Question about Plantronics M55 Bluetooth Headset
Plantronics m55 wont answer blackberry - Plantronics M55 Bluetooth Headset
2 Suggested Answers
ginko
  • 19396 Answers
SOURCE: I have a blackberry bold
Hi.
You can go to phone General Options menu and turn Auto Answer On or Off
Here procedure:
Auto answer when pulling phone out of the holster
1. From the Home screen, press the Send key.
2. Press the Menu key.
3. Click Options.
4. Click General Options.
5. Change the Auto Answer Calls field to Out Of Holster.
6. Press the Menu key.
7. Click Save.
You may also need to set this:
Stop ending calls when you insert your device in the holster
3. Click Options.
5. Change the Auto End Calls field to Never.
7. Click Save.
Built-in auto answer is very basic (on off only) If you need you can have better control of Auto answer if you install an application like this one.
If you repute my solution helpful, then please take some times to accept the solution. Providing good repair tips requires time and skills, and your feedback is important for us.
Regards.
Ginko.
Posted on Oct 22, 2010
M55 Volume
How is the battery charge? I will bet the battery is the little devil here.
Mar 18, 2014 | Plantronics M55 Bluetooth Headset
Plantronics voyager pro plus is connected and paired with blackberry tour. when a call is coming in, I cannot answer or hang up the phone from the bluetooth headset.
Make sure that your Blackberry's headset mode is activated. If the headset mode is turned on in the Blackberry menu and settings, you may also need to re-pair the headset to your phone to make sure that it has a good connection. Before running through the pairing process, be sure to totally delete the headset from the Blackberry's menu. You may want the headset turned off for this process.
Once you make your Blackberry discoverable, then put the Plantronics Voyager Pro headset into pairing mode by holding the power button until the headset flashes red and blue. Here is the link below for the Voyager Pro pairing instructions.
Plantronics Voyager Pro Pairing Instructions
Good luck from Headsets Direct!
Mar 09, 2011 | Plantronics Voyager PRO Bluetooth Headset
My new blackberry pearl no reconnize my plantronic 330
Test the headset on another phone, if it doesn't work on the other phone then your headset is defective. Connecting the headset to the blackberry is fairly simple. Just verify that the Blackberry's bluetooth connection is active and make sure the headset's connection is active as well. Select the plantronics headset within the Blackberry's bluetooth menu, it should be listed in the menu if the headset is working.
Mar 05, 2011 | Plantronics Explorer 330 Headset
How to pair blackberry storm to plantronics explorer 232
I am a little rusty on the PLantronics 232. but I believe to put it in pair mode, you have to press the volume up and the MFB (multi function button= button that answers and disconnects calls) at the same time. then pair your blackberry like normal. as I recal the pair code either 0000 of 9876
Feb 14, 2010 | RIM BlackBerry Storm 9530 Smartphone
Unable to pair bluetooth Plantronic 975 with BlackBerry 9700
On your Blackberry, navigate to Options,Bluetooth,Hit the cursor, Select Options, Set Discoverable to Yes, and save.
Make sure your Plantronic is in pairing mode.
On the Blackberry, hit the return key, add device, Search, Pllantronic will be listed on the blackberry as found. Select it, and add the password which by default is 0000.
Feb 10, 2010 | Cell Phones
Can't get new Blackberry 9630 to discover Plantronics 330. I've followed the pairing instructions for both instruments, but the Blackberry doesn't detect the headset no matter how close it is.
Once you make your BlackBerry discoverable, then put the Plantronics Explorer 330 into pairing mode by holding the call control button until the headset flashes red and blue. Here is the link below for the Explorer 320 user guide which has the pairing instructions, it will be the same for the 330.
Plantronics Explorer 320 User's Guide
Feb 02, 2010 | Plantronics Explorer 330 Headset
Answering blackberry with Plantronics ATT V521
I pull the battery from my blackberry and I can use the voice dialing again.
Jun 20, 2008 | GPS
Plantronics M55 Bluetooth Headset Logo
Top Plantronics Radio Communications Experts
LeAnna Mathews
LeAnna Mathews
Level 1 Expert
shaun taylor
Michael Vincent Cruz
Are you a Plantronics Radio Communication Expert? Answer questions, earn points and help others
