Carl lewis magnetic rower
SOURCE: Machine does not register when rowing
You most likely moved or damaged the senser under the seat check if the wire is loose or damaged the the senser it in the center of the bottom side of the seat Good luck
SOURCE: Nordic Rower replacement wheel
Nordic Rowers were made by Water Rowers, which still exists and sells parts.
SOURCE: I have problem with Carl Lewis RO84 magnetic rowing machine, cord goes slack
dEAR Sir:
Adjust the damper on the rowing machine. The damper controls the amount of drag you are experiencing as you pull. It is supposed to simulate the drag in the water. Most rowing machines have 10 levels. Between levels 3 and 5 will be your closest simulation to the water. Consider this for your exercise if you are training to be a rower.
ernesto cuadra
managua, nicaragua. c.a
SOURCE: R205 Tunturi Rowing Machine, needs new bearing wheels under seat
Good News! Home Depot sells (on-line only) drawer rollers that work PERFECTLY for the Tunturi Rower machine seat rollers. The only difference is the wheels are nylon instead of rubber. Model Number R7228, Internet Number: 100142874. Item description: ROLLER, W/ 1/4" -20 STUD, 1-1/8" NYLON, BALL BEARING. There are two rollers in a package, $5 for two! http://www.homedepot.com/buy/prime-line-1-1-8-in-nylon-ball-bearing-drawer-rollers-2-pack--r-7228.html
