Question about Hoover SteamVac F5914-900 SpinScrub Upright Vacuum
Hoover Platinum Collection Carpet Cleaner F8100-900 is leaking out the bottom on to the carpet. how do I fix the problem
Water is leaking at the bottom of my shampooer( < Go to Carpet cleaners pagePrintPrint Hoover Platinum Collection Carpet Cleaner F8100-900
  • 37 Answers
SOURCE: hoover steam carpet cleaner
does the trigger feel like it is doing anything? if not you may find that your handle lever guard is broke and needs to be replaced. this is the plastic piece at the top of your handle and can be removed by taking out the screw. if this isnt it let me know.
Posted on Sep 25, 2008
  • 384 Answers
SOURCE: carpet cleaner pick up water
water outlet are pluged soap residue seal broken or miss alined
Posted on Apr 05, 2009
  • 97 Answers
SOURCE: My Hoover Carpet Cleaner is leaking out the bottom
this could be the little white valve that the water comes out of, if its leaking from here or if its leaking at the bottom of the machine it could be the pump
Posted on Jul 19, 2009
  • 97 Answers
SOURCE: Hoover Steam Cleaner - dirty water is not coming up in the tank!
recovery tank (dirty water tank) not on correctly
Posted on Jul 20, 2009
ftw1952
  • 10319 Answers
SOURCE: hoover carpet cleaner brushes do not move
did you check to see if the belt came off or its stretched?
Posted on Jan 24, 2010
Automatic shut off comes on as soon as I start cleaning the carpet
Try taking tank out see if the sensor that might be stuck or the tank may have a small piece broken off that keeps the auto shut off working. Try utube for further videos on this problem.
Sep 22, 2016 | Hoover SteamVac Spinscrub 50 Carpet...
Help! My boyfriend took apart my hoover platinum carpet cleaner
That sucks! Um, if you do not have the manual, here it is
http://hoover.com/file/622/
If that does not help. you can contact Hoover
https://hoover.com/contact/
Flick the boyfriend
May 08, 2015 | Hoover SteamVac Carpet/Upholstery Deep...
Hoover brush and wash instruction manual
Hi there! To prepare for cleaning, put the solution and water in the top tank. While cleaning, all the dirty water gets sucked into the bottom tank. To clean squeeze trigger to release cleaning solution and slowly push carpet cleaner forward, this equals one wet stroke. Continue to squeeze trigger and slowly pull carpet cleaner back toward you (second wet stroke). Release trigger and slowly push carpet cleaner forward over area just sprayed with solution (dry stroke). Then slowly pull carpet cleaner back toward you without squeezing trigger (dry stroke). To avoid saturating the carpet don't do more than 4 wet strokes over one area. Always end with dry strokes. Here is a link to view the instruction manual if needed.
http://hoover.com/file/604/
Hope this was helpful!
Jun 19, 2014 | Hoover SteamVac Carpet/Upholstery Deep...
I have hoover platnium collection vacuum the lights turn on but does not run
If you are electrical handy, check for wiring continunity to motor or the motor itself could be bad. Only do this safely.
Dec 02, 2013 | Hoover Platinum Collection Carpet Cleaner
Hoover spin scrub 50 leaking from bottom
Uh, may I encourage everyone to check the trigger under the handle...we went through taking the whole thing apart and it was just that the trigger was stuck in the open position, which poured the water out continually!
Apr 09, 2013 | Hoover SteamVac Carpet/Upholstery Deep...
My Hoover SteamVac carpet cleaner leaks water
i have a hoover carpet cleaner and when it is not in motion it leaks water
May 23, 2010 | Bissell Carpet Cleaner Powerbrush Deep...
Hoover vacuum carpet cleaner will not sucktion (sic)
No, this cleaner uses no belts.
If you are having a suction problem, first check that the lid on the recovery tank is lined up to the tank when installed to get a good seal.
