Question about Amana NFW7300WW Washer
Hi, getting a burning smell from amana nfw7300ww00 washer. everything is spinning draining etc ok...
fanny
  • 146 Answers
SOURCE: amana ALW480DAW washer
Remove the front panel by loosening the two screws that hold it in place. Unhook the spring that puts tension on the tension pulley. Remove old/worn belt and replace with new belt. Very important that you use the correct size belt or the motor may be damaged and remember to hook the spring back for the tension pulley. The new belt has to go around the inside of the tension pulley.
Posted on Oct 31, 2007
SOURCE: Amana Model NPW5400TQ0 Washer
REPLACE THE TIMER OR Power control BOARD
Posted on Jan 31, 2008
  • 156 Answers
SOURCE: washer wont drain or spin just hums and then blows fuse
bad motor
Posted on Feb 25, 2008
SOURCE: Amana LWA50AW Washer Leaks!
Same problem here. It's coming from Shaft. Any instructions???
Posted on Apr 26, 2008
heatman101
  • 43501 Answers
SOURCE: Amana washer doesn't spin, model dlw330raw,
Here is a tip that will help you with that...
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
heatman101
Posted on Apr 26, 2010
Amana nfw7300ww00 wont drain. pump basket is clear pump runs but not pushing the water out. pump hose is clear
You may have blockage up b4 pump need to remove hose from outer tub and clean out or pump is bad and just spinning motor you hear prop is stripped
Jan 30, 2013 | Amana Washing Machines
When washer gets to spin cycle it will spin for 3 second then cut off, A few minutes later I hear a click inside the washing machine and it will try again
If there is smell that keeps on increasing then you must shut down the washer and remove power. Check on the motor , the capacitor to the motor and the main control panel. Since smell was noticed there can be ccomponents and so take care not to burn you fingers when you touch any part. Once this is identified you can remove and repace. if the heat was noticed on the motor,check for free movement of the spindle or it can be due to possible heavy load. Also check for inlet and drain valve pump to be faulty and have burning off the coils.
Nov 05, 2011 | Amana DLW330RA Top Load Washer
Maytag washer model # MAVT236AWW Ser # 11354800GV This thing will not wash or drain or spin. It will fill up with water. I have smelled a burning smell and smoke filled the back room. To me it has...
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Apr 20, 2011 | Maytag Washing Machines
Amana ALW880QAW doesn't spin and agitation is slow
winephan,
I could be the pump slowly ceazing causing the belt to slip which would give a burning smell.
Motors in those units, are well build...have a service guy in but DON"t say anything about the motor.. because they will say it because you mentioned it
I sounds like you pump
Jul 22, 2010 | Amana ALW880WH Top Load Washer
MOTOR SMELLS OF BURNT MOTOR WINDINGS. iS IT NORMAL
No, the pump works while spinning. The burnt smell is probably the belt, especially if your wife saw smoke. Did she put a big load in it at the time?
The belt will slip until the tub catches up with the motor. If there is a heavy load, it can burn the belt up. I would replace it. Make sure the idler pulley on the motor moves freely also.
http://www.partselect.com/MultiModels.aspx?ModelNum=ALW480DA&searchTerm=&RefineSearch=0
Jan 22, 2010 | Amana ALW480DA Top Load Washer
Kenmore Elite washer, model # 22942101 Spin cycle not working. The water drained out but the drum does not spin. It smells as if something burned out.
If the water drained out, then it sounds like the motor is still good.
I would check if the brake were failed in some manner since you smelled something, and if that is OK, then it's probably a failed gearbox.
Jan 27, 2009 | Kenmore 24032\24036 Top Load Washer
Empty washer tub wobbles during spining, plus burning smell
BOTTOM OF TRIANGULAR PLATE ARE 3 SKID PADS, USUALLY WHITE OR BROKEN HALF MOON SHAPE WHEN WORN OUT RESULTS IN THIS
Nov 30, 2008 | Kenmore 24032\24036 Top Load Washer
Amana NFW7300WW Washer Logo
Top Amana Washing Machines Experts
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
Are you an Amana Washing Machine Expert? Answer questions, earn points and help others
