Question about Keurig Mini B31 Plus Red Coffee Maker
Wont brew coffee. takes water - Keurig Mini B31 Plus Red Coffee Maker
SOURCE: coffee machine vibrates very loudly
IT VIBRATES WHEN TAKING IN WATER
Posted on Aug 13, 2008
  • 5 Answers
SOURCE: coffee maker is not pumping water fast enough.
have you tried cleaning it? Minerals from the water build up inside the tubing and make it run slow. Take a pot full of white vinegar and run it through a brew cycle. follow this by a couple of pots of cold water and you should be good to go.
Posted on Nov 04, 2009
  • 60 Answers
SOURCE: Partial cup of coffee brewed
Call keurig customer service 1800 cup brew
Posted on Mar 26, 2010
espressonist
  • 1711 Answers
SOURCE: Keurig coffee maker will not **** the water to brew
Here is a sugestion tip that will help
http://www.fixya.com/support/r5543433-keuring_coffee_maker_b60_b70
Good luck thanks for voding
Posted on Aug 10, 2010
heatman101
  • 43501 Answers
SOURCE: wont brew coffee. runs water through fine.
Here is a tip that I wrote that will give you some things to try that will helpyou get your Keurig coffee brewer workingagain.
Keurig CoffeeBrewer not making a full cup of Coffee
heatman101
Posted on Aug 07, 2011
Why cant I get a full cup of coffee
Brewing a Partial Cup
If the brewer is not brewing the full amount selected, it may be caused by the following:
  • The exit needle is clogged by coffee grounds or cocoa mix. Please refer to the K-Cup Holder cleaning instructions.
  • The brewer needs to be descaled. Please refer to the descaling instructions.
  • The removable water reservoir was removed during brewing. Place the water reservoir back onto the brewer and perform a cleansing brew without a K-Cup pack.
Jul 27, 2014 | Keurig B60 Coffee Maker
Mr. Coffee single serve brewer won't brew
First clean and please try again
Fill the reservoir with water.
Place your mug underneath the machine.
Add the K-Cup.
Choose your serving size.
Press the brew button to begin brewing.
Enjoy your delicious cup of coffee! .
Sep 25, 2013 | Mr. Coffee BVMC-KG6 Single Serve Coffee...
Gevalia 12 cup coffee maker slow brewing
The pipes are blocked with build up scale or water dirt. You can try to descale the machine by adding in the water half cup of lemon juice and brew it without coffee leave if for 20 min and the clean it by brew it with fresh water these will make a diference then try this again in a week.
May 16, 2012 | Gevalia CM-500 12 Cup Coffee Maker
Water is hot but it does not brew the coffee.
Hi. How do you know that the water is hot if it wont brew coffee. They have different boilers to do each function. Hot water function. steam function and brew funtion. Sounds to me that you have a clogged brew unit. If hot water is coming from the water outlet, the you do have a fault with the brewing side of things. Dazza REPAIRER
Sep 23, 2011 | Keurig Elite B40 Coffee Maker
My machine wont give me much water into the brewgroup tried another brewgroup and it is the same . Iyt takes about a minute to put thru one shot of coffee and we only get about 10mm of expresso in the cup...
Hi
If you push the scoop but don't put any coffee in the brew group, what happens? If it brews right (water comes out), then I would suspect that your coffee is too fine. Push the lever below the grinder on the right to the back (#7) and then try to brew again. Don't let it go all the way. Push the coffee button as soon as it starts to brew. Do this 3 times. The 4th time let it go and see if it will brew. If it doesn't I would need more information.
Aug 10, 2011 | Saeco Royal Cappuccino Espresso Machine
My Pot wont brew
mcdevito75 here, Your Mr. Coffee may need cleaning, here"s how, Fill the resovoir with white vinegar, cycle thru the machine 3 times, half way thru the 3rd time stop 1/2 way thru and turn off machine for 30 minutes, then recycle. After that rinse your Mr, Coffeee by cycleing thru fresh water each cycle takes another resovoir of fresh water to get rid of the vinegar. If this is not the problem, maybe the pump is shot. Contact Mr. Coffee by phone or online at Mr. Coffee.com or replace the machine.
Jul 09, 2010 | Mr. Coffee 072179228578 12 Cup Coffee...
The water is boiling, but wont flow into the filter??
Remove sprayhead and pour water into tank until it flows from the brew tube, then replace sprayhead and brew coffee.
Mar 14, 2010 | Bunn VPS Coffee Maker
Keurig b60 wont brew
The water reservoir tank probably isn't seated properly. Try wiggling the tank a bit and if that doesn't do the trick, completely remove the water reservoir and then replace it. Once it's seated properly, it should start drawing water and brew as designed. This seems to be a design flaw with this particular model, so periodic adjusting of the water reservoir may be necessary to ensure it is seated properly if your problem persists. Hope that helps! Best of luck...
Jan 25, 2010 | Keurig B60 Coffee Maker
Not brewing full pots of coffee
Check the in line water fliter. It may need to be changed.
You can try this also.
Put the brew basket in place with no coffee in it, put an empty decanter under the basket. take a full decanter and pour it in the water fill screen at the top of the unit. When the wtaer stops dripping and the unit is back up to temp, try a full brew cycle.
If it works OK, it just got low on water in the tank
Could be caused by a plugged up filter or lime scale build up.
Dec 28, 2009 | Bloomfield 8572 Coffee Maker
I have a Bunn model VPR, I can fill it up with water, plug it in, no water. turn it on, no water. it gets hot. I opened it up, there is no restriction. What coulf cause this?
This is a pour over unit.
You fill the tank with water, it heats the water in the tank.
When the water in the tank is at brewing temp, the lite should go out.
To brew coffee with this system, you put a filter in the brew funnel, put coffee in the filter. Place the brew funnel in the slide tabs to hold in place. put an empty decanter on the warming plate under the brew funnel. Then take one decanter of fresh water and pour it in the top of the brewer where it says "WATER ONLY" the coffee will begin brewing immediatly.
Oct 26, 2009 | Bunn VPR-Black (33200.0002) Coffee Maker
Keurig Mini B31 Plus Red Coffee Maker Logo
19 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
