Question about HP Compaq ProLiant DL360 G4 Server
Can't access bios
Bios access raid
    Master:
  • 680 Answers
Can not setup RAID 1 on an IBM X3200 M3 Server
you can access the raid controller using the BIOS and system devices>>> refresh>>> then select the controller then create your raid...
don't know why they move out from the POST the controller its really stupid''' Sorry..
Feb 04, 2012 | IBM System x3200 M3 7328 Server tower ...
Hello, I Have a Foxconn A74ML-K Motherboard that I need to reset the bios on, clearing it normally does not work and taking out the battery has the same effect, nothing. I cannot access the bios due to the...
just re-jumper the settings of the BIOS into pin1&2 for 5-10secs then plug the power cable but do not turn on the power, after that place it back to pin2&3 for the normal settings then turn PC on and access your bios..
Hope it help
Aug 26, 2011 | Foxconn A74ML-K Motherboard AMD Socket...
My raid controller has not install
Your RAID controller is managed by the RAID BIOS on the motherboard. Depending on the motherboard manufacture, you should be able to boot into the RAID BIOS to make adjustments to the RAID array.
Turn the machine off then turn it back on. Look for key combinations of Ctrl+R or similar to access the on-board RAID BIOS. Refer to the manufacture documentation for OS support or BIOS upgrades.
Mar 05, 2011 | Computers & Internet
Bios in my other computer is not fully acpi compliant (blue screen)what can i do ?
This error is typically related to the OS attempting to access the hard drive during install or startup.
So, it sounds like you've got some hardware like a RAID controller that is causing the problems. If you're attempting to install to a single hard drive, disable the RAID controller. If you've just installed some type of hardware, try removing it.
If you don't have a RAID controller, update your Bios from the manufacturer and see how that works for you
Oct 25, 2009 | Microsoft Windows 2000 Professional for PC
Trying to create a server using the ASRock k7vt6 mobo
turns out the RAID enable in the bios is also used to enable the SATA. but this doesn't mean you have to use RAID to use SATA drives! there's a separate bios to configure the RAID that you can access after the initial boot screen by pressing tab. here, you can delete an existing array or create a new one. deleting the array makes the motherboard see both drives separately, like I wanted. problem solved :)
Aug 01, 2009 | Asrock K7VT6 (K7VT6 RAID) Motherboard
OS on RAID is corrupt
Hi Compufixa,
Your problem is with the system needing a raid driver for the motherboard or the raid card. pretend you are installing windows with bartpe. it also asks you for the raid drivers. use a floppy disk with the raid drivers and let it load. that should let you see the raid drives as a set.
Hi Guest,
Your problem is a little different. since its a mirror raid. you might want to try taking out one of the drive and work with a single drive until it is fix. try doing a repair with the windows CD. seems like there are some corrupted OS files. And you might want to start a new question since your problem is really different from Compufixa's problem. Thanks
Apr 25, 2009 | Microsoft Windows Server Standard 2003 for...
Version number?
Bios 7N is for the following
  1. Support up to 137GB HDD and above.
  2. HPT 370 RAID BIOS version 1.11.0402. The RAID function is for KT7-RAID / KT7A-RAID only. This BIOS version is also for non RAID boards and HPT BIOS will be automatically disabled while RAID controller chip not detected.
Version A9 is the last update
  1. Fix nVidia GeForce4 Ti 4x00 AGP card compatible issue with Windows XP.
  2. HPT 37x BIOS version 1.11.0402.The RAID function is for KT7A-RAID only. This BIOS version is also for non-RAID boards and HPT BIOS will be automatically disabled while RAID controller chip not detected.
  3. BIOS Compile Date: 7/11/2002.
LINK
The above link is for the KT7a with Raid, however the standard KT7a also lists the same bios updates, the KT7a Raid ver1 lists different bios that won't be compatible with your board.
Apr 12, 2008 | Abit KT7A Motherboard
Raid JMB363 RAID BIOS UTILITY
The P5K motherboard has a four port vanilla ICH9. There
Is no RAID on the Intel, when the chip has only four ports?
So S1, S2, S3, S4 are not RAID.
In the P5K manual, the RAID function exists on the Jmicron
Controller. One drive connector is internal (SATA_E2, on the
Left of the motherboard picture in the manual), and one
Drive connector is external (F_ESATA on the back I/O area).
This is not convenient for building a RAID0. (The intent is
To allow making RAID1 backup disks.) You'll have to snake
The SATA cable back into the computer, if you hope to use
It with two internal SATA disks.
The manual has full instructions for setting up RAID on the
Jmicron JMB363. The manual says to set the Jmicron to RAID
Mode in the BIOS. Two disks must be connected, in order to
Be able to press <control-J> at the start of the BIOS, to
Enter the Jmicron RAID setup in the BIOS. At that point, you
Can declare an array in the BIOS setup.
Then, when Windows is installing from the Microsoft install CD,
You’ll need to press F6 and offer the Jmicron RAID driver.
Section 5.5 of the Asus manual, describes how to make
A RAID driver floppy. The application in the mother board cd is available for make drivers disk
Dec 07, 2007 | Intel D101GGC Motherboard
Sata/raid not working on ASUS M2N MB
You may need to set up the RAID array before it will be detected. Look in the BIOS and see if there is a way to set up the RAID array there. If there isn't, watch as the PC boots up and see if there is an option to go into the RAID settings before windows starts. You may need to actually create an array before it will be seen.
Nov 06, 2007 | ASUS M2N-MX Motherboard
HP Compaq ProLiant DL360 G4 Server Logo
319 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