Second, remove the tank and make sure the round black rubber seal is present on the pipe from the base that aligns with the bottom of the recovery tank. That seal connects the vacuum from the motor to the recovery tank.
Oct 13, 2009 | Hoover F7425-900 SteamVac V2 Widepath...
Hoover Steam Vac V2 Deep Cleaner leaking clean water
Fill the tank and determine if the plastic is leaking, or if the valves are leaking. if the tank is cracked, it would need replaced. There is an improved design now available.
You may cycle the valves on the bottom with the eraser end of a pencil.
Sep 24, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
Instructions on Using The Hoover Steamvac Ultra cleaner
CARPET CLEANER\r\n™
i went the xtra mile to look this up you give me a incorect modlel # put the user guide are the same ps: dont for get to vote for me when it ask if i helped you lol sawdust46
MaxExtract™ technology features the most advanced
combination of multi-action agitation, carpet washing, dirt
removal and direct heat drying - all in one machine. This
technology delivers a floor that is not only deeply cleaned,
but a room that can be lived in again within hours!
• High intensity LED
- illuminates problem areas
• Stream Setting
- ideal for smaller spots
and stains
• Spray Setting
- attacks heavy traffic areas
Dual scrubbing1, multi-directional
brushes have been specifically
engineered to surround carpet
fibers, removing dirt at every angle.
1Patent pending
High velocity suction removes both
dirty water and soap residue, leaving
carpet revitalized. Forced heat further
speeds the drying process. No sopping
wet carpets. No musty odors. Just
clean carpet.
STREAM
SPRAY
REMOVES MORE DIRT2
INTEGRATED SPOT CLEANING
2Test of leading brands of household extractors using FCTP-0024p
Our exclusive pre-programmed
cleaning modes take the
guesswork out of revitalizing your
carpets. Simply select your carpet
type and cleaning task, and let
the pre-programmed modes take
care of the rest. Fully equipped
with Process Feedback Lights
and Full Tank Indicator Lights,
this Intelligent Cleaning System
makes cleaning your carpets
easier than ever before.
HOOVER PLATINUM COLLECTION™ DETERGENTS
TO MAXIMIZE CLEANING PERFORMANCE
PROFESSIONAL STRENGTH
Carpet and Upholstery Detergent
PET PLUS
CARPET CLEANER
Instant Stain Remover
Carpet and Upholstery Spray
AN EFFORTLESS CLEAN
CONVENIENCE IN HAND
Powered Scrubbing Tool,
Upholstery Brush and
Crevice Tool included for
cleaning fabric covered
items such as:
• Stairs • Upholstery
• Mattresses • Pillows
• Area Rugs
To learn more about the Hoover Platinum Collection™
visit www.Hoover.com ™ ®
Six new vacuums, six new standards of clean, and six
new reasons for Clean Freaks to Rejoice. The Hoover
Platinum Collection™ saves you time and effort while
giving you the confidence of knowing your home is truly
clean. Whether corded or cordless each item is distinctive
in both appearance and performance, offering best in
class cleaning through a combination of innovative
technologies and carefully engineered ergonomic design.
With the Hoover Platinum Collection™ you get fast and
effective deep cleaning so you can move on with what
is next in your day, knowing you have efficiently
accomplished the deep clean you desire. With these six
superior cleaners from Hoover®, it is a wonderful time to be
a Clean Freak, and a terrible time to be a dirt molecule.
EXCLUSIVE HOOVER PLATINUM COLLECTION™ MEMBER SERVICES LINE:
1.877.MYPLTNM (1.877.697.5866)
Hoover®’s Best In Class,
Limited Six Year Warranty
Jul 11, 2009 | Hoover F5872-900 SteamVac Wet/Dry Vacuum
Leaking Hoover Steamvac
Either you have a crack in the tank and it is running down the indise of the handle and going out the bottom, or there is a water line off either under where the tank sits or under the top cover.
Mar 29, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
Hoover SteamVac F5914-900 SpinScrub Upright Vacuum Logo
37 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
