Question about Kenmore 53632 / 53634 Side by Side Refrigerator
Frigerator not cooling freezer cooling but with some build up ice on the vent area
  • 399 Answers
SOURCE: the freezer has ice build up on vents
Cooling is poor For an overall understanding of how refrigerators should work, read about refrigerators in the How Things Work section of our website. A refrigerator or freezer that is cooling, but cooling poorly, may have a problem in one of several areas:
Evaporator coils
Condenser
Poor cooling is often the result of a heavy frost build-up on the evaporator coils or a condenser that is clogged with dust, lint, and dirt.
Evaporator coils Poor cooling is often the result of a heavy frost build-up on the evaporator coils. You can't see these coils without removing a panel on the inside of your freezer. A sure sign that there is a build-up is the presence of any frost or ice build-up on the inside walls, floor, or ceiling of the freezer. Such a frost build-up usually indicates a problem in the self-defrosting system or damaged door gaskets.
The refrigerator is supposed to self-defrost approximately four times in every 24 hour period. If one of the components in the self-defrosting system fails, the refrigerator continues to try to cool. Eventually, though, so much frost builds up on the evaporator coils that the circulating fan can't draw air over the coils. There may still be a small amount of cooling because the coils are icy, but with no air flow over the coils, cooling in the refrigerator compartment is quite limited.
Here's an inexpensive, though inconvenient, way to determine if the problem is with the self-defrosting system. Remove all of the perishable food from the refrigerator and freezer, turn the thermostat in the refrigerator to Off, and leave the doors open for 24 to 48 hours. (Be sure to have several towels ready in case the melting frost and ice causes the drip pan to overflow). This allows the refrigerator to defrost "manually." When the frost and ice build-up has completely melted away, turn the thermostat back to a normal setting. If the refrigerator then cools properly, it indicates a problem with one of three components in the self-defrosting system:
  • The defrost timer
  • The defrost thermostat (also called the bi-metal switch)
  • The defrost heater
If it still does not cool properly, there may be a problem with the refrigerant level or the compressor. You may need to consult with a qualified appliance repair technician to further diagnose the problem
Condenser Self-defrosting refrigerators all have a set of coils and a cooling fan, usually under the refrigerator, that need to be cleaned regularly. If these coils get coated with dust, dirt or lint, the refrigerator may not cool properly. The coils may appear to be a thin, black, wide radiator-like device behind the lower kick-panel. To clean them, disconnect the refrigerator from the power source, use a refrigerator condenser brush (see the Appliance Accessories section) and your vacuum cleaner to clean the coils of any lint, pet hair, etc. You may not be able to get to all of the condenser from the front, it may be necessary to clean the remainder of the condenser from the rear of the refrigerator.
also click the links below for more help
It's stopped completely
It's not cool
Cooling is poor
It's noisy
It leaks
The freezer compartment is icing up
The food in the refrigerator freezes
There's water dripping inside the refrigerator
The refrigerator never cycles off
The ice maker has a problem
There's an ice- or water-dispensing problem
Posted on Dec 06, 2008
tborn6
  • 700 Answers
SOURCE: Refrigerator doesn't defrost
theres a defrost control on the unit that is probebly bad. its in the upper right of the refrigerator aand depending on the unit is either solid state or mechanical
Posted on Mar 27, 2009
EllaWatson25
  • 725 Answers
SOURCE: Kenmore elite fridge. Bottom freezer ice builds
You have a bad defrost system on this unit, that's why you're freezing up. Call us with the model number and we'll get the correct part out to you right away. We hope to hear back from you soon.
Posted on Oct 10, 2009
  • 112 Answers
SOURCE: What if the refrigerator doesn't stay cool and the
The defrost mode has failed...replace the defrost element or the timer...it may also be low on gas.I bet its the element....easy and cheap to replace.
Posted on Jul 20, 2010
  • 5370 Answers
SOURCE: Freezer is building up ice
If its again building up ice, that means the unit is not defrosting.Its starting the cooling procedure, then while defrosting, its not working.The defrost assembly consists of three main parts.The defrost thermostat, the defrost heater and defrost board.Any of the one is not functioning.When thermostat sense the maximum cooling, it triggers the defrost heater to start heating and this defrosts the ice collected on the coils and the system works.Both thermostat and heater are controlled by defrost board.First the thermostat and defrost heater to be checked, if both check ok by meter and visually, then its defrost board causing the problem.You can get required parts from from online sites like:--- www.repairclinic.com or from searspartsdirect online site. ----------- Before that you can try manual defrost reset procedure.The manual defrost reset procedure is as follows : ---- First unplug the unit from main power outlet. Then empty whole unit completely. Then keep both the doors open. Wait for 24 hours. All the ice collected on the coils and in the freezer section will get melted. Clean the water from the sections. Then Connect the power cord of the unit to main power outlet after 24 hours/.Then set the temperature to normal in both fridge and freezer section. It will take near to 4 hours to get run in its proper cooling cycle. Then check, if the problem returns again. If the same problem occurs then it's defrost problem. ------------------ This should help.Thanks.Helpmech.
