Question about Dometic Rooftop RV Air Conditioner
Outside heat stops ac operation
Outside temp over100 deg unit current to high,trips braker
    Genius:
  • Dometic Master
  • 1,363 Answers
Clean coils seee if it makes a difference. all air-conditioners are designed by mfg. to run in a ambient temperture of 95 degrees. after that they lose effiency.
Posted on Aug 16, 2015
  • 10865 Answers
SOURCE: dometic rv air conditioner over 100 deg. trips breaker.
The problem is that when u add up the electrical draw from all of these appliances running full bore, your draw exceeds your available amperage. Now you are doing the math and saying no...... Let me tell you why. It is rare to find a situation where a 100 amp service actually porovides 100 amps. You almost always have voltage dropo. And when you are adding extension cords to the mix the drop is even more. That said, When you are using the AC try to minimize the use of other appliances, especially the microwave which is a big draw too.
Posted on Jun 25, 2009
panilling9
  • 284 Answers
SOURCE: Breaker trips on roof top RV A/C
check your breaker is it hot to the touch?
check the wire tightness at the breaker?
remove the circuit breaker and inspect the terminals on the breaker and in the panel and the breaker itself for signs of overheating and discoloration due to the fact
check the connections at the unit itself
check that you have proper voltage to your unit
find the nameplate and look for FLA full load amp draw
is the breaker properly sized for the unit and is the wire size correct for the breaker?
(Check nameplate on unit)
buy a clamp on amp meter and see if it is under or over the nameplate rating when unit is running
take great care when you venture into electric,if you arent comfortable find someone who is.
you may have a weak breaker if all the above pass?
Replace it
Posted on Jul 05, 2009
SOURCE: outside unit tripped the breaker. flip the breaker
either the start/run capacitor,or , fan motor is bad.-
Posted on Jul 06, 2009
mcdevito75
  • 1970 Answers
SOURCE: my ac compress is making a loud noise, but still
mcdevito75 here, Sounds like the blower motor is going bad have it checked by your local A/C repair people.
Posted on Jun 24, 2010
  • 674 Answers
SOURCE: i live in AZ. my
The fan not in the shroud may cause this. Are you sure the condenser fan is even running or running at the right speed? If its not running, the compressor head pressure will build up until it possibly pops the breaker.
Posted on Jul 29, 2010
Why wont hot tub heat with jets on losing temperature on 110 volt
My first question would be about the outside temperature. What is the outside temperature?
Hot tubs that are designed to operate on 115v only have 1.5kw heaters and if the outside temperature is below 50 deg F they tend to not keep up to 103 deg water while being used. They are also designed to not heat while the high speed pump is operating.
Does it stay up to temperature on a normal basis?
ROD
US Parts Center
Jun 08, 2014 | Qca Spas Dream Series Dream Master Hot Tub...
Not cooling
outside freeze sensor locking out operation
Jan 04, 2014 | Dometic Rooftop RV Air Conditioner
Not sure the heat pump is producing enough heat
lower the fan speed to low and if you do not close your turns at 50 degrees Celsius then check the freon
Nov 04, 2011 | Heating & Cooling
1988 true GDM 33 its 100+deg. in my shop. Refrigerator is only cooling to @44 deg. is that about normal for the outside temp?
The unit is probably not designed to work in an ambient temp that high, probably 90-95 would be as hot as the manufacturer was thinking, however the age of this unit probably means the compressor valves are not sealing quite as well as they used to. this can cause a unit to never pull down all the way to proper temp. get as much air circulating to the unit to help draw heat away
Aug 31, 2011 | True GDM-33-C-PT-54 Refrigerator
I have a Ruud Model RQNA-B 13 Seer heat pump and it has shut down during this cold snap. It does this everytime it turns extremely cold and in the summer when it is extremely hot. Help, the service men...
If the outdoor unit is not operating and the electric heat is working, more than likely the outdoor thermostat is keeping the unit off.
This is an adjustable setting, doing it at the outdoor
unit. Typically the unit is ste anywhere from 15-35
deg outdoor temp. If it is 20deg outside and unit is not operating you turn it down to 15 deg to get the unit to run.
In the summer time if the unit is placed where it is
extremly hot most of the day, then the unit is
probably either shutting down to the compresssor
internal overload,which resets on its own. Or it
is tripped out due to a High pressure switch
whick can be reset manually or automatically depending on the unit.
The High pressure switch is located on the liquid line
which is the smallest of the two refrigerant lines.
If its a manual reset,just push the button in.
If you can get the unit to run, check to make sure
the outdoor fan is operating.
Good-Luck
Jan 09, 2010 | Heating & Cooling
During heating (outside temp. 2 deg C), outside
Get the charge tested, check the sub-cooling across the outdoor coil.
Dec 19, 2009 | Heating & Cooling
My Duo Therm Runs good until the outside Temp. Reaches about 75 dregees Then starts kicking off the braker. What would cause this?
Too many things on the same circuit. Try turning everything electrical off but the ac and see if it stops tripping the breaker.
Jun 08, 2009 | Dometic Rooftop RV Air Conditioner
Heat pump cycling on and off.
It sounds as if you you have a low charge of refrigerant, r22. When the unit comes on outside, the outdoor coils become the lowside, there is a low pressure switch that is tripping out contactor protecting the compressor.
Mar 11, 2009 | Heating & Cooling
Possible Computer Problem
Its sounds like your engine wormed-up.
Jun 10, 2008 | 2000 Lincoln Town Car
Phkj048-1
If the outside temp. is lower than 32 deg. F it is normal for the outdoor unit to build up ice but not safe for the motor compressor. Because the safe outdoor temp. in heating is 5 to 64 deg. F but don't worry it has safety device to stop the operation.
Mar 18, 2008 | Goodman PHKJ048-1 Air Conditioner
Dometic Rooftop RV Air Conditioner Logo
52 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Donni Steen
mike cooper
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
