How to set cmp-10 bt citizens printer into pairing mode
4 Suggested Answers
honey2509
  • 146 Answers
SOURCE: Passkey for printer
you can use the default passkey which is 1234..
hope this will work
all the best
Posted on Jan 31, 2008
SOURCE: My BT-10K pairs and operates in phone mode with a
CANT CONNECT TO PS3
Posted on Aug 06, 2010
SOURCE: BT GPS module RBT-2100LP stuck in pair mode
royaltek faq advises to disconnect battery for 3 days to reset device
Posted on Dec 29, 2010
How do I set pairing mode
You will need to be sure that your device has BLUETOOTH. If it has bluetooth please turn on the bluetooth settings on your android device. You will now want to turn on the speaker.
Using the android device you will search for available bluetooth devices. Once you see BT-100 you will select that to PAIR. Some devices will automatically CONNECT after the devices have been paired. If not, please press BT-100 again to CONNECT. The BT-100 speaker should BEEP indicating that they have connected and the speaker is now ready to use.
If you continue to have trouble feel free to contact the manufacturer at support1@digixmedia.com or going to http://www.contelusa.net
Feb 04, 2014 | Digix BT-100 Portable Bluetooth Wireless...
How you play music on jabara bt 2050 0n phone
first you have to pair your blue tooth device to your phone,first you turn the bt power to on on your phone menu,next you have to put your blue tooth device headphones into discovery mode,now most bt manufactures use the power button for this feature,by holding the power button down for 6 to 10 seconds when you turn the bt device on it usually puts the bt intodiscovery mode.a solid light usually remains on on your blue tooth device,then you can search or add new device from your phone menu.once they have paired or recognized you will need a pin pairing code.Most manufactures of blue tooth devices use a factory 4 digit pin pairing code ,they are as follows0000,1234,9999,or1111 i hope this helps
Feb 25, 2011 | Samsung Radio Communications
Can't remember how to pair my LG HBM-710 to my new phone - Samsung Fascinate. Can you help?
to pair a blue tooth device to a phone first you must turn the bt power on the phone to on,then you have to put your blue tooth device into discovery mode,now most manufactures use the power button for thisw feature.By holding down the power button on your device when turning it on for 6 to 10 seconds it usually puts the device into discovery mode.there should be a light that stays on on your blue tooth device.once you have the bt device into discovery mode you will be able to pair the device to your phone by search or add new device,once it pairs it will ask for a pin or pairing code.most manufactures of blue tooth devices use a 4 digit factory pin pairing code they aare as follows 0000,1234,9999,or 1111 once youve put tjhe pin code on they will pair ,i hope this helps
Feb 25, 2011 | LG HBM-710 Wireless Headset
Cant get it to woork blue light just blinks
you have to put ur bt device into pairing mode in order to pair it to a cell phone usually when u turn your bt device on you continue to hold the power button for 6 to 10 seconds and when you have a solid light you are in pairing mode then your cell will pair to your device,it will ask for a pin or pairing code,most blue tooth manufactures use a 4 digit code.the codes to most blue tooth devices are as follows 0000,1234,9999,or 1111.i hope this helps
Feb 20, 2011 | Jabra BT125 Headset
Hi, My WEP460 samsung Bluetooth head set will not connect to my PS3. What do I do?
You have to make sure your blue tooth device is in discovery mode .most blue tooth manufactures use the power button by holding it down for 6 to 10 seconds while turning your bt device on ,once in discovery mode they should pair but you will need a pin or pairing code.Most blue tooth device manufactures use a factory 4 digit pin they are as follows 0000,1234,1111, or 9999 i hope this helps
Feb 19, 2011 | Samsung WEP460 Bluetooth Headset
My uniden bt108 bluetooth headset would not pair with my new Iphone4. My Iphone 4 couldn`t even recognize my bt108.
On your phone, make sure bluetooth is turned on (settings, general).
While your phone is in discovery mode, turn your bluetooth device on and put it in discovery mode (usually you have to hold the power button for 7-10 seconds).
Your phone will find the device, and you will be prompted to enter the devises PIN number (often 0-0-0-0). Your phone should pair with the device then.
Dec 17, 2010 | Uniden BT-108 Bluetooth Headset
I am trying to pair my Jabra BT 4051 with my iPhone 3G. I had it paired with my 1st iPhone, which was just replaced. it goes into the "searching" mode, but never seems to find it?
Dec 11, 2010 | Jabra BT4051 Bluetooth Headset
Pair to a sony ericsson w760a to a just wireless bt-35k2 bluetooth wireless head set
Put your device in search mode.
Put the bt-35k2 headset in pairing mode.
(Press the ON button but hold it down for about 6 seconds. As I recall, it will flash intermittent blue and red; either way, you will certainly see flash sequence that is not normal "blue" mode.)
Once device detects headset, you'll be prompted for passkey; enter 0000. Pairing will complete once authenticated.
Dec 26, 2009 | Just Wireless Bluetooth Headset Wireless...
Pairing blackberry with MEX-BT3700U
Place MEX BT in the search mode (Hold down BT button until BT logo begins to flash) Put BB in BT search mode, When BB will identify the BT device as "XPLOD" when prompted enter on BB "0000" and enjoy.
Mar 24, 2009 | Sony Car Audio & Video
42 people viewed this question
k24674
jasbo
jasbo
