Question about Philips GoGear HDD6330 MP3 Player
Ma 4gb go gear is not working
It was working perfectly till one day t whole thing went off.... now i cant switch it on... while charging is t only time t screen flashes but it goes on to a never ending 'loading' screen. tats it... please help......
  • 8,596 Answers
Make sure you back up all songs on the GoGear before attempting this solution.
1) Back up all files on the GoGear
2) Open up Philips Device Manager (Start --> All Programs --> Philips)
3) Click on the Repair Tab, and look for a msg that says connect the player while holding the volume + button
4) Disconnect the GoGear from the computer and turn the GoGear off - hold in the volume + button and continue to hold it as you reconnect the GoGear to the computer; after holding the volume + button for up to 20 or 30 seconds, a window will open up saying that your device is being repaired (now you can let go of the volume + button); after the repair is successfully complete, your GoGear will be good as new
Now you can do the firmware upgrade that will prevent this problem from occuring in the future. Open up Philips Device Manager and click the Update tab. This problem was caused because most GoGear's were designed for Windows XP with Media Player 10 (which is no longer the latest standard).
-Tha Mp3 Doctor
Posted on Feb 11, 2008
My DS Lite wont charge! Help!
Try another charger, yours may be faulty. Alternatively,the battery may need replacing as it is no longer holding charge, these can be obtained very inexpensively from Ebay and you will just need a small cross head screwdriver to remove the cover on the back of the DS lite, then tap the unit in your hand to dislodge and remove the battery.
Dec 22, 2013 | Nintendo DS Lite Console
Check fluid level. In park. With engine running. If fluid level is ok it maybe internal trans.
Feb 22, 2013 | 1999 Ford F150 Regular Cab
I have a 4GB Craig MP4 player and earlier today it was working perfectly fine. It turned off automatically and later I went to turn it back on to listen to it and it won't turn on or charge when connected...
Quite often there is a fault with USB charging. Do two things to confirm its not totally broken. First try another USB charger. Second and better- charge from a power outlet at home.
Mar 09, 2011 | Audio Players & Recorders
My van has an old security system it dosnt work since tow three years.Now a days my vehicle starts it remain one or two days works whenever I start but some time it didnt start. I left for whole night...
I agree with the mechanic..
I would have someone remove the security system all together from the van...
You dont mention what model van ... or year... so it's hard to discern what to do from this point.
Oct 06, 2010 | Vehicle Parts & Accessories
My philips go gear 4GB wont turn on even though it is charged
There is a small hole on the side of the player through which you need to use a small office pin to reset. press it for some 5 secs and release. the playerr would have hung up earlier and is now reset. you can now switch it on. Hope this clears. Good day
Jul 02, 2010 | Philips Electronics - Others
2002 suziki XL-7 will not start
The starter solenoid has been known to stick on these cars. If you jump start the extra battery will free it up till next time (right) If this is the case replace solenoid or the whole starter. You can also bang the solenoid with a wooden broom handle if it will reach the starter not sure you can see if from above. Ignition switch would be my second item to check closer. But starter should probably fix it. When you say battery is fully charged it should have a voltage also around 12.8.
Sep 13, 2009 | 2002 Suzuki XL-7
Cant start my computer. Only the power on light is showing
battery may be failing and will not work till it is charged enough to may have to replace the battery. or the charger or both.
Feb 21, 2009 | HP 2133 Notebook PC
My phone in salt water.
Salt water is corrosive and even if you do get them to work again they wont work a new phone...and ipod and camera...
Jun 28, 2008 | LG enV VX9900 Cellular Phone
Creative ZEN 4GB
ive got the same thing
basicly i cant turn it on rebuild dont work and my comp cant find mine but my brothers works perfectly
Apr 17, 2008 | Creative Labs Zen Digital Media Player
Orange and green light flash
The flashing battery light is an indication that the system is attempting to charge the battery. The orange light indicates a problem charging one of the battery cells. This usually means that the battery either needs to be recalibrated or replaced. To recalibrate the battery just use the system until the battery is dead, then recharge and repeat the process twice, after which time the battery should be recalibrated. If this doesn’t fix the flashing orange light then the battery may need to be replaced.
hope this helps
Jan 07, 2008 | Dell Latitude D600 Notebook
Philips GoGear HDD6330 MP3 Player Logo
76 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
