Question about Riso Office Equipment & Supplies
Cr1630 c25 remove used master but no master is on drum
The master came off the drum. But still receive error c25
3 Suggested Answers
  • 76 Answers
SOURCE: problem of C25 risograph cr 1610
Remove the old mater on drum and clean your master incoder strip and sensor. Look also at your drum clamp and bend the 2 sides of the 2 arms a bit up that goes under the clamp unit so that it can open a bit wider. let me know if you still struggling.
Posted on Oct 08, 2009
SOURCE: Pulled drum out and now
Patrick,
I am having the same issue. This is where I get a bit lost 'Once the preasure roller is back down look into the machine, there is a gear with 2 holes in it.The hole on the left must be in line with the hole in the frame, the hole on the right on the gear must not line up to any holes but show to the exit side on the machine.'
I am working on a Riso GR3770, but should be somewhat similar-I hope.
Are you able to explain where this 'gear with 2 holes in it is'.
Many thanks. Josh
Posted on Oct 11, 2012
Lanier error code 00
That is the master clamper area. Take off the rear cover. From the rear it is on the right. There is a motor and a rack gear that moves to open the drum master clamper when removing and loading a master. With the back cover removed, try to make a master while watching that assembly. You can also put the drum in and drive the motor by hand to watch and see if opens the drum clamper.
Dec 12, 2014 | Lanier Office Equipment & Supplies
I have a riso cr1630, after printing, image on papers is colorless or weight. i cheek ink cartridge and change it. but this problem Occur again! tell me what is problems please?
First Master remove the drum and pour some oil or gasoline on it
Is likely to be true
Fabrics drama, you most likely dead
If not properly written as plaid and pale published
The problem of the mirror
You should remove them just to be
May 30, 2014 | Riso RZ220 Duplicator
Where is the transfer belt located on a Konica Minolta C25
above the 4 drum units have to remove the 4 toners the 4 image units and the transfer belts is removed from the right side after removing a section of the duplexer on the right side door.
May 08, 2014 | Konica Minolta Bizhub C25 C35 C35p Color...
I have a c25 relay I'm wiring that is controled
I am a Master Electrician, I provide DIY services via email. You can pay via paypal. email me at buffalonymann@yahoo.com and I'll give you the link to my website where you can set up the account
Sep 04, 2009 | Cutler Hammer Eaton Electical #BD3030...
MY RISO CR1630 GIVES AN ERROR CODE 15 WITH TOOL FLICKER - IT LOOKS LIKE AN INK PROBLEM CAN YOU HELP PLEASE?
It is master position sencor,take out your master roll,pull out your drum. Take a a4 paper and push it threw there were your master go in,roll the 3 rollers in front so that the paper go forward so you can see the paper inside machine and pull the paper out to the inside of the machine. Put every thing back,turn off machine and while you hold the reset button in,turn machine on again. let me know if it worked.
Aug 13, 2009 | Riso Office Equipment & Supplies
RZ 220 Risograph error code A-16-525 after paper jam indication. No jam was present.
The master is stucked on the print drum,open print drum remove master and try again.
Let me know for futher help.
Jan 26, 2009 | Riso RZ220 Duplicator
Problem of C25 risograph cr 1610
Jul 01, 2008 | Office Equipment & Supplies
Riso Rz 220
Remove the master that is on the drum. Then check the master roll remove it cut about 18 inches off then re install master roll. hit the reset, then print bottons.
Jun 11, 2008 | Riso RZ220 Duplicator
15 people viewed this question
Top Riso Office Equipment & Supplies Experts
Marius Chiriac
paulfvincent
Adorjani Laszlo
Are you a Riso Office Equipment and Supply Expert? Answer questions, earn points and help others