Posted on Apr 05, 2011
Refrigerator is warm. found ice packed in vents on frig side cleaned them out but now we noticed that the vents in the back of freezer are also packed with frozen ice build up. could this be the reason for...
That ice is the reason that the freezer is working but the refrigerator is not cooling. That ice is
blocking the vent that allows cool air to leave the freezer section andfall down into the refrigerator
section.
The fix is free: defrost the frig - pull the plug, and let that icce melt out of there, clean up the
wet mess, and turn the frig back on - problem solved.
Keep the vent area free of ice (and other blockages, like frozen peas covering over the vent), and
you'll keep the problem from recurring.
Aug 08, 2011 | Refrigerators
Our Kenmore frig is not cooling at all! The freezer is doing great however. What could be wrong with it and can we fix it ourselves to save money?
For one reason or another the cold air is not getting from the freezer compartment to the refrigerator side.
Possibilities Are There is ice build up in the vent. The vent is stuck closed or set at closed setting(freezer setting to cold) Defrost thermostat in freezer area not defrosting ice to allow air flow. This you can tell once you remove the back panel in the freezer you will see the inside full of ice.
May 26, 2011 | Kenmore Refrigerators
Ice is forming on the back of the freezer and the freezer and refrigerator side aren't cooling at all. Everything is defrosting.
If your able to transfer your food to another ref. your refrigerator needs to be defrost there is a product you can buy and spray in freezer,unplug unit and drain water or empty pan under frigerator,when starting back up make sure nothing is blocking cool vent so air can circulate,don't over pack.this may be why you get cold spots in certain area's.try this thanks
Jul 26, 2010 | Refrigerators
Ice keeps building up in freezer. Then the refrigerator stops cooling. You can get the ice off the vents in bottom back of freezer and it will start cooling again but only last a couple days before it...
Your freezer coil needs a good defrost. You are getting only a little bit of the ice off. It stops cooling because the ice acts like a insulator over the coil so it is unable to cool. Was to get this done is to empty it out and shut if off and leave the door open or maybe a hair dryer or even so warm water.
I hope this helps.
Apr 20, 2010 | Frigidaire FRT17G4B Top Freezer...
Not keeping food cold and popping noise
There is ice buildup in an area that you cannot see.
The interior wall may "bulge" a little if the ice builds up a lot.
1. You may have the cooling dial set too high (use lower numbers)
2. The blower vent into the fridge or freezer maybe blocked (move items away from vents inside)
3. Defrost the fridge. The water pan underneath the refrigerator may overflow.
If there is no "defrost" setting, unplug for an hour (don't open refrigerator or freezer during defrost)
Plug back in, food will not spoil.
Sep 21, 2009 | Haier Refrigerators
Water was leaking out of the freezer so I cleaned the ice build up on the freezer and now the frigerator is not cooling. I have a Kenmore side by side
check and make sure the timer is not stuck in defrost mode. if you can turn the timer by hand past the current point it should advance past the defrost cycle and begin cooling. The timer is usally found near the bottom of the refrig located in the front side.
Jul 07, 2009 | Kenmore 72102 / 72104
Top Freezer works fine but there is no ice building up in freezer the bottom fridge not cooling properlyThings are not as cold as they should be
Remove the back panel from the freezer to verify no ice behind the freezer panel. Look inside the air vent on the freezer panel for ice buildup. Make sure the freezer control is set to minimum not coldest freezer.. Make sure the freezer fan motor is working.
May 28, 2009 | Electrolux Refrigerators
Kitchenaid KSRA25IL Freezer working Fine - Refrigerator not
many times when a unit has a defrost problem the coils freeze up and do not allow the fresh food side to cool properly...check for a build up of ice on the inside back wall of the freezer compartment. if there is a build up of ice, you have a defrost problem. Also, check to make sure the evaporator fan in the freezer is blowing the air into the fresh food side.
Dec 26, 2008 | KitchenAid KSRS25IL Side by Side...
Open Questions:
Kenmore 53632 / 53634 Side by Side Refrigerator Logo
14 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
dweatherby
paulcarew
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
