Question about HP CP3525N Color LaserJet Printer
Color Laser Jet CP3525n 10.00.02 memory error
I received error code 52.00 on my HP printer, what does it mean?
Laser scanner start up error.. First of all need to find out which scanner faulty out of two..
Go to menu scroll to diagnosys, scroll to component test, scroll to scanner test....
If the cyan or black component tests showed a startup failure,
reconnect the connectors (J503) on the laser PCA and (J106) and J111) on DC controller PCA... replace the scanner
If the yellow or magenta component tests showed a startup failure, reconnect the connectors (J501) on the laser PCA and (J106)..Replace scanner..
Before starting better to download service manual to better understand the replacement..
Jul 29, 2015 | HP CP3525N Color LaserJet Printer
Hp color laser jet 5550dn shows error code 10.10.02 supply memory error
This error codes indicates that one of the toner cartridges you have installed does not contain a valid chip on it. If you recently changed a cartridge that is the likely culprit.
Feb 28, 2015 | HP Color LaserJet 5550dn Q3715A Workgroup...
HP COLOR LASER JET 2605 PRINTER 49 ERROR MSG DISPLAY SOLUTION
49 errors are most commonly caused when the printer receives a print job with commands it does not recognize. You can try updating the firmware as this will often resolve the error. Go to HP's website to find the most recent firmware, however this model is fairly old and likely the firmware update will be fairly old.
Sep 25, 2014 | HP Laserjet 2605dn Workgroup Laser Printer
Hp color laserjet cp2025 10.1000 supply memory error
Hp color laser jet cp2025 10.1000 supply memory error solution
May 30, 2012 | HP Office Equipment & Supplies
Error 58.04on hp cp3525n Support
Low voltage power supply has a problem.
If after power cycling the printer snd the error still appears,
then the Low Voltage supply will have to be replaced.
Nov 02, 2011 | HP CP3525N Color LaserJet Printer
Hello I have a problem with the work printer. It is a 3500 hp color laser jet and it is having a 10.10.00 supply memory error. I'm not sure what to do. Can you please help me?
10.10.00 SUPPLY MEMORY ERROR
Missing memory on supply
Black print cartridge
1. Open and close the front door.
2. Ensure the cartridges are fully seated.
3. Swap the cartridge for the color indicated with a cartridge in another slot to determine whether the error follows the cartridge or stays with the slot. If the error follows the cartridge, replace that cartridge, otherwise, continue with step 4.
4. Check the memory controller PCB contacts to the memory tag. Clean if dirty.
5. Reseat the memory controller PCB connector J201 and DC controller PCB connector J1025.
6. Defective memory controller PCB, replace the memory controller PCB.
7. Defective DC controller PCB, replace the DC controller PCB
Aug 25, 2011 | HP Color LaserJet 3500 Printer
I have owned numerous black & white HP laser printers and numerous Konica color laser printers. I purchased 2 HP Color Laserjet CP3525N printers new from HP 1.5 years ago. Now they both squeak loadly...
The squeaky wheel gets the grease! Yes it's a mechanical problem. The paper feed rollers and gears are loaded with paper dust and need to be cleaned or replaced.
Jul 26, 2011 | Dell Studio Xps 9100 Desktop Computer
I have two HP Color Laserjet CP3525n printers for my home office. I've owned many HP laser printers and color laser printers (Konica) and none of them have ever made load squeeking noises while...
These are not the quietist printer I have dealt with. Most of the squeeking noises we have encountered in servicing are related to the drums in the cartridges. Are these original cartridges or refills? If original and units are still under warranty, I would go after HP to deal with the noise. If you are using refilled or remanufactured cartridges, some noise is just part of the money saving tradeoff you make.
Jul 26, 2011 | HP CP3525N Color LaserJet Printer
I have an error code 58.04 on my hp color laser jet cp3525n can you help me out to reslove this error
8.4 suggests that engine power supply failure. The engine power supply mounts in the middle of the machine under where the toner cartridge resides. Lots of work to get to, I'm afraid. Need a service manual? Check out the link below. . .
http://www.image1products.com/techdocs/HP.htm
You could try cold reset:, if you can?
1. Turn printer off.
2. Hold the GO key
3. Turn printer on.
4. Continue to hold the GO key until the printer reads COLD RESET.
5. Release GO.
- INITIALIZING appears.
- Then, RESTORING FACTORY SETTING.
- Followed by OFFLINE.
6. Press the GO key to put back on line.
NOTE: A cold reset resets the HP Jetdirect card. Remove HP Jetdirect card before performing a cold reset
Apr 09, 2010 | Office Equipment & Supplies
Why black color smears when printing envelope but color prints fine?
Firstly are you using the cirrect cartridge ( genuine)? some compatible ones have less drying agent to help prevent clogging but take longer to dry.
Some papers are not suitable to laser printers, so ensure the paper you are using is recommended for use in a laser. This includes Photopaper
Jul 28, 2009 | HP CP3525N Color LaserJet Printer
HP CP3525N Color LaserJet Printer Logo
61 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
