Question about Amana ASD2575BRS 25.5 cu. ft. Side by Side Refrigerator with 3 Adjustable SpillSaver Glass Shelves, Adjustable Gallon Door Bins, Deli Drawer, Energy Star Qualified and External Ice/Water Dispenser: Stainless Steel
Base grille door won't close
Water filter door on the base grille opened by itself and will not close
Rear passenger door won't stay closed
Door latch on door itself is in closed position if it will not close at all. In this case, open door and pull outside handle hard to pop open door latch. If you have door opening at random, door latch needs replacing or door catch on body is loose.
Jul 29, 2012 | 2003 Chevrolet TrailBlazer
Where is the water filter on a 1997 side by side Roper
Do you have a manual for the refrigerator to check he same
Sep 08, 2008 | Roper RS22AQXKQ Side by Side Refrigerator
I have a front loading Bosch washing machine and it was working fine on Friday. On Saturday morning I went to take a load of clothes out and the door won't open - I am getting an E13 signal. My...
Hi!
The door lock uses electrical power to keep the door closed. Unplug the machine from electrical power and the lock will be released in a couple of minutes. Please be sure not to flood the room if the water level inside is above the door level.
Regarding the E13 error itself, it means too long draining time, and it can be caused commonly by something stuck in the drain filter. To get to this filter and clean it, you have to look at the lower part of the machine and remove the circular panel, then insert a little screwdriver into the hole and twist , the acces pannel will get open. Now twist the handle of the filter and pull it out. Now it can be cleaned. CAUTION: opening the filter will cause all water inside the machine to get out, so have some towels handy to avoid water to spread all over the floor.
Hope it helped,
Bogdan
Aug 28, 2011 | Bosch Washing Machines
Steps to change water filter
the water filter is located in the grill/kickplate under the doors on the freezer side,the steps are,
open freezer door
stoop down
grasp the black handle and rotate it in a counterclockwise direction 90degrees
pull out filter
remove black cap and reinstall black cap on new filter
push filter into housing
rotate it 90 degrees in a clockwise direction
close freezer door
Gene
Aug 07, 2011 | Whirlpool Refrigerators
Where the water filter whirlpool gold model no GS6SHEXMQ00 located? the last home owner lost the manual.
The base grille water filter cartridge is located below the freezer
compartment door. Depending on your model, you may have a
filter that is installed behind the base grille or a filter that
is installed through the base grille
This should be the right manual
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%202188772.pdf
Mar 11, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
How do i remove water filter under the side by side refrigerator
filter should be removede by turning filter counter clockwise,as if "unscrewing",so to speak.no need to shut off water or anything,just unscrew-tip:might be easier to remove by removing ref. grill. ref. grill removes easier by doing this w/ both doors open
Mar 10, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Sounds stupid, where is the water filter
it is in the grill at the bottom of the front of your unit. you can see it when you open the freezer door.
start by removing the lower plastic grill by grabbing the grill and twisting outwards on it.
then the filter can be removed by turning the filter, top to the right.
when you put the new filter in in place, it should sound like water is running into the unit.
then replace the grill.
Jan 07, 2010 | Refrigerators
How do I take out the water filter?
Found at Kitchen Aid website, Good luck
Changing the Water Filter
1.
Press the eject button to release the filter from the base grille.
2. Pull the filter straight out.
3. Turn the cap counterclockwise to remove it from the filter.
IMPORTANT: Do not discard the cap. It is part of your
refrigerator. Keep the cap to use with the replacement filter.
4. Align the ridge on the cap with the arrow on the new filter and
turn the cap until it snaps into place.
NOTE: You can run the dispenser without a filter. Your water
will not be filtered. Simply insert the cap all of the way into the
base grille and rotate the cap until it is firmly in place.
5. Remove the protective covers from the O-rings.
6. Push the filter into the base grille. The eject button will pop
back out when the filter is fully engaged.
7. Flush the water system. See “Water and Ice Dispensers.”
Jun 30, 2009 | KitchenAid Superba KSCS23IN Side by Side...
Can't locate the water filter. water has a bad taste
The base grille water filter is located below the freezer
compartment door. Depending on your model, you may have a filter that is installed behind the base grille or a filter that is installed through the base grille.
May 23, 2009 | Kenmore Refrigerators
The ice maker in my whirlpool gold refrigerator Model No, GR2FHTXTBOO, is not working.
Hello jitkagardner,
Welcome
You said, The ice maker in my whirlpool gold refrigerator Model No, GR2FHTXTBOO, is not working.
How old is the fridge?
When have you last changed the water filter.
Should be down below at the front grille!
Try these tasks!
If the ice maker is not producing ice or not enough ice
Refrigerator connected to a water supply and the supply
shutoff valve turned on? Connect refrigerator to water
supply and turn water shutoff valve fully open.
• Kink in the water source line? A kink in the line can reduce
water flow. Straighten the water source line.
• Ice maker turned on? Make sure wire shutoff arm or switch
(depending on model) is in the ON position.
• New installation? Wait 24 hours after ice maker installation
for ice production to begin. Wait 72 hours for full ice
production.
• Freezer door closed completely? Firmly close the freezer
compartment door. If the freezer compartment door will not
close all the way, see "The doors will not close completely."
• Large amount of ice recently removed? Allow 24 hours for
ice maker to produce more ice.
• Ice cube jammed in the ice maker ejector arm?
Remove ice from the ejector arm with a plastic utensil.
• Water filter installed on the refrigerator? Remove filter and
operate ice maker. If ice volume improves, then the filter may
be clogged or incorrectly installed. Replace filter or reinstall it
correctly.
• Reverse osmosis water filtration system connected to
your cold water supply? This can decrease water pressure.
Let me know how it goes!
Huuum
Please remember to leave a rating!
Oct 21, 2008 | Refrigerators
Amana ASD2575BRS 25.5 cu. ft. Side by Side Refrigerator with 3 Adjustable SpillSaver Glass Shelves, Adjustable Gallon Door Bins, Deli Drawer, Energy Star Qualified and External Ice/Water Dispenser: Stainless Steel Logo
768 people viewed this question
Top Amana Water Dispensing & Filtration Experts
ray gallant
Bill Boyd
Tom Chichester
Are you an Amana Water Dispensing and Filtration Expert? Answer questions, earn points and help others
