Question about Toshiba E-Studio 3511 Color Copier
Enable ssh Toshiba eStudio - Toshiba E-Studio 3511 Color Copier
4 Suggested Answers
mhdali25516991
  • 3 Answers
SOURCE: Why Toshiba estudio 350 Ink missing
Check the developer drive gear,
behind the mother board,,,view the two clutch left side clutch is developer drive clutch, open & check the gear.
Posted on Apr 04, 2014
alam2020
  • 11 Answers
Two things could be 1 check dv unit gear normally gear teeths worn out then you need to replace gears together with seals but if gears are ok then open back cover remove cooling fans board and clean or replace developer drive clutch it shoud be fine after one of above let me know
Posted on Jan 23, 2015
Can you post the image of the developer gear for Estudio 355.
Posted on Jul 21, 2016
To clear the code error c413 of Toshiba estudio 2505
How do i clear the error code C413 at Toshiba estudio 2505 thnx, regard asif ali
Feb 08, 2017 | Toshiba Office Equipment & Supplies
Tip
Vmware enable SSH
If you want to do advanced features in VMware ESXi you will need to go into the core of ESXi to do this you can use Secure Shell or SSH. SSH is simplar to telnet but the data is encypted.
To enable SSH on VMware ESXi you need to enter an the ‘unsupported’ mode.
Step 1. At the physical console of the ESXi server press the Alt+F1 key combination.
Step 2. Type ‘unsupported’ and then press <Enter>. Note that nothing will appear on the screen whilst you type.
Step 3. When prompted enter in the ‘Root’ password and press <Enter>.
Step 4. You will now be presented with a prompt on the console. From this prompt type the following command
vi /etc/inetd.conf
Step 5. vi (the file editor) has now opened the inetd.conf file. Using the direction arrows scroll through the lines until you reach the line that has ‘#ssh’ and remove the hash (ie: #). This is effectively un-commenting this line so that the ssh service can be started.
Step 6. Now that you have made this minor file you want to save this change and exit out of the editor (vi). To do this press the ESC key (to put vi back into Command Mode) and then type ‘:wq’ *Note: If you want to exit without saving any changes to the file then just press the ESC key (Command Mode) and then type ‘:q!’.
Step 7. With the SSH service now un-commented from this file we need to restart out ESXi box to do this type in Reboot.
on Mar 31, 2010 | Computers & Internet
Error code C440
Toshiba eStudio 355/455 Full Service Manual - Tradebit.com
https://www.tradebit.com/.../155135538-toshiba-estudio-355-455-full-se...
Download Toshiba eStudio 355/455 Full Service Manual ... Configuring DepartmentCodes Configuring ... TSB-1013: C440 Error - Countermeasure .... DIG-ACC-145: MJ-1025 Bracket Change to Enable Installation on e-STUDIO205L/255/305
Aug 08, 2015 | Toshiba E-Studio 305 Digital Copier
I want to limit printing to black & white on my toshiba estudio 3040c
U can enable department code for colour print, enable "no limit black", where user print colour only prompt for department code. All this can be done under User Function --> Department Management
Sep 25, 2014 | Toshiba Office Equipment & Supplies
How do I print via USB on a Toshiba Estudio 200L copier?
You might need to have an enabler, which will fix to your copier.
May 16, 2014 | Toshiba Estudio 200L Copier
How to enable duplex in printers toshiba e studio 160troubleshooting
For estudio 160, once u connected the duplex unit, u can start using it after u power ON the machine.
Dec 30, 2009 | Toshiba E-Studio167 Copier
Scan feature greyed out on Toshiba eStudio 232
You have to have the USB stick to enable the scan.
It locates on the right side near the back of the machine.
They make , print dongles, Scan dongles and print scan dongles. But that USB device enables scan.
May 04, 2009 | Toshiba e-Studio 232 Black and White...
Toshiba E-Studio 3511 Color Copier Logo
90 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
