Question about Mtd 2 Satge Snow Thrower 26"
After engine has been started the auger will not turn and starts smelling of burning rubber
    Sergeant:
  • 416 Answers
Something like ice in bottom of blower housing keeping it from turning
and belt is burning up
Posted on Oct 29, 2014
I have a 2004 Pontiac Aztek that will not start
Check your starter.mine burned up and it smoked and would not start.
Frank
Oct 06, 2014 | 2004 Pontiac Aztek
My mazda mpv wont turn over 1991 V6 and it smells like burnt rubber when trying to start it and it smelled liked that while running for a couple of days before it cut off
Unusual for a rubber smell could it be plastic? I would suggest possible a wiring loom that has either shorted and melted or has touched a hot component and melted. If you can smell burning with the electrics on but the engine off it is probably a shot and you may be able to trace with sight and smell with just the ignition switch in. This can cause issue with starting as it could be a feed to or from the starter, an imobiliser cable or just the ecu seeing an electrical fault and not allowing you to start. An unto electrician should be able to advise if you can't find it. You don't say if it is turning over but not firing or not turning over at all
hope this helps
Jul 05, 2014 | Cars & Trucks
Car heater blowing cold air and rubber burnning
If your heater is spraying a light mist through your vents it could be your heater coil. Mine did the same thing, smell rubber burning, then started a light mist through the vents. If you don't get that checked out, it could mess up your water pump and possibly your engine
Jun 22, 2014 | 2000 Chevrolet Cavalier
Auger will not engage
blocked or frozen blower inside of housing, move to warm area or chip out the ice
youre going to need a new belt after burning that one up
Feb 06, 2014 | Mtd 2 Satge Snow Thrower 26"
Smoking from under hood
A leak of some fluid, probably oil, dripping onto the exhaust. This smells terrible, and it only needs a drop or two.
Jan 22, 2014 | Honda Cars & Trucks
Why does my car smell like burning rubber under the hood after i drove it for a while?
could be anything from engine oil on the engine block burning as your driving and coming inside through the air flow from the outside vents, you can always click over the button and recirculate the interior air which will close the vents from pulling air from the motor. Might want to take it in and inspect it, if its not burning oil off the engine somewhere the only rubber would be your tires rubbing somewhere on the wheelwell or the frame and possible melting in that manor.
Feb 07, 2013 | 2003 Hyundai Tiburon
Compaq presario V3019US notebook pc has burning smell
Take out the battery and run just on external power, see if the smell goes away. If it does, check to see if there is a recall on that battery.
Jun 08, 2009 | Computers & Internet
Craftsman 247 88190 0 snow blower auger frozen
my auger and impeller froze too. fixed by clearing all snow, ice,stone build up behind impeller it works fine now.. hope that helps
Jan 19, 2009 | Ariens 34 In. Zoom Series Riding Mower
Refrigerator burning rubber smell when it tries to turn on
sounds like the relay on the compressors is getting hot and cutting the unit out, if the fridge is quite old it may well be the run windings gone short circuit in the compressor pot. The relay switches from start to run windings so may be firing the start circuit, switching over to a shorted run winding, and then getting hot and activating the thermal cutout and hence the burnig smell, plus the start and rapid shut down of the compressor.
Mar 19, 2008 | Refrigerators
Mtd 2 Satge Snow Thrower 26" Logo
195 people viewed this question
Top Mtd Garden Experts
Roland W VanLue
Roland W VanLue
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
