Question about Babies R Us 1011187 Babies R Us Perfect View Color 5" Video Monitor
The monitor wont pair with camera - Babies R Us 1011187 Babies R Us Perfect View Color 5" Video Monitor
Existing Uniden cameras won't pair - nothing has been moved, but we lost surveillance and cameras wont pair
Check the camera power supply. If this is an IP camera, you may want to make sure that the camera didn't change the IP address.
Sep 07, 2015 | Uniden Video Surveillance System Uds655
Why night vision is dark
Had a similar issue. If the cameras have the night vision led lights and it's just one camera, the wire pair that supplies power to the lights may have a short, if all cameras are dark, the main power supply may be out. You can check with a voltage tester. Some cameras use three wires with a common ground, others are 4 wires. One pair for the video and one pair for power.
Aug 11, 2014 | Samsung SDE-120n 4 Channel DVR System
I have a Samsung baby monitor SEW-3034, it was working pretty ok, but after 2weeks not using, now when I plugged in power and turn on, only beep once and no screen show up, try charge for a long time, but...
You can connect up to 4 cameras and each camera must be paired with the monitor. Sounds like you need to repair the camera so that the monitor will recognize it. Look at the boston of the camera there should be a button to press.try this
Aug 16, 2013 | Baby Gear
Monitor says no signal, no picture or sound
Step 1: Move the Monitor to the same area as the CAMERA. With
the Monitor on, press the Menu button on front of Monitor and using
the Scroll button move down to the "ADD/DEL CAM" option. Press the
Scroll button to select "ADD/CAMERA".
Step 2: At the same time press and hold the scroll button on the
monitor and the pairing button on the CAMERA for at least 5
seconds. Then release.
Step 3: You should then see a picture from the CAMERA on the
Monitor.
Step 4: If this is unsuccessful, you will see the message "OUT OF
RANGE" on the Monitor screen and should repeat steps above
making sure the CAMERA and Monitor are close enough to each
other for pairing.
Jan 11, 2013 | Summer Infant Baby Care
How do I sync other cameras to the baby monitor?
just decide which camera you want next one to be so say camera 2 on your monitor and on the back of the camera you want to add there is a pairing button press it and it will pair, and the just add on to the next one say camera 3 if you have another camera just press the pairing button on the camera your adding each time
Aug 21, 2012 | Summer Infant Best View Handheld Color...
My samsung video monitor (sew3030) says out of range and I have tried everything and nothing works.
I had this same problem all i did on the menu went to the option where it has the monitor and the camera behind it and click on the middle button (select) and it says pair it and some seconds then you click the button behind the camera and that was all i had to do hopefully it solves your problem if not this is the number you can call for technical support 1-877-349-3149
Mar 04, 2012 | Samsung Wireless Baby Monitor Camera...
My camera is saying out of range can you help
Turn on both camera and monitor. Bring the monitor close to the camera. Press menu button and scroll down to "add camera"
Press and hole the pairing button on the back of the camera and press and hold the centre button on the monitor and hold for a few seconds. The monitor should soon show what the camera sees. Then just close up menu.
Sep 13, 2011 | Summer Infant Best View 25" Color Video...
My summer best view handheld video monitor says out of range and will not pair.
Have you tried pressing the pairing button at the back of the camera unit and press the scroll button at the center of the receiveing monitor at the same time as suggested by the manual? I had the same problem, followed the manual instructions and solved it. (Greetings from Mexicali, M
Sep 06, 2010 | Summer Infant Best View 25" Color Video...
Had summer baby monitor for eight months, last night it stopped
Your monitor has become unpaired with your camera. Follow the instructions in the manual to pair them again (basically, tell the monitor piece to Add New Camera while you press the Pair button on the camera). The manuals can be downloaded from www.summerinfant.com.
Jul 08, 2010 | Summer Infant Day & Handheld Video...
My baby monitor summer zoom pan has deleted the camera and won't let me add it on. Says no camera! HELP!!!
take the monitor to near the camera put the monitor to which camera say camera 1 and then on the camera there is a pairing button press it and thats it.
Apr 26, 2010 | Summer Infant - Secure Sounds Digital...
Babies R Us 1011187 Babies R Us Perfect View Color 5" Video Monitor Logo
354 people viewed this question
Top Babies R Us 1011187 Baby Gear Experts
Dorel UK
Dorel UK
Jennifer Rock
Jennifer Rock
Are you a Babies R Us 1011187 Baby Gear Expert? Answer questions, earn points and help others
