Keyboard and touch pad are not functioning after it used more than an hour
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 68 Answers
Return it for a replacement or refund
Posted on May 06, 2014
moz205
  • 80 Answers
SOURCE: Keyboard inoperative
press and hold fn and press f11.it sounds like you activated the sticky keys
Posted on Dec 22, 2007
IB4G2008
  • 3587 Answers
SOURCE: 1 mgs
hmm...sounds like you need a new palm rest..but you can open up the unit, and check to see if the ribbon cables are still connected.
Posted on Mar 11, 2008
  • 16 Answers
SOURCE: keyboard is locked
Does the problem occur outside of the operating system? For example, can you use the keyboard to enter the BIOS on boot up or if you are using Microsoft Windows, can you press F8 on the keyboard thereby causing the Microsoft Windows Boot Menu to appear?
If the keyboard does not function outside of the operating system, the problem is a hardware problem. If that is the case, you may need to reseat the keyboard cable on the motherboard. Maybe the keyboard cable has come loose.
If the problem is hardware related and reseating the cable does not fix the problem, you may need to replace the keyboard.
Posted on May 20, 2009
  • 76 Answers
SOURCE: presario v3000 keyboard, touch pad and including
check in control panel .
that your touch pad and keybord option is not disable.
Also uninstall key bord and touch pad driver then reinstall.
Posted on Aug 23, 2009
rcw1962
  • 2571 Answers
SOURCE: Laptop Touch Pad will not work
if you plug usb keyboard onto your laptop it will probably turn the touch pad off.
If no other keyboard is attached there is usually a switch to turn off the touch pad.
also if you attach a mouse this may disable the touchpad so you dont move the mouse pointer when you are typing
Posted on Jul 10, 2010
How to fix keyboard and touch-pad problem, both are not working at all?
There is no fix for, just keyboards from time to time get fry. I will first blow the keyboard with air (canned or compressor) and test.
DIY keyboard replacement.
Buy a new one.
New eMachines E430 E525 E625 E627 E628 E630 E725 G430 G525 G625 G627 G630...
May 01, 2015 | Acer Emachines E725-4520 Laptop T4400 2.2g...
Which is an function key in keyboard
(FuNction key) A keyboard key that works like a shift key to activate a second function on a dual-purpose key. Commonly found on laptop keyboards, the Fn key is often used to control hardware functions such as screen brightness and speaker volume. The Fn key may also be found on extra small keyboards for desktop computers, typically for Page Up and Page Down, which are combined with Up Arrow and Down Arrow. See function key.
Feb 24, 2011 | Samsung Pleomax PKB-700B Keyboard
My touch pad mouse has stopped working - its not broken but maybe i used a function key??
hello press the function key and F7 key to reactivate your mouse pad if it is not broken other wise check your pointing devices in the control panel menu good luck
Dec 09, 2010 | E-Machines AAFQ50400000K0 Keyboard
I have an Acer Aspire 5517. Just the other day, my touchpad and keyboard stopped working. What do I do?
1 . Look for Fn function key - Most laptops have this special key Fn that is next to the Ctrl key on the keyboard. It should have a blue or green color, easy to find.
2 . Look for F1 to F12 functions keys, they are on the top row of the keypad. Look for one has an icon that looks like the touch pad, which is to control the touch pad of your laptop. It maybe F8 or F9 depends on each make of your laptop. These function keys also control the brightness, sound, wireless etc.
3 . Now hold down the Fn key and the F10 key to enable the touch pad, in this example, the Toshiba laptops. You press them again to disable it
4 . If none of the above works, plug in an USB mouse, then check into the Control Panel -> touch pad or mouse configurations. Also, check Device Manager if the touch pad driver is installed and working properly.
Thanks.Have a great day.
Oct 17, 2010 | Acer NSK8458AN Keyboard
A red light comes on my hp touchpad and I loose all control, and can't get it back. How do i re-gain controll of my touch pad?
It shows that you have accidentally shut off the touch pad. In the upper left corner of the touch pad is a dimple/circular depression. Tap it twice, the light will go out and normal touch pad function will return.
Oct 10, 2010 | HP P2360AA Keyboard/Mouse
Would like explanation of function key symbols I want to turn off the finger pad.
function key is Fn key on keyboard.
these keys might be in orange color
with the help of these keys you can control sound volume. you can adjust screen resolution like brightness .you can also turn off/on wireless features.These keys are like shorcuts keys to perform few functions on your laptop.
To turn off your the finger pad
You can use the Mouse Properties window to disable the touch pad and track stick or adjust their settings.
Open the Control Panel, and then click Mouse. For information about the Control Panel, see Windows Help and Support Center <findinfo.htm>.
In the Mouse Properties window:
Click the Device Select tab to disable the touch pad and track stick.
Click the Touch Pad tab to adjust touch pad and track stick settings.
Click OK to save the settings and close the window.
May 07, 2010 | Dell Latitude D610 Notebook
Lost my manual for chef condor integra oven - need to check auto functions and how to set them
For TOuch Control oven:
1. Press Finish Time touch pad
2.press ^ touch pad until clock displays the required am or pm finish time.
3. Press Cook Period touch pad.
4. Adjust the cooking time as in step 2, using up and down arrow touch pads. (hours and minutes needed to cook food)
5. Press Automatic touch pad.
Press Fan touch pad to select fan speed. Red indicating light shows normal speed.
7. Turn oven thermostat to desired setting.
8. Press Keep Warm touch pad if keep warm function is required at end of cooking. 9. At end of cooking time a buzzer will sound for 1 minute and the KEEP WARM cycle will now operate until the meal is ready to be served.
10. To cancel the Automatic cycle, press Manual touch pad and turn oven thermostat off.
For Multifunction oven:
1. Set time of day.
2. Turn Function switch to Finish. 0.00 will be displayed.
3. Turn display switch + to give the required am or pm finish time. (an illuminated bar in the bottom left corner indicates when the clock display is pm).
4. Turn Function switch to Cook then turn Display switch to + till desired cooking period is displayed (hours and minutes needed to cook food)
5. Turn Function switch to Auto. The automatic programme is now ready to use.
Turn upper oven thermostat to desired setting.
If keep warm function is required, turn function switch to Cook (optional)
Happy cooking!
Jun 14, 2009 | Ovens
Key pad mouse and touch pad not functioning
I have a laptop packard bell easy note a8730 and
laptop touch pad doesn't work properly @ get m
Dec 29, 2008 | Dell F3534 Touchpad
Touch pad failed.
Look along the top of the keyboard for an "f key" that shows a "touch pad" icon, IF you see it, press the "function key" (along the bottom of the keyboard) PLUS at the same time the "f key" (that you found along the top) and that should "toggle" the touch pad back on....
Also, IF you plug in a USB mouse that will allow you to move the cursor around--but the USB mouse doesn't fix your touch pad problem.
Hope this helps.
Oct 04, 2008 | Toshiba Satellite A65-S1065 Notebook
Computers & Internet Logo
12 people viewed this question
David Payne
David Payne
