Question about Sony Televison & Video
My tv screen is dark and blurry on the left side as you look at it.
After 30 minutes I can shut off the tv and turn back on and I get a good screen
  • 1694 Answers
SOURCE: Blurry on one side of screen. Green and purple shadows
Convergence IC's should be replaced before any alignment is
attempted ....part # STK392-560....You need two......mount
to large heatsink...............T.
Posted on Dec 04, 2007
C13295
  • 128 Answers
SOURCE: Blurry on left side of the screen. Shadowing in different colors.
Try this website. It is the Hitachi support website. http://www.hitachi.com/GlobalSupport/ContactUs?form_type=global_support Hope this helps :)
Posted on Jan 28, 2008
SOURCE: HITACHI 51F59A PROJECTION COLOR TV
we have hitachi 51 inc projection tv model 51f59a for 2 yrs. we got problem adjusting the colors the screen is reddish. pls solve this .
Posted on Nov 23, 2008
Axle80
  • 73 Answers
SOURCE: TV shuts itself off
Something is overheating or you've got leaking capacitors somewhere. I'd start with the ballast board. Its directly underneath the lamp housing. You can access and remove it through the lamp door. Replace that and if that doesn't solve the problem, comment again, and we'll move on to more complicated repairs. You haven't noticed any weird noises, humming, screeching or similar oddities from the set? Turn the set on with the lamp door open and bypass the switch with a piece of tape, if you hear something like a hum, you may have a bad color wheel motor.
Posted on Mar 23, 2009
  • 64 Answers
SOURCE: Our Mitsubishi WD 52525 goes to blue screen and shuts off.
It sounds like you TV is overheating and the video is suffering and the lamp is overheating as well. Also, if your TV is over 2-3 years old, the mirrors (behind and below the big front screen) desperately need to be cleaned. Clean all filters and fans as well. (Look on side and behind the unit). Is the TV in a "hot" environment and/or dirty environment? DLP TV's are NOT sealed units. They need to be cleaned every few years to work well to have a good, clear, bright picture.
Posted on Aug 01, 2009
Dark Screen
It sounds like a back-light problem. Check all the CCFL back-lights.
May 08, 2013 | Samsung LN52a750R1FXZA
Sony KDL-52WL130 Dark and blurry on left side of screen . Also vertical lines on left side of screen
The TV requires thorough servicing and this might require attention by a qualified service technician.
Jul 12, 2012 | Televison & Video
42" sony projection with blurry picture
Remove front bottm panel and behind it should be the Focus/Screen control block replace it.
Mats 1-800-628-1118
May 09, 2010 | Sony KP-51HW40 51" Rear Projection...
Jun 24, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Picture is dim and blurry
The screen probably needs to be degaussed, which will require either a degausser or a technician. Try turning the television off, and then unplugging it from the wall outlet. Then replug after 30 seconds and turn it back on. Also, try plugging any cables from a cable or satellite box into another set of in-ports on the back. If the problem persists, the screen needs to be degaussed.
Feb 22, 2008 | Philips 51PW9303 51" Rear Projection...
Screen goes from blurry to clear to blurry
The first thing to check is for loose conections,the problem is related to the high voltage but it can start in the main board with one component loose,when the high voltage is developed it goes to what is call the distributor block,a lot of sets have the focus and screen controls coming out of this block for each picture tube,this block might be bad but before we go to him we need to check everything is solid in the main board.If you are familiar with electronics you can remove the back cover and tap the chassis with a wooden or rubber handle to see if the set reacts,if it does you need to be atentive what area makes it react and flip the board to do some resoldering,If you are not too familiar with tv service you need the assistance from a servicer.Let Us know how it goes or if you need more information.
Oct 27, 2006 | Zenith H32G48S TV
Televison & Video Logo
12 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
