Question about Brother AX-425 Typewriter
Not printing correct characters
When type, character pressed is not what is typed
JayBlair
  • 328 Answers
SOURCE: types incorrect characters
Have you checked the keyboard switch inside on the right. The US setting is the selection to the rear.
Posted on Aug 15, 2007
  • 120 Answers
SOURCE: Brother ML-500 Typewriter Typing the wrong characters
The printwheel is not in correctly. the printwheel has a bent spoke or the printwheel homing sensor needs cleaning. Lawrence
Posted on Feb 14, 2008
JUSTOLDJIM
  • 478 Answers
SOURCE: No Characters Typing
could be the ribbon is not lifting, do you see an image on the ribbon, also may be twisted inside the cartridge the shiny side has to be facing the keyboard.
Posted on Nov 06, 2008
venexcsd
  • 1185 Answers
SOURCE: Wrong characters.
You need to get the user guide out and make sure that you have set the keyboard up to suit your country.
If you do not have a user guide go to www.brother.com and you will find one in their downloads section
Posted on Jun 16, 2009
Jimsta01
  • 405 Answers
SOURCE: I am getting all the wrong characters, when I
You simply need to replace the daisy wheel to resolve this issue.
Posted on Jun 27, 2010
How do I fit the correction tape o a Smith Corona XL1500 typewriter
First, backspace to the mistaken character. You slip the correction tape in the middle of the platen where the type hits, then type the same character, pull out the correction tape, backspace and type the correct character.
Nov 28, 2014 | Smith Corona Office Equipment & Supplies
Print Traditional Chinese Characters
Try to find the characters in internet and then print them using pdf document oor any type.
The following links give you few Chinese characters.
Chinese character cards 1
Chinese character cards 2
Chinese character cards 3
Chinese character cards 4
Cheers!
May 06, 2013 | Epson LQ-2090 Matrix Printer
Toshiba Satellite A45-S250 non-numeric keys locked
Your keyboard logic chip is in need of therapy.
Replacement of keyboard warranted.
Now, I thought that it might be a redesignation of your language code, but that proved not to be the case.
Mar 29, 2009 | Toshiba Satellite A45-S250 Notebook
Olympia supertype 330 types wrong characters
check the pitch setting to make sure that it matches the printwheel. It is the switch that is marked 10, 12, 15, PS. PS is proportional spacing and will only type correctly with a PS wheel. The number settings are for PICA ELITE and MICRO.. 10, 12 and 15. The numbers are characters per inch...so the larger the number, the smaller the character.. it is the opposite of FONT SIZE.
Feb 05, 2009 | Olympia Supertype 330 Typewriter
Wordsmith 100 Wrong character typed.
Your keyboard assembly needs to be replaced.
Jan 14, 2009 | Smith Corona Wordsmith 100 Typewriter
I have a brother 4100 fax. how do I change the information on the fax transmission page? thank you
If your date and time are not set yet, press Menu, then 1, then 2 and enter the date and time, pressing Set after each entry. Enter time in 24-hour format so it will display AM or PM properly.
For other info at the top of your fax transmission page after date and time, such as your fax and phone numbers, and company name:
Press Menu, then 1, then 3 for Station ID info.
First put in your fax number and press Set.
Next put in your phone number and press Set.
Next press the buttons for your company name and press Set.
Press Stop/Exit to return to the date and time display.
Here is info on inputting text, from the manual:
Entering Text
When you are setting certain functions, such as the Station ID, you may need to type text into the machine. Most keys on the dial pad have three or four letters rinted above them. The keys for 0, # and don’t have printed letters because they are used for special characters.
By pressing the appropriate number key repeatedly you can access the character you want.
Inserting Spaces
If you want to enter a blank space, press once between numbers and twice between characters.
Making Corrections
If you entered a letter incorrectly and want to change it, press to move the cursor after the last correct letter. Then press Clear; all letters above and to the right of the cursor will be deleted. Re-enter the correct characters. Also, you can back up and type over incorrect letters.
Repeating Letters
If you need to enter a character that is assigned to the same key as the previous character, press to move the cursor to the right.
Special Characters and Symbols
Key - once - twice - three times - four times - five times
2 - A - B - C - 2 - A
3 - D - E - F- 3 - D
4 G H I 4 G
5 J K L 5 J
6 M N O 6 M
7 P Q R S 7
8 T U V 8 T
9 W X Y Z 9
Press for (space) ! “ # $ % & ’ ( ) + , - . /
Press # for : ; < = > ? @ [ ] ^ _
Press 0 for é à è ê î ç ë ö 0
Jan 11, 2009 | Brother IntelliFAX 4100 Laser Fax
IBM Wheelwriter 3 typing incorrect characters
If you have another printwheel try that, if you still have the trouble try blowing out the area where it is in stalled. If that fails turn the machine off then back on, after it completes the POR mark the printwheel with some white out, repeat the POR see if the mark is in the same place, if it isin't you probably have a selection plate problem.
DickyO
Nov 11, 2008 | Lexmark Wheelwriter 3 Typewriter
Feb 14, 2008 | Brother ML-500 Typewriter
Types incorrect characters
Aug 15, 2007 | Brother ML-100 Typewriter
Types wrong Characters
Does it always type the same wrong letter ie a always prints u or w ? if so the print wheel drive gear is out of position. if not and it get random letters some thing may be interfering with the wheel rotation.
Jul 04, 2007 | Smith Corona Wordsmith 200 Typewriter
Brother AX-425 Typewriter Logo
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
