Question about Caterpillar Backhoe Tractor
Brakes need bled 426C backhoe - Caterpillar Backhoe Tractor
We are trying to bleed brakes on CASE 426C Backhoe. But for some reason it is not working. What can I do to get it right?
Probably blew the master cylinder when you lost the brakes.
When an older vehicle's pedal goes ALL the way to the floorboards,the master cylinder "sees" crud at the end it never touched B-4.The seals have been damaged. Possible to get a kit to fix it but don't. Get a rbld. master and start over. Done.
Nov 11, 2014 | Toys
1937 ford coupe relpaced booster brake pressure when off/no pressure when started
Try checking with either propane or water mist on all hoses and surfaces where generated vacuum could escape.
Activator rod from Brake pedal to Master cylinder can be adjustable on some models.
Jul 20, 2017 | Ford C Cars & Trucks
I need to know where the bleeding screw for brakes on jcb214e backhoe
most of those type of equipment have inboard brakes in the axle tubes of the rear gear assembly i.e. follow your brake lines from the master cylinder to the rear axle assembly,the lines usually go in and to a caliper and another line comes out to a bleeder tip nipple ,some models are actually inside the axle tubes them selves requiring disassembly of the wheels ,axle tubes etc. until you get to the inboard rotors and calipers ,major work for such a minute ordeal this is done to keep the system protected believe it or not,i would obtain yourself a model repair manual if i were you or you could also go to jcb and ask them for a photo copy of the entire brake hydraulic system
Feb 28, 2012 | Jcb Bruder JCB Loader Backhoe
I replaced brake shoes and brake pads, bled brakes, still have spongy brakes
Hi:
Your Masre Cylinder needs bled or its only working for front r back:
#2- To much shoe to Drum Brake Clearance
Sep 28, 2010 | 1995 Ford F250
Caterpillar 426c Problem will not shift Into forward and Reverse
It sound like it could be a problem with FNR shift lever, is the harness running to the back still attached?
Mar 06, 2010 | Caterpillar Backhoe Tractor
Brakes don't work on polo n reg bled them seemed fine till turned engine on moved car 10ft no brakes
did you change the pads? if so when you bled the brakes did you make sure that all air was out of every line? if you bled the brakes for another reason you need to specify why
Sep 25, 2009 | Volkswagen Golf Cars & Trucks
Transmission on Backhoe
I think you need Check your Transmission Pressuer of your machine. After That Change Recormanded Transmission Oil & Right Quntity. Transmission Pressure Should be 10-12 bar.
Jun 14, 2009 | Bruder Jcb 4CX Loader
Caterpillar Backhoe Tractor Logo
Top Caterpillar Toys Experts
fordexpert
DROPNDEAL
DROPNDEAL
Are you a Caterpillar Toy Expert? Answer questions, earn points and help others
