screw is neutral, the white is neutral, always, and the ground wire goes to the ground screw, maybe outside of the box. You should be all set, tape off the old colored wire you didn't use and mark it . You might need it someday. Hope this helps.
Posted on May 31, 2010
My oven and broiler no longer heat. There is no error code on the screen, and I don't see a spark on the igniter when it tries to start.
The safety valve will not blow unless the ignitor is shorted while operating- the valve is a simple continuity check. If you are getting no 120vAC to the ignitor during a bake selection, replace the control board. If you recently self-cleaned the unit, you may have blown the hi-limit fuse. Never use self-clean! Range Stove Oven High Limit Thermostat WB24T10081
Jul 13, 2016 | Kitchen Ranges
Buck stove 27000 fan runs on low but when goes to high will shut down moved temp gage to front and rewired with harness won't fun on manual either.
Buck Stove ' Hearth.com Forums Home
www.hearth.com/talk/threads/buck-stove.45094/
Jan 6, 2010 - I replaced the blower motor. immediately blower would run for... ... Buck Stove 26000 insert (1982, in the living room fireplace) Has kept ... I throught the same thing so I fired the stove really hot, motor would not run past low setting and ..... I have a pre-1979 Regular Buck 27000 where the thermal disks are ... Anyone burn an insert without the surround?
Jan 8, 2012
Insert Blowers - to use or not?
Jan 3, 2011
Buck Stove Fan Noise
Dec 27, 2010
Any HVAC Techs or Electric Motor Gurus Here?
Nov 22, 2010
More results from www.hearth.com
Nov 08, 2015 | Cars & Trucks
Main blower runs all of the time.
If you bypass tstat, meaning hot wired blower, does the blower cycle on and off by touching and removing red with fan?? If yes than obvious problem in tstat. I was leaning towards a bad relay but if you can make it work by passing tstat, there's you problem.
Jun 23, 2017 | Heating & Cooling
Replaced igniter, dryer worked great for 3 days, now igniter still works but the flame only stays on for 3 to 4 seconds not raelly heating up the dryer
it can be the high limit thermostat,the flame sensor eye on the burner tube,or the cycling thermostat on the blower housing you can try bypassing the thermostats to see if they are weak,but dont leave them bypassed as they control heat output and will cause over heating if left bypassed
Mar 05, 2012 | LG DLG5988 Gas Dryer
Buck Stove 27000 Blower Problem.
John, there are several switches on the heater,an air flow switch, a high temp cutout switch on burner housing, so the heater don't get to hot, there is another disc switch by the vent, It may just need a good cleaning throughout,check flame sense probe/wire,circuit board
Jan 30, 2010 | Heating & Cooling
Dryer do not spin if thermostat is plugged
Ok. The model number pulled up a stack unit and a regular standalone dryer. Im refering to the standalone Dryer.
Your Temp control thermostat is located in the front of the blower housing in the front of the machine, part # 134048800
the thermostat that your jumping is either the thermostat on the heater housing, Part # 3204267
or the Thermal fuse on the back wall,
Part # 134120900
If you have not changed the Thermostat on the blower housting, this is why you have not solved the problem.
Make sure your heater coils are not shorting to ground as well.
Make sure to replace the thermostat that your jumping and the one on the blower wheel. and as always make sure you unplug the machine while you work.
Jan 08, 2010 | Frigidaire FSE748GF Dryer
Intalled an overhead 130K BTU Mr. Heater last
On a call for heat, the 24 volt thermostat sends a signal to the control module. The control module will indicate a call for heat with a light on the control either blinking or remain solid depending upon model. The inducer (exhaust) blower will purge all gasses from the furnace and pressurize a pressure switch. Once the pressure switch tells the module to continue, the electronic ignition will energize and send 120 volts to the igniter. The igniter will glow and you will be able to see it if viewed thru the small inspection port. Once the igniter gets hot enough, it sends a signal to the module opening up the gas valve (24 volts). Either a pilot will come on or the burner tube will ignite then spread the flame to all burners. Lastly a safety sensor will be looking for a certain temperature within a few seconds and the furnace will continue to operate and the room air blower will turn on in a minute or two.
What could go wrong? The unit will not run if there is no signal from the thermostat (bad thermostat or broken wire), the control module does not sense a signal from the thermostat (bad control), the inducer does not energize (bad motor), the pressure switch does not close (blocked vent piping, bad switch, plugged condensate hose), the igniter does not energize (bad control, bad igniter), the gas valve does not open or there is no gas (bad gas valve, broken wire, no gas), the pilot does not light (dirty pilot), the burner does not light (bad burner, plugged orifice, not enough combustion air), the flame does not spread to each burner (bad flame spreader, dirty flame spreader, more bad burners), the flame safety sensor does not detect flame (dirty or bad flame spreader, bad flame sensor, broken wire, bad control), or the room air blower does not energize (bad fan motor, bad control).
Dec 01, 2009 | Mr. Heater Heating & Cooling
I have a GE electirc stove JDP37GT1Bb The blower that cools the oven doesn't turn off at all
If that blower that cools the oven is auto run and off automatically, then maybe the thermostat that controlling it, was damaged.
May 31, 2009 | GE JBP30 Electric Kitchen Range
Heat controller furnace will not lite and seems to have no power ( it does )
pilot generator may be bad if you have propane heat.In some cases that can indicate a low voltage short ,or could have a bad transformer on unit
Oct 03, 2008 | Heat Controller PE121A Air Conditioner
Plumbing Logo
96 people viewed this question
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
