Question about RCA F27450 27" TV
I have a 2006 Sony TV big screen, I turn the Tv on but it clicks back of within seconds.
I have a Sony TV big screen. I bought it in 2006. The TV wouldn't come on so I purchased a lamp for that model, that I had bought new in case that the old one went out. It wouldn't come on before I changed it. So I thought that that was the answer. We changed it and it was still turning off an on but it wouldn't stay on and it is still doing it.
SOURCE:
CompuGuy44
  • 432 Answers
SOURCE: TV turned off by itself, now wont turn back on!!!
It has gone into protection mode. This is caused when a short circuit is detected by the power management system inside the tv. Try a hard reset: Unplug the power cord for a full 4 hours; then try it again and see if it will clear the protection fault and reset it. If the reset does not help you will need to have a tech look at the set and take voltage measurements inside to determoine which section of the tv has failed and what components will need replacement. The cost of repair is always over $150 and could be much more, depending on the specific parts that need replacing. for example, if the convergence ICs have burned out the repair is around $350. The flashing of the standby light may mean something, but I do not know the diagnostic code RCA is using; most RCA models do not have any diagnostic blink codes in the set. Hope this helps. Let me know if I can help further.
Posted on Jun 29, 2007
MikeNJ1964
  • 398 Answers
SOURCE: rca home theatre big screen tv
If it is truly a 52 inch standard projection set (you have it listed under 32V420T which is not a projection TV) and your 3 colors (red, green and blue) are no longer lining up and are all curved on the sides, then it means that your convergence power supply has stopped working. Post the actual model and chassis number and a better description of the picture here and I will be able to assist you further.
Posted on Aug 07, 2007
SOURCE: tv problem
went the tv swith on it swith off by itseft
Posted on Aug 10, 2007
cutejessie
  • 72 Answers
SOURCE: Tv won't stay on
it is a brandnew tv, so expected that it is under warranty,, it best for you to return where you bought so the warraty will not void. Big possible of factory deffect.
Posted on Dec 26, 2007
  • 135 Answers
SOURCE: 36 inch RCA 36v430t
Mike-It looks like the power supply is going on your tv-it can be replaced. This happens, usually, when little kids are playing wth the remote or power button on the tv. Turn it off and on a whole bunch of times in a row, kids love to do that, and it burns out the power supply part- to make a CRT tv like your RCA36 incher- which is a beautiful machine- I have the RCA/PROSCAN 36 incher-LAST longer...You should always wait 5 min between turning it off and on. Don't ever sell it. This one is worth fixing. It has better color and sound Than the new plasmas and lcds-The Pros know this. Be carefull, they might try and talk you out of it-so they can fix it and have it for themselves. So what if it's not High Deff. It's a great set.
Posted on Jul 02, 2008
There is a big block in my TV screen covering 8 to 10 inches. I have a Sony Bravia, model KDL-40S4100, and i bought it in 2008.
if it is a black block, look in the menu under closed captions and see if it is in the text mode. if so change back to cc1 or turn off.
Aug 19, 2011 | Sony Bravia KDL-40S4100 40 in. LCD TV
I would like to know if this TV model is digital raedy.It has a MFG. date as 2000 I want to take it on a trip if it is digital ready. Thank you Thom
If the tv it is flat and tv LCD screen design than it is digital ready.It well be able to pickup free DTV air broadcasting from tv channels stations.If tv it have a big back and bulky design like it have CRT-tv tube.It well not pickup tv broadcasting in tv digital channels,all tv channels went digital on 2006.
Jun 30, 2011 | Televison & Video
I have a sony grand Wega KDF-kdf50e2000 and when you turn the TV on it will work fine for 40 seconds and then go off with the green power/standby indicator flashing. After 40 seconds the TV will come back...
If this is the model I am thinking of, Sony has a recall on the light engine. They are going bad in many of the Grand Wegas. Call them up and they should offer a new tv. You can either get a BRAND NEW lcd tv for free, but it is going to be smaller than your current one. Or you can get a different size for a reduced price. Late last year (november 2009) my grandma saw a red band at the top of the display. We called up Sony and we got a BRAND NEW 46" 120hz Sony Bravia for about $250 if I remember correctly. And since it is a new tv, you get a new warrenty. You also get to keep your current grand wega because they simply don't want them. I stongly recommend calling them up because this will give you a new tv. Spread the word.
Jan 02, 2010 | Sony Grand WEGA KDF-60WF655 60" Rear...
Turn on the big screen sony tv, but fades to blue
You probably have a bad BLUE CRT. Due to the cost and the length of time it would take to repair, I would not invest the money into it. It would require a Qualified Service Person to come to your home and remove the BLUE CRT assembly and send it back to SONY to be rebuilt. Estimated cost would be around 800.00. I would check prices of a replacement set.
I hope this helps,
Skyassoc
Oct 27, 2009 | Sony KP-46WT500 46" Rear Projection...
Tv won't stay on
Dec 26, 2007 | RCA 20F420T 20" TV
Sony KV-35S42 35" TV
Check first for bad solder on the vertical IC, Im not sure for your set as I do not have the service manual, but it may be location IC301. If after resoldering it does not fix it you may have to replace it and you should replace the electrolytic capacitors in the vertical section. Hope this helps. Don
Jul 31, 2007 | Sony KV-35S42 35" TV
Red Screen
Sounds like the red color tube is goeing bad you wil hafto call in a tech to conferm it Sony is noted for tubes goeing bad, in the future leave sony alone
Sep 24, 2006 | Sony KP-57HW40 57" Rear Projection...
RCA F27450 27" TV Logo
42 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
