Question about Panasonic KX-FP121 Plain Paper Thermal Fax
Now power machine does not power on
Frequently power down
1. Power off the printer and computer and then disconnect the interface cable.
2. Power the computer back on.
3. Once the computer has booted, power the Brother machine back on.
- If the computer still reboots, restarts, shuts down, or enters hibernation mode, this problem is related to the power source for the Brother machine and computer. Continue to the next step.
4. If the Brother machine and computer are plugged into the same surge protector, uninterruptible power supply, or power backup device, power everything off.
5. Unplug the Brother machine power cord from the power device.
6. Plug the Brother machine power cord directly into a wall outlet or a different surge protector strip. You may need to use the reset button on the power device.
7. Power the Brother machine and computer back on.
Still having Problem Then follow Us For Brother Printer Support
Mar 23, 2014 | Brother MFC Office Equipment & Supplies
MFC-8710DW has no power
If your Brother machine does not appear to have power,then check whether or not the date and time appear on your Brother machine's LCD. If anything is displayed on your Brother machine's LCD, then it is most likely receiving power.If your Brother machine's LCD is blank, continue to Step 2.
Verify the Brother machine's power cord is connected securely to the power outlet. If you are using a surge protector, extension cord, or power switch, disconnect it and plug the Brother machine directly into the wall outlet.
Please note Brother strongly recommends that you connect your machine to a surge protector.Because To protect your investment against power surges and lightning,
In particular, we suggest that you use a surge protector that is compatible with both standard A.C. power cords and telephone line cords. Surge protectors equipped with telephone jacks will assist in insulating your machine from any power surge that might travel through a telephone line.
If the Brother machine is turned OFF, its LCD will be blank. Please make sure the Brother machine is powered ON by pressing and holding the On/Off or Power Save key. This key is located in the upper-right corner of the control panel.
If your Brother machine's LCD is still blank, connect it to a completely different, known working power outlet. If the Brother machine powers up, then the problem is related to the original outlet.
-OR-
Confirm the power outlet is working by plugging another known working device (a lamp, radio, etc.) directly into the same outlet. If the other device does not work, the problem is related to that power outlet. If a wall switch controls the outlet, verify that the switch is ON.
If your Brother machine still will not power on, please contact Brother Customer Service.
Or
Please Follow Us On Brother Printer Support
Jan 02, 2014 | Brother printerall-in-onelaser mfc8710dw
My Pfaff model 1211 machine won't come on. The power switch has been replaced but no light and no power for stitching
Sounds like a bad connection somewhere as the power seems intermittent. Consult your repair man to check the electrics.
Apr 06, 2017 | PfaFF Sewing Machines
Machine has no power, it is plugged in and the fuse has been changed, there is power to the socket,
IF there is no power going to the machine.possible fuse not properly mounted.Try to check using a tester if power is flowing to machine.From the socket,use an extension wire and check if power is flowing within the circuit if it is the problem is in the machine.Did the machine blown out?
Jun 21, 2011 | Washing Machines
Describe 102-372 code problem in m24 xerox work centre
Solution : Power OFF the Printer, Wait 45 Seconds, Then Power ON CAUTION: If the machine is powered OFF / powered ON, all information that is stored in the machine's memory may be erased.
NOTE: Before powering OFF, make sure that all copy or print jobs have completely finished. Never power OFF in the following instances:
  • While data is being received.
  • While jobs are being printed.
  • While jobs are being copied.
  • While a scan is being executed.
  1. Power OFF the machine. The power switch is located on the front right side of the machine under the Control Panel.
    NOTE: Before the machine is powered ON again make sure the Touch Screen is blank.
  2. Power ON the machine.
    NOTE: When the power is ON, a 'Please wait...' message will be displayed. This message indicates that the machine is warming up and cannot be used. After 45 seconds, the machine becomes ready for use.
    If the issue is not resolved repeat steps 1 and 2 a second time.
Mar 07, 2011 | Xerox WorkCentre M-24 Color Copier
Can the HP 1040 fax be cleaned to remove the two vertical lines that print? How? There is no glass to be cleaned and it does seem that the machine can easily taken apart?
This seems to a hardware problem. Resetting the machine fixes it most of the time.
There are many levels in reset, please try the the next level if the 1st did not fix.
Power Drain:
* Turn OFF the machine, disconnect the power cable from backside of the machine and from wall outlet.
* Press and hold the Power button for 60 seconds.
* Connect the cable and turn ON the machine.
Partial Reset
* Remove the power cable from back side of the machine while its ON.
* Press and hold "#" and "3" button, while holding them both insert the power cable and release the button after 10 seconds.
* If machine turns OFF, press power button to turn it ON.
Semi-Full reset
* Remove the ink cartridges.
* Press and hold "#" and "6" button, while holding them both insert the power cable and release the button after 10 seconds.
* Insert the ink cartridges.
NVM Reset
* Press and hold "OK" and "Cancel" button, while holding them both insert the power cable and release the button after 10 seconds.
Regards,
Riztech
Sep 25, 2010 | HP 1040 Plain Paper Inkjet Fax
Bestec ATX-300-12E Rev. D 300w E-Machine GTW Power Supply Part 100929 (ATX30012E) Power Supply: Do you have to use a emachine power supply...
No it is not neccassary to use a E-machine power supply if your previous one has become faulty. You can use any one as long as it has the required power rating.
May 18, 2010 | E-Machines Bestec ATX-300-12E Rev. D 300w...
I live overseas, and brought this sewing machine
its not transformer or machine problem at all.all the connections are also proper.its the power issue the required power to the machine is not getting from the electric outlet.just call the local electrician and check out the power supply voltage from the electric outlet.and power required to the machine which will be listed on the machine.if more power is required he will connect the over power IC and get the machine work.if less power is required he will connect the RESISTOR and lower the power to the machine and make it work.
Aug 30, 2009 | Simplicity Sewing Machines
Won't power up, after cleaning????
There is a switch that shuts the machine off when the door is open, Be sure machine is on and all components in and press the switch manually and see if it comes on. Some times the switch gets cocked to one side and the activator on the door misses it. Let me know
Sep 05, 2007 | Saeco Vienna SuperAutomatica Coffee...
Panasonic KX-FP121 Plain Paper Thermal Fax Logo
27 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
