Question about Kymco Midi XL 8mph Mobility Scooter with Free Delivery
Brake problem brake locks on
What to do about the brakes when they lock up in 2001 Pontiac Aztec
check brake fluid --if rear brakes are drum possible out of adjustment ---or need brakes replaced --possible faulty brake caliper following link has gm vehicles the consept is the same
Rear Brakes Locking Up Yahoo Video Search Results What causes rear drum brakes to lock Need Help With Rear Disc Brakes Locking Up Heating Up Hot 1999 2006 2007...
Aug 04, 2016 | Pontiac Cars & Trucks
Brakes on my 05 trailblazer locked up while driving and the vehicle won't move.
ALL brakes locked up, or just rear? Rear could mean differential is locked up...Sounds more likely while driving it, as cars now have a front or rear valve so all brakes are not lost at one time..
Feb 20, 2015 | 2005 Chevrolet TrailBlazer
What is anti-lock braking system on cars?
Anti-Lock Brake systems are all essentially the same they will prevent the driver form applying 100% Brake pressure and locking up the wheels while driving. The ratchet the pressure more slowly to prevent the car from skidding. Our first reaction in an emergency is to slam on the brakes and that is 90% of the time not the right action. So Anti-Lock brakes are designed to prevent this unwanted skid.
If you need further help, reach me via phone at https://www.6ya.com/expert/john_411a7faba7ce8217
Sep 17, 2014 | Isuzu Rodeo Cars & Trucks
Had the brake switch replaced when I put the brakes on felt like I was thrown forward and the car won't move it's like the anti brakes are locked hyundia sonata 2002
THATS NOT THE ANTI LOCK BRAKES ,ANTI LOCK BRAKES PULSE NOT LOCK UP YOU HAVE OTHER PROBLEMS ,CHECK ALL BRAKES FOR HANG UP ,BROKEN PADS ,EVEN REAR WHEELS
Aug 05, 2014 | Cars & Trucks
How do you rewhy is my brakes locking down while driving?how do i rest the abs system?
You have water in the brake system, it boils and applies the brakes.
Different size tires will set a trouble code, but not apply brakes.
Jun 23, 2014 | 1995 Jeep Grand Cherokee
99 pontiac grand am - brakes are locked-up
Have you checked the emergency brake ? The cable could be locked up. Slowly apply e brake if it feels loose the cable is locked up. You could also have someone watch the cable near the rear wheel to see if it moves .
Sep 29, 2012 | 1999 Pontiac Grand Am GT
Brakes lock up after driving 10 km
Eighter you have problem to the to the anti lock brake modelue like a connection .Or there it a stuck valve inside BPMV witch is the molelue likely a dump valve witch is suppose to release the pressure .Unpluging the vacuum hose to the vacuum booster control will just disable the power brakeing mode .Try to figure witch wheel or wheels are not releaseing because the anti lock feature should not come into play unless there are extreame brakeing conduitions .See if its not a problem with a caliper sticking
Apr 22, 2012 | 2003 Kia Rio
I have a 2002 Lincoln ls . How do I replace the abs speed sensor? Right front tire?
you have one on the inside of each wheel.
SECTION 206-09A: Anti-Lock Control 2002 Lincoln LS Workshop Manual
REMOVAL AND INSTALLATION Front Wheel Speed Sensor
Material Item Specification RTV Silicone Sealant
FSTZ-19G204-AB (Canada CXC-114A) NAVSTR Sealer
Removal and Installation
  1. Raise and support the vehicle. For additional information, refer to Section 100-02 .
  1. Position the inner splash shield aside.
    1. Remove the pin-type retainers.
  1. Disconnect the anti-lock brake sensor electrical connector.
  1. Remove the anti-lock brake sensor harness from the brake hose clips.
  1. Remove the anti-lock brake sensor.
    1. Remove the anti-lock brake sensor clip.
  1. NOTE: Make sure the anti-lock brake sensor is fully seated before installation of the new clip.
    To install, reverse the removal procedure.
    • Apply a 2.5 mm (0.1 in) bead of silicone sealant to the outside diameter of the anti-lock brake sensor.
Rear Wheel Speed Sensor Removal and Installation
  1. Disconnect the rear anti-lock brake sensor electrical connector.
  1. Remove the rear anti-lock brake sensor harness from the control arm clips.
  1. NOTE: Clean off dirt and foreign material that may have collected around the rear anti-lock brake sensor before removal.
    Remove the rear anti-lock brake sensor.
    1. Remove the anti-lock brake sensor bolt.
  1. To install, reverse the removal procedure.
Feb 24, 2010 | 2001 Lincoln LS
Brake lock-up
I suspect that you have front disc and rear drum brakes.You did not say which of your brakes are locking up. I suggest that if your front brakes are locking {skid} that means your rear brakes are not engaging. If your rear brakes are locking {skid} then I suggest you have problems with park brake or brake fluid leaking onto the rear shoes.
More info would help me help you. I will check back soon.
May 21, 2009 | 1985 Honda Accord
Anti lock brake light
abs relay some times go bad
Dec 05, 2008 | 1999 Oldsmobile Alero
Kymco Midi XL 8mph Mobility Scooter with Free Delivery Logo
20 people viewed this question
Top Kymco Health & Beauty Experts
Lawrence Oravetz
Robin Hill
Robin Hill
Jeff Tilburn
Jeff Tilburn
Are you a Kymco Health and Beauty Expert? Answer questions, earn points and help others
