Question about Peg Perego Triplette Stroller
How to take out the big one
Cannot figure out how to remove the big bed-like one from frame
How do you remove the bed of a 98' Chevy S10 step
disconnect all electrical connections between the frame and box, disconnect the fuel filler hose from the box or the fuel tank, there are 4-6 bolts that mount the truck bed to the frame to remove. move truck bed.
Sep 25, 2014 | Cars & Trucks
How do i remove the truck bed from 2005 chevrolet avalanch
disconnect all electrical wiring that is attached to the bed then disconnect the fuel filler tube. there is 4 bolts that hold the bed to the frame that you will have to remove. some trucks the bolts are removed from inside the bed and others from under the bed though the frame. then get help to pickup the bed and turn it to gain access to the pump or remove the bed from the frame.
Sep 19, 2014 | 2005 Chevrolet Avalanche
Cannot figure out the assembly of Mantua IPK170 bedframe
If you go to www.Mantua.com you may be able to download instructions on assembly of your bed frame. If not try emailing customer support and ask them to send you a link to a download for assembling your bed frame or, perhaps they can send you the attachment of a assembly instructions .Be sure to include what you want instructions for.
Jul 31, 2010 | Mantua Toys
Converting Simplicity Ellis crib to full size bed with headboard
Did you ever figure out how to do this? I am having the same challenge.
Jan 17, 2010 | Simplicity for Children 4-in-1 Convertible...
2000 Chevy Silverado 2500 6.0 litre fuel pump
lifting the truck bed off the frame works best if you dont have a lift..take the fuel neck loose from bed and remove bolts holding bed to frame from the drivers side..loosen the bolts on passenger side..raise the bed on drivers side while watching bumper to bed clearance on passenger side.. you should get enough clearance to remove fuel pump from tank
Dec 26, 2009 | 2000 Chevrolet Silverado
How do u remove the bed from a 2001 chevy?
get under the bed you have 4 to 6 bolts that run on each corner of the bed to frame rails , look thru holes in frame for big bolt heads to remove the bed, easy , hope this helps you ,thanks robert b.
Jun 07, 2009 | 2001 Chevrolet Silverado 1500
Need instructions on how to convert my aspen simplicity crib into a toddler bed?
i think this is the same crib that i have. I remove the front rail that slides up and down, then i removed the plastic contraptions that allow it to slid up and down on. I then attached the bed frame on the lowest setting, by first fastening the two back ends first. Then I attached the toddler rails to the bottom of the bed frame and then once they where on I attached the bed frame to the crib with the rails and the brackets for the bed frame pressed together. I hope i explained it so that i makes sense.
Mar 14, 2009 | Simplicity for Children Aspen 3 in 1...
Fixing a bed togather
Here is a link to the instructions. If this isn't the exact bed go to their website and find the correct one and you'll be able to find the instructions there.
http://www.littletikes.com/pdf/7527.pdf
Mar 10, 2009 | Little Tikes Sports Car Bed Frame Police...
Peg Perego Triplette Stroller Logo
21 people viewed this question
Top Peg Perego Baby Gear Experts
Jennifer Rock
Jennifer Rock
romney2012
Are you a Peg Perego Baby Gear Expert? Answer questions, earn points and help others
