Question about Physio-Control Physio Control Lifepak 12 Unit to External Modem Cable - 10 Foot
Charger says battery failed - Physio-Control Physio Control Lifepak 12 Unit to External Modem Cable - 10 Foot
My lenovo tab is not working i were checked the charger also but the charger is ok
When a device like that fails completely, and the charger is charging there's only so many things that can go wrong.
  • The device has completely failed (worst case, but, not if nothing happened to it, no plugged in while lightning, no dropping, etc.)
  • The battery won't charge. If it's not easily replaced, see a battery store, they'll usually install one for the cost of the battery, if they can open it.
  • The regulator for charging the battery has failed. This means not only will it not charge the battery; but, it can't tell when the battery is charged, and it will kill the battery, this must be replaced by a repair shop, unless you know an electrician, and have the key to open the tablet.
Sep 02, 2015 | Lenovo IdeaPad Computers & Internet
Battery charger won't work.
The simplest is to throw the bad charger in the trash assuming the results are the same with both batteries otherwise the battery is probably failing.
Apr 15, 2014 | Drills
Dewalt DE0245 battery charger blink fast without battery inserted
It really sounds like the electronics in the charger are failing or failed, it's probably cheaper to buy a new charger
Mar 25, 2014 | Computers & Internet
When I connect charger with my laptop 30 sec show battery is charging after 30 sec one message show:- QuickSet The Ac power adapter type cannot be determined. your system will operate slower...
del recognition circuit may have failed in charger , or could be fine central pin on charger plug or laptop plug has broken connection,it is used to tell laptop that this is genuine dell charger.If you remove battery will laptop work off charger.if does then definitely one of the three problem possible . for first only soln try another dell charger first,often has to be one to suit your model ,common dell problem ,if then work and charge battery ,you will need to replace charger as recognition circuit failed. If either of last 2 can repair but need to pull apart repair broken connection ,or open up laptop and check power connection and repair connection . If you remove battery will laptop work off charger.if does the definately one of the three problem possible . for first only soln try another dell charger first,often has to be one to suit your model ,common dell problem ,if then work and charge battery ,you will need to replace charger as recognition circuit failed.
Oct 27, 2013 | Dell Inspiron 65W PA-12 1525 LAPTOP
My computer shuts down when i plug in the charger
Assuming this AC laptop charger functioned correctly at one time. Several Possibilities: (1) laptop charger has failed ... connect another compatible charger to your computer to test for this; (2) or the battery has failed ... remove battery and test if the charger plugged in directly powers the laptop.
Apr 07, 2013 | Targus APA30US AC Laptop Charger AC...
I have a firestorm double 14.4 charger. Both lights come on but neither battery charged. The charger does not get warm.
Take a volt meter and test the connections where the battery comes in contact with charger. If you have no voltage, then the charger has failed and needs to be replaced.
Aug 25, 2011 | Black & Decker Black And Decker 12 Volt...
I have a dell inspiron 1545. i have the charger plugged in but a red light is flashin on my laptop. this light then turns white and immediately red again.if i remove the charger the laptop just switches...
Probably battery, although that should be orange not red..
Remove battery and try it on AC alone, if that works, it was a damaged battery halting the process
If it does not, check the charger's tightness in the charging port, if sloppy or loose, this will need replacing.
Some Dell's are VERY picky about the charger, if not the exact model specified, they will not charge the battery
If none of the above, remove battery and test with another Dell charger of the same spec, if this also fails to work and you are sure the light is red, you have a problem with the motherboard. Commonly the charger power board fails on these.
Jan 06, 2011 | Dell Inspiron 1545 Notebook
I have an invacare ride on . The battery charger failed after the storm. Are they repairable or do I need a new one. If so, how much do they cost
The battery charger for this scooter is available from:
http://www.monsterscooterparts.com/
I believe the original equipment charger from Invacare for this scooter was a 3 Amp off board or on-board charger. The charger is no longer available from Invacare. Monster scooter parts shows this as a 2 Amp charger for the Lynx.
It would be more expensive to repair this charger than to replace it since you indicate it failed after a storm power surge. You will be happier by replacing the off-board or on-board charger for a price between $50 and $150. The only cost effective charger repair is the cord or plugs.
If the charger was plugged in during the storm, I would check the power path on the scooter for burnt fuses and wiring. Hope this helps.
Dec 30, 2010 | Invacare Supply Group Invacare Scooter...
Hi I have a acer aspire 5720 laptop had it about 1 year the orange light on the front which shows battery charging started to flash and when I moved the charger wire it flashes on and off I bought another...
Usually when you see this flashinf indicator it is a failing battery. IT maybe that some of the cells in the battery are failing and refusing to accept a charge, in that case the battery will actually damage the charger.
May 21, 2010 | Acer Aspire 5720 6497 Laptop
Physio-Control Physio Control Lifepak 12 Unit to External Modem Cable - 10 Foot Logo
571 people viewed this question
Top Physio-Control Medical Experts
Electro Med Services...
Rhonda Webster
Rhonda Webster
Are you a Physio-Control Medical Expert? Answer questions, earn points and help others
