Question about Radio Shack (43-3829) Digital Answering Machine
Setting time of day and day of week on aswering machine
Problem #1. On model #DT300 the instructions under Set Time of Day # 3 does not change the day. The only place I can get the day/s to change is under the programming. What is wrong with it. I have...
Thank you for very clear question, and timer identification.
1) I don't have repair for defective timer.
http://waterheatertimer.org/Intermatic-timers-and-manuals.html#DT300
http://waterheatertimer.org/pdf/DT300-series-manual.pdf
2) Choose DT300 format
#3 says to press-and-hold CLOCK button until display shows 24H or 12H
Then release CLOCK button.
Next press HOUR button to select either 12H or 24H
This lets you choose am-pm format -or- choose military-time format where 11pm is 23
3) Set current time
Press-and-hold CLOCK button throughout whole current time setting.
Do not release CLOCK button until current time settings are finished.
Next, press HOUR button, and then MINUTE button, and then DAYS button until current hour, minute and day display.
If this step does not work, then timer has gone bad.
Replace with locally available Utilitec 155671 from Lowes or Westek TE06WHB from Target
http://waterheatertimer.org/Woods-timers-and-manuals.html#59377
4) How to set DT300 timer program for full week of operation.
Each program requires you to set program 1 ON time and program 1 OFF time
Be careful to avoid program conflicts and overlaps so timer works as expected.
For program 1 ON time, you press PROGRAM button until 1 and ON display.
Release Program button.
Then select hour, minute and days. In this case you want all days of week, so you keep pressing DAYs button until whole week displays: Mo Tu We Th Fr Sa Su
Then you set program 1 OFF time, you press PROGRAM button again until 1 and OFF display.
If you set ON time for all days of week, and OFF time for Tu Tuesday, then timer will not work correctly.
5) Read manual and add a comment for additional help
Aug 18, 2011 | Hardware & Accessories
My power was off 2 days. My GE phone shows
the time needs to be set on your answering machine. If you buttons on your base press and hold the day/check button to set the day of the week.
Most likely you don't have the base buttons on your model so on the hand set press the flash button to enter the answerer remote mode. Press the 8 key to enter time set menu. Set hour an dmin using num buttons. Set am/pm using caller id buttons. Press #pause to confirm the setting. Set day of week -/+ and #pause to set them.
Jan 31, 2010 | Uniden Cordless Phone
Answering machine keeps flashing CL
Your time needs set on your answering machine. If you have buttons on the top of your base, press and hold the day/check button to set the day of the week. Press and hold the hour button to set the hour. Press and hold the min button to set the min. If you don't have buttons on base, press flash button on handset to enter answerer remote mode. Press the 8 key to enter time set menu. Set hour and min using number buttons and set am/pm using caller id buttons. Press # pause button to confirm the setting.
Sep 26, 2009 | Uniden Cordless Phone
Phone doens't turn on : (
hi. i would seriously return this phone asap. this phone has a defective circuit board and battery bay. the core has failed prematurely. return for a free replacement asap.
May 23, 2009 | i-mate Jama 101 Smartphone
How do I set the time?
Press menu, press global setup, press set day and time. Use volume up/down key and right soft key to go from day of week, hour, minute and am/pm.
Feb 15, 2009 | Uniden TRU8885 Digital Answering Machine
At&T 1738 digital answering machine -- how to set time
Press and hold C until day of the week is announced. It will say Monday. If you don't want monday use annc/skip to go to the next day. When you get to the day you want hit set. This will save that day of the week for you. Then it will annouce hour, select the hour by doing the same thing and after you have the hour press the set button. Do this for the minutes too. Lastly is the year, if you've went to 2027 and it won't loop back to 2007 say, you can usually unplug it and it will reset the year back to the factory setting.
Oct 23, 2008 | AT&T 1738 Digital Answering Machine
Setting the time
You need to select the "set" button after each entry when setting the machine up so it will save your selection. (Day of the week then set, hour then set, minutes then set, year then set).
Oct 21, 2008 | AT&T 1738 Digital Answering Machine
Java stacks
Nice try! It's over a YEAR after your "deadline".
Find an upper-class student to give you one-on-one tutoring with your homework assignment.
Sep 10, 2008 | Computers & Internet
Radio Shack (43-3829) Digital Answering Machine Logo
22 people viewed this question
Top Radio Shack Lands Phones Experts
ismael castillo
Are you a Radio Shack Lands Phone Expert? Answer questions, earn points and help others
