Question about Metra 99-7503 2003-2005 Mazda 6 Installation Stereo Kit
Location of 2003 Mazda 6 turn signal flasher relay
Turn signal and hazard flashers not working. fuse OK. Passenger side flashers stay on.
2 Suggested Answers
auto_elecric
  • 17 Answers
SOURCE: replacing turning signal flasher on 2004 intrepid
Steering wheel end airbag have to be removed,
Posted on Nov 27, 2012
Hazard flasher on 1993 mazda mx6
IT IS LOCATED AT--BEHIND LEFT SIDE OF DASH IN RELAY BOX. (TURN SIGNAL AND HAZART FLASHER UNIT ) SAME FOR BOTH. PUT YOUR TURN SIGNAL ON AND TOUCH THE RELAYS IN THAT AREA YOUR ARE GOING TO FEEL WICH ONE IS WORKING, (DEFECTIVE FLASHER OR HAZARD SWITCH. )
Oct 12, 2017 | 1993 Mazda MX-6
1999 jeep grand cherokee - rear driver turn signal and brake light don't work. flasher, back up and running light works. everything works when lens assembly is plugged into the passenger side. can...
Check this diagram (click over pic for zoom)...
Check the postion F4 / 15 Amp ( Lt. Blue ) Flasher, hazard switch (see Junction Block diagram above for location of turn signal Flasher relay - Mopar p/n 4686094)
Repair tip: WJ flasher repair.
Hope helps.
Apr 16, 2011 | Jeep Grand Cherokee Cars & Trucks
Turn signals not working but hazards do
Hi, your car has separate flasher relays for the turns and the hazards. Replace the turn flasher, Front seating area, driver side, under dash, mounted on passenger side of steering column.
Thanks for using FixYa.
Mar 17, 2011 | 1994 Pontiac Grand Prix
My turn signals and emergency flashers quit and the signal fuse is good Help?
okay...the signal fuse powers horns, dash indicator lights (neutral, OD etc)
so all that is working fine?
the other common items are the wiring to the bulbs and the bulbs....doubt all 4 failed at once.
Looking at my wiring diagram, it looks like the system was designed so the hazard circuit and the turn signal circuit cannot be used at the same time, It appears that the common component to accomplish this is the Hazard Relay (not Hazard Flasher Relay). Basically the power to your Turn Signal flasher is fed from the Hazard Relay if your Hazard Switch is off, and when the Hazard Switch is ON, the Hazard Relay switches and cuts off power supply to Turn Signal flasher, and feeds the 4 turn signals for 4 way flashing.
So I suspect possibly either your connector at the Hazard Relay is loose, or the relay has failed
I'll try to find location for you, looking for a 6 wire connector with the following colours
Brown/White, Brown, Brown/Red, Brown/Green, Chocolate, Dark Green.
It may be under the right side cover....there is one flasher relay there...but will do some research.
You realize the Venture has a 5 year warranty?
Mar 14, 2011 | 2008 Yamaha Royal Star Venture
No turn signals or hazards???
Check the FLASHER unit; the turn signal flasher is mounted in a clip on the right side of the steering column support bracket. The hazard flasher is located in the component center, under the instrument panel, on the right side. Replace the flasher by unplugging the old one and plugging in the new one.
Hazard flasher -->> The Flasher is located: Front seating area, passenger side, under dash, below glove compartment, mounted in fuse panel
Turn signal -->> The Flasher is located: Front seating area, driver side, under dash, mounted on passenger side of steering column
Good luck (remember comment and rated this).
Apr 23, 2010 | 1995 Chevrolet Monte Carlo
Where is the turn signal relay, hazard relay, and flasher for a 2003 Ford F150? My turn signals do not work (inside or outside), but 3 out of 4 outside lights work when the hazards are on, but with only 1...
It is not the flasher if the hazards work, it is 1 flasher for both turn signals and the hazard lamps. It is in a relay block ( along with the blower motor relay ) under the dash, about in line with the steering wheel column ).
Try tilting the steering wheel all the way up, and test again.
The other quick test is to cycle the hazard switch a few times, to see if it cleans the contacts for the turn signal on the MFS,
Apr 01, 2010 | 2003 Ford F150 Regular Cab
What is the location of the electronic flasher relay on a 95 Oldsmobile Achieva
Your Olds has 2 flasher relays. One for the turn signals and one for the hazard lights.
The turn signal flasher relay is located on the driver's side, under the dash, mounted on the steering column.
The hazard flasher relay is located driver's side, under dash, driver's side of steering column, mounted on fuse panel.
Mar 28, 2010 | 1995 Oldsmobile Achieva
Metra 99-7503 2003-2005 Mazda 6 Installation Stereo Kit Logo
51 people viewed this question
Top Metra Car Audio & Video Experts
xxxxxx xxx
Are you a Metra Car Audio and Video Expert? Answer questions, earn points and help others
