Question about Black & Decker WMB500 Belgian Waffle Maker
Parts Plastic hinges - Black & Decker WMB500 Belgian Waffle Maker
F4 button pressed in
Most of the Roland buttons on this type equipment use a small switch that is actuated by a plastic button that is HINGED from a plastic panel behind the faceplate or a part of it. These plastic hinges get broken when too much force is applied to the button... it is USUALLY fatal and requires replacement of the whole button faceplate... and they are expensive... contact Roland parts to inquire.
Mar 01, 2011 | Roland Mv8800 Production Studio
The plastic hinges on my 3210 that hold the top on
Is it just stuck? Because if it is just use WD40 on the hinges. If it's broken, then sorry. Can't help you.
Jan 18, 2010 | HP Photosmart 3210 Printer
I have a Dometic rm2652 refrigerator the door hinge broke
the hinge is not plastic, only the insert sleeve that goes into the hole atop the door is plastic. If the actual hinge (metal arm) is broke, then you need to order a new part (not difficult if frig is 20 years or less). If you cannot find the part, go to a metal shop and show them the broken part, they usually can repair it or remake a new piece.
If the hole in the door went bad (that is: if the hole tore open and cannot hold the hinge pin) you need to have a metal repair brace added to the door. This will involve the metal shop or a good mechanic that can come to you and do the neccessary repair at the house; otherwise you need to bring the door to the metal shop. macgivor
Dec 27, 2009 | Dometic RM2652 Refrigerator
Need left hinge/spring box
Precisionroller.com
their part number is H7914
Brother part number is LP2403001
Nov 18, 2009 | Brother DCP-8040 Copier
The plastic part on the back hinge broke and i
This just happened to ours, it's a design flaw in my opinion.
Anyway, I drilled through the plastic covers and used 4 6-32 countersink screws, 2 inches long, with corresponding nuts and ground off the excess screws with a dremel tool.
Won't come apart again and matches the brushed stainless theme.
Jun 22, 2009 | Waring WMK300 Professional Belgian Waffle...
Door opening internal plastic hinge broken
Just saw you post as I was searching for the same item. If you have not found the part yet, it can be ordered from repairclinic.com (part #916507). $5.50 plus shipping.
Apr 18, 2009 | Sharp R-1480 Microwave Oven
Door hinge is broke on Bosch Axxis+ Front loader
There are 4 screws in the door that hold a plastic hinge cover on
.The door will then set into the hinge just fine (PLENTY OF ROOM) and then you put the hinge cover back on and screw the screws in to hold the door onto the hinge.You will likely need a 2nd set of hands to keep from breaking the door.
Oct 10, 2017 | Bosch Axxis WFL 2060 Front Load Washer
Plastic casing over notbook hinges broken.
Look on ebay for hinge covers. Sometimes you will find them on there. Good luck!
Dec 17, 2008 | Acer Extensa 5620 Notebook PC
Brother MFC 8420-- hinge?
i went to Brother site and opened support.
searched for parts and got a listing of technical support shops in my area. called the first one listed and asked if they had the LP2403001 hinge in stock and they came back with an affirmative answer. will pick it up this afternoon locally.
You can see an image of the hinge assembly at ebay if you search for LP2403001.
Regards,
David
Jan 25, 2008 | Brother DCP-8020 Laser Printer
Black & Decker WMB500 Belgian Waffle Maker Logo
77 people viewed this question
Top Black & Decker Kitchen Appliances - Others Experts
Irene Tulloch
Gerry Harvey
Gerry Harvey
Are you a Black & Decker Kitchen Appliances - Other Expert? Answer questions, earn points and help others
