Question about Tecnik Built Under Larder Compact Refrigerator
How to clean built under larder
Has a dip stick in bottom of fridge with black mould have cleaned with cotton bud but can't get all of mould
Sticky buttons
Lifting it up may break the buttons.... Can you try using cotton bud and try cleaning it; if it can enter without forcing it; dip it in a methylated spirit and apply it gently.
Feb 03, 2014 | Lenovo Computers & Internet
Can you please advise what we clean the laser head with
If you are able to open the unit and access the laser mechanism then i would recommend using isopropyl alchohol (available from chemists and good camera shops) and a cotton bud. Isopropyl alchohol is particularly suitable as, unlike commercialy available tape head and laser mechanism cleaning fluid, contains no water and evaporates after use. Using a cotton bud, dip one end into the alchohol and lightly wipe the laser surface in a circular motion. Then, reverse the cotton bud and repeat the action using the dry end (although the alchohol will evaporate this helps to remove any crud you may have released). You may care to repeat this procedure if the laser has never been cleaned before. Hope this helps.
Jan 12, 2014 | Wurlitzer Jukebox CD Player
DVD JUST LOADS WON'T PLAY
Try cleaning the lens of your DVD player either by a lens cleaning CD or remove the dvd cover and clean the lens using a soft cotton bud dipped in Shaving lotion or Lens cleaning liquid.
Oct 27, 2012 | Televison & Video
I have a PS3, and in the past few months it would randomly quit playing games. sometimes it would feeze in the middle of the game, then it got to the point that it would freeze at start up of the game,...
Hello, you haven't been handling your device with care. Please, avoid touching the readable part of your cds with your hand. Get you lens cleaned. For me, I use water to clean any of my lenses. My trick: Use a cotton bud (for the ear), dip the cotton bud partially into clean water, Do as if you are flapping the cotton bud, in order to remove the water droplets. Use the cotton bud to clean your lens very gently. Next use the other dry end of the cotton bud (which should be very neat) to finally clean the lens. Leave you device for 5 minutes, then try your neat cds. Sure, this helps, and dont forget to rate me. Thanks a lot
Apr 21, 2011 | Sony Video Game Consoles & Games
I just put in a new black ink cartridge and it will not print black ink. The color ink prints, but the black will not.
Hello nicfurtaw, there are dried ink on the ink carousel, or cradle, you may need to soften the ink. Use cotton buds, dip into warm water and gently wipe the ink hole where the ink pass through, until the carousel is clean.
  1. remove the black ink cartridge
  2. find the spot where the ink pass through
  3. see dried ink on it.
  4. use cotton buds dipped in warm water to soften the ink.
  5. do this several times
  6. clean enough, test to see if the black ink will pass through
  7. replace the black ink cartridge
  8. test the printer.
Feb 10, 2011 | HP Photosmart C3180 All-In-One InkJet...
The fridge and freezer smell like a dead animal. cleaned the inside with bleach but still smells for weeks. model w10212088
There are two reasons for bad smells. 1. Long time not being used. 2. Lack of cleaning inside compartment.
Solution: Unplug fridge. Keep open fridge door. Dip a dry cloth in soap water and start cleaning each and every compartment. Keep freezer door also open. And then clean with another dry cloth. Keep both doors open for nearly 5 hrs. It will be enable fresh air to **** the smell inside fridge.
After 5 hrs close the fridge and run on empty for one hour. Keep food items after one hour. Please keep all food items closed vessel. Not only it's avoid odor but also be hygienic.
If you use to keep fish items in freezer, clean fridge once in a week.(Spray roo spray in the room when you keep fridge door opened. Don't spray into fridge.)Helpful.
Jan 30, 2011 | Whirlpool Refrigerators
How do I clean the laser lens?
Get a cotton bud and dip it in a dilute solution of washing up liquid and clean water. Place the bud in the centre of the lens and rotate it counter clockwise cleaning off the dust/gunge etc
Allow to dry thoroughly and then test.
Jan 01, 2011 | Samsung Televison & Video
Small puddle of water on floor in front of fridge
there is a drain pan under the fridge where water is collected then evaporized from the heat of the compressor thet sometimes the pan cracks or the pan is unleveled .check pan
May 23, 2009 | Bosch Logixx KDR40423 Refrigerator
CD-ROM cANT BE READ
Hi
sometimes DVD/CD drive become dirty of dust falling into leses.
Try This first !
Prepare 1 Cotton buds (clean one)
1 ply of tissue
1)Dip i side of it to Pure SWAN ALCOHOL or cleaning pure alcohol
2)touch 3 second of cotton bud to tissue (this to ensure excessive alcohol absorbed to tissue)
3) eject your cdrom drive
4) use cotton bud, scroll /rub/ twist the bud onto the shiny lens, be careful not over excessive force over the lenses.
5) rub again with dry bud.
TRY read your discs
Good luck
Please rate me if you happy with the results
Jan 05, 2009 | Computers & Internet
Epson C43SX
try this: delete epson c43sx drivers then reinstall them then go to the Epson web site and look for an updated driver, if that does not work take the whole cartridge harness out, under the harness you will see a contact board and you will see another one on the printer, get cleaning solvent and a cotton buds, dip cotton bud into the cleaning solvent, turn cotton buds sideways and clean the contact boards on both the cartridge and the printer, clean until and refresh cotton buds until you get a a clean cotton bud tip, let it sit for 5 to 10 minutes, reinstall the harness and try again, if that does not work you could have a main board problem contact Epson.
Apr 23, 2008 | Epson Stylus C43SX InkJet Printer
Tecnik Built Under Larder Compact Refrigerator Logo
18 people viewed this question
Top Tecnik Refrigerators Experts
Charles T Nevin
Charles T Nevin
richie46
ray gallant
Are you a Tecnik Refrigerator Expert? Answer questions, earn points and help others
