Error c-0210 dialta 470 - Computers & Internet
3 Suggested Answers
SOURCE: quiero saber el significado del
Hola, este c?digo de error es un problema con la opci?n de fuente de papel, del paper vertical transport cooling fan motor o de la tarjeta de control ( control board). Reemplaze el motor si esto no resuelve el problema, cambia la tarjetade control.
Posted on Mar 03, 2011
  • 1294 Answers
SOURCE: minolta dialta Di 470 donne code c 0210 puis
C210,transfer/separation corona malfunction.Change or clean the corona wire and the corona holders(white Assembly).
Posted on Jan 23, 2012
I have a photo copier machine minolta dialta di 470 that show error code c-0400
open the front door upper left is small access cover remove and depress the trouble reset. if the code comes back replace the scanner lamp and board.
May 03, 2014 | Konica Minolta Office Equipment & Supplies
Error code c0400 on minolta Dialta Di470
As I said before, Open the front door upper left is small access cover remove and depress the trouble reset. if the code comes back replace the scanner lamp and board.
Di450 error codes cf033
Hey their... The code on your Hub450/550/470 is the toner density not being read. The drum must be removed u will find a sensor under the Mylar(mylar catches the toner wiped from the drum) that sensor is dirty and the Mylar is bad... :-D. PS u can perhaps repair the mylar with tape from the inside... Good luck
Dec 24, 2013 | Konica Minolta DiALTA Di200 Copier
E000110-0210 CANON C3220-C1
Code E110-0210 Description The operation of the laser scanner motor is faulty. The rotation of the M laser scanner motor is faulty.
The motor lock signal remains in an unlock state for 1 sec or more while the laser scanner motor is in operation. Error Codes Canon iRC3220 Code E110 0210
Oct 29, 2013 | Office Equipment & Supplies
Quiero saber el significado del codigo 49 en la fotocopiadora dialta 470
Mar 03, 2011 | Computers & Internet
[CS Raw] Connecting to connection server port '5050'... [FAILED] *** 'COMPONENT_TYPE_YCP' YCPError: 'FND.0203' ***
Solve this problem
Checking connection servers...
*** 'COMPONENT_TYPE_YCP_EX' YCP EX Error: ('FND.0210', 0, 0) ***
[CS Raw] Connecting to connection server port '80'... [PASSED]
[CS Raw] Sending port check command... [FAILED]
*** 'COMPONENT_TYPE_YCP' YCPError: 'FND.0000' ***
[CS Raw] Connecting to connection server port '23'... [FAILED]
[CS Raw] FAILED
*** 'COMPONENT_TYPE_YCP' YCPError: 'PortSelector::AllPortsFailed' ***
Dec 08, 2010 | Yahoo Messenger
Machine has an error 0210 stuck key. Not sure what my daughter has done to her machine- can you help?
Machine has an error 0210 stuck key. Not sure what Problem with the Fujitsu Siemens LifeBook T3010 Tablet P
May 23, 2010 | Fujitsu Siemens LifeBook T3010 Tablet PC
Porque sale error c0500 en la dialta 470
plz chek the thermostate heater unit fuse and heater lamp and clear truble button and relase this code c500
May 28, 2010 | Konica Minolta DiALTA Di200 Copier
Minolta dialta Di 470 donne code c 0210 puis
Jan 10, 2010 | Minolta Office Equipment & Supplies
MInolta Di 183
Abnormally high toner density detected Black ATDC (auto toner density control circuit)
Replace black IU, check toner motors, make sure toner is loose not clumpy. Change dev reset toner level.
Thanks.
Mar 25, 2009 | Minolta DiALTA Di183 Copier
Computers & Internet Logo
26 people viewed this question
David Payne
David Payne
