Question about Pool & Spa
Hurlcon pump troubleshooting
Hi my bx pool pump does not seem to work efficiently and I also noticed the gauge on the cartridge filter does not work properly either. Not sure what it could be? Any help is appreciated
  • 20 Answers
SOURCE: the pump/filter combo for my easy set pool doesnt
Prime the pump by filling with water BEFORE youturn it on.
Posted on May 07, 2009
SOURCE: Need help installing filter pump model 635 for my swimming pool
Just go to the Intex Corp link below. Choose the appropriate pool and/or pump. At the bottom of the page you will see a link for instructional manuals and videos. Hope that helps.
http://www.intexstore.com/ProductList.aspx?categoryID=30
Oh yeah, by the way...you may want to start looking around for another pump for that pool if you plan on using it more than a year. I have had mine for 3 years and I spend more time in the pool vacumming than I do in the house!! The 635 pump is not strong enough for the 18x52 pool nor does it filter out fine silt and sand...it sucks it up and spits it right back into the pool thru the return. Good luck to you
Posted on May 22, 2009
There is an air/suction leak on the inlet side of the pump or, if this is an above ground pool, the pump is not set below the level of the pool.
Posted on May 31, 2009
  • 16 Answers
SOURCE: I have a intex 637R pump and the problem is it doe...
I have the same problem. I've replaced the filter and made sure nothing was blocking the inlet or outlet but it barely pumps. I also bled the air out.
Posted on Jun 27, 2010
jharwell668
  • 640 Answers
SOURCE: Pool Pump - keeps getting air
It sounds like you might not be getting enough suction on your pool filter. I would check all of the hose connections for cracks, loose fittings, etc. If you are getting any extra air, it will cause your pressure to decrease.
Posted on Sep 08, 2010
My hurlcon CX 240 pool pump has good return pressure but very low suction from the pool and wont opperate the kreepy krawly, Do I need a new pump? Thanks. Richard
no
what you may have is a blocked outlet--filter --tap incorrectly set
good pressure but no suction indicates that the pump is pumping but the pumped water has nowhere to go
Jan 05, 2017 | Pool & Spa
Hurlcon sand pump seems to pump water out of the pool. It's like it's on backflush all the time. Anyone had similar problems?
Either your Filters Valve setting is in the wrong position, or your filters valve needs to be rebuilt or replaced. (valve diverter or and/or valve gasket)
Jan 24, 2016 | Pool & Spa
Hurlcon ctx 2hp pump troubleshoot
maqke sure the intake union is tight also check to see if seal slipped use filter lube
Jul 02, 2014 | Pool & Spa
We have a hurlcon GX 600 cartridge filter that has suddenly stopped working and there is no flow...
have you cleaned filters lately? if not take out and clean filters soak in bucket with 4 parts water to 1 part muriatic acid if you have take filters out of canister put back together without filters try them to see if you have flow if not sounds like pump plugged something might be caught in impeller
Jan 26, 2014 | Pool & Spa
It sounds like you have a suction leak. What's odd it that it works for 2 hours then loses prime. I don't think it would be related to the air temperature. Check out the pump basket lid o-ring to make sure it is in good condition and properly lubed (this is a very common cause of suction problems).
Also check your water level to make sure it's high enough. Any valves on the suction side of the pump may also be suspect. Good luck with it.
Jan 05, 2014 | Pool & Spa
motor overheating replace pump
May 21, 2017 | Pool & Spa
Hurlcon cx240
bad sensor and cell calsified need to super shock poool
Mar 19, 2017 | Pool & Spa
I have a Sta-Rite pool filter. In the start up procedure, you are supposed to bleed the air until a steady stream of water flows from the air release valve. Although I have confirmed that everything is...
Hi sstanl, Is your pump output or flow normal back to pool? if there is no water flowing through system you will get no expulsion of air or pressure reading on gauge. If pump is working then you probably have a clogged air release valve and maybe a clogged gauge. Just remove air relief assembly from filter top, remove gauge and clear any obstructions in parts. You should easily be able to blow air thru assy with gauge removed. Teflon tape the components and snug them back in their places. restart your pump and voila! air will come out when prime is established.
Apr 23, 2009 | Sta Rite Sta - Rite Mod Media 450 Sq Ft...
My pool pump pumps water, return is low pressure
fix any air leaks on suction side of pump. Check valve positions.
Clean filters...may need to replace cartridges in cartridge filter, or take out D.E. grid assembly and clean it on a D.E. filter, or change sand in a sand filter...
Mar 26, 2009 | Pool & Spa
Pool & Spa Logo
131 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
