If a point on a line is (2, 6) and y varies directly to x, find y when x is 6
3 Suggested Answers
  • 2509 Answers
SOURCE: y varies directly with x if y =-4 when x=2 find y
so y = 2(-x)
if x is -6, minus x is +6
and 2 times +6 is 12
Posted on Nov 13, 2014
  • 2509 Answers
SOURCE: y varies directly withx.if y=-4 whenx=2 find y
answered
Y varies directly with x if y =-4 when x=2 find y when x=-6
so y = 2(-x)
Nov 13, 2014 | Cars & Trucks
Find equation line
3x-7y=2 is an equation of a line. That line doesn't go through the point (6, -7) though. Are you looking for the equation of a line through the point parallel to the first line? Perpendicular?
Jun 02, 2013 | Texas Instruments TI-84 Plus Calculator
Find tdc and adjust valves on a 325 i
With the tappet cover off, rotate the engine in the normal direction of rotation until you see #4 cylinder valves rock - open/close in succession. This will be TDC on #1 - set the valve clearances. Turn the engine until your see #2 valves rock, set #5 valves, turn the engine till #6 valves rock, set # 3 valves, turn the engine until #3 valves rock, set # 6 valves, turn engine till #5 valves rock, set # 2 valves, turn engine till #1 valves rock, set # 4 valves. Once you have located #1 TDC (the second mark in the pulley should be lined up with the cover mark), it is only 60 deg. to get to the next cylinder to set. If you accidentally go past the setting point, go back and approach the setting point again in the direction of engine rotation. When you come to setting # 6 the TDC marks should be aligned again.
Jan 29, 2011 | 2003 BMW 325
Equation of line between to points
Example: Equation of the line through (1,5) and (3,6)
Calculate the slope (gradient) of the line as a=(y2-y1)/(x2-x1) where y2=6, y1=5, x2=3, and x1=1. You should get a=(6-5)/(3-1)=1/2
The equation is y=(1/2)x PLUS b, where b is not known yet.
To find b, substitute the coordinates of one of the points in the equation. Let us do it for (3,6).
The point (3,6) lies on the line, so 6=3/2 PLUS b.
Solve for b: 6 MINUS 3/2=b, or b=9/2=4.5
Equation is thus y=(x/2) PLUS 9/2 =(x PLUS 9)/2
Jan 10, 2011 | Texas Instruments TI-84 Plus Calculator
If y varies directly as the square of x,and y=24 when x=4,find the constant of variation
y varies directly as the square of x means:
y = kx^2
Where,
k is the constant of variation. You can use any letter except y or x for constant
Put values of y and x: (24) = k * (4)^2
k = 24/(4*4) = 24/16 = 3/2 = 1.5
Answer: The constant of variation is 1.5 moz-screenshot.png
Nov 04, 2010 | Computers & Internet
Find an equation of the line containing the given pair of points (1,5)and(3,6)
Oct 20, 2010 | Texas Instruments TI-84 Plus Calculator
Maximum advertised distance
D-Link Air lets you access your network from anywhere you want. However, keep in mind, that range is limited by the number of walls, ceilings, or other objects that the wireless signals must pass through. Typical ranges vary depending on the types of materials and background RF noise in your home or business. The key to maximizing range is to follow these basic principles: 1. Keep the number of walls and ceilings to a minimum - Each wall or ceiling can rob your D-Link Air Wireless product of 3-90 ft. of range. Position your Access Points, Residential Gateways, and computers so that the number of walls or ceilings is minimized. 2. Be aware of the direct line between Access Points, Residential Gateways, and Computers - A wall that is 1.5 feet thick, at a 45 degree angle, appears to be almost 3 feet thick. At a 2-degree angle it looks over 42 feet thick! Try to make sure that the Access Point and Adapters are positioned so that the signal will travel straight through a wall or ceiling for better reception. 3. Building Materials make a difference - A solid metal door or aluminum studs may have a negative effect on range. Try to position Access Points, Residential Gateways, and Computers so that the signal passes through drywall or open doorways and not other materials. 4. Make sure that the antenna is positioned for best reception by using the software signal strength tools included with your product. 5. Keep your product away (at least 3-6 feet) from electrical devices that generate RF noise, like microwaves, Monitors, electric motors, UPS units, etc. 6. If you are using 2.4GHz cordless phones or X-10 (wireless products such as ceiling fans, lights, and home security systems), your wireless connection will degrade dramatically or drop completely. Anything using the 2.4Ghz frequency will interfere with your wireless network. For the average home, range should not be a problem. If you experience low or no signal strength in areas of your home that you wish to access, consider positioning the Access Point in a location directly between the Residential Gateways.
Feb 16, 2006 | D-Link Air Xpert DI-774 Wireless Router
Feb 16, 2006 | D-Link Air Xpert DI-774 (DWL-774) Wireless...
Range problem
Feb 16, 2006 | D-Link Express EtherNetwork DI-604 Router
Computers & Internet Logo
14 people viewed this question
David Payne
David Payne
