Question about Sew Smart Compact Cordless 17390B Sewing Machine
Foot pedal will not make machine work. This machine has an electric cord, so does it need batteries too?
Pneumatic air foot petal
If the machine won't work with two pedals that are good then the problem isn't the foot pedal. Does the light turn on? If this is functional then you know there is "electricity" attached to it. Since both pedals aren't functional you will have to have the motor and connecting cord (inside machine) to see which is the problem. By the way; if the problem is the cord inside the machine you may not want to plug it in. You stand a chance of getting shocked. Have it checked for safety.
Sep 27, 2016 | Sewing Machines
NO RESULT WHEN PRESSING THE FOOT PEDAL
Do you have electrical power to your sewing machine?
Are both ends of the Foot Pedal cord plugged in correctly?
If the above check out, you need a Service.
Mar 05, 2015 | Sewing Machines
Brother serger slows down
it could be the motor or the power cord or the foot pedal,
check to make sure the power cord and the
foot pedal are connected correctly to the machine.if they are
then the machine and power cord and foot pedal need to be
checked
Nov 13, 2012 | Brother 1034D Serger Sewing Machine
The machine is very slow and sometimes stops as it did not have power.
if it's is battery powered then the battery's need to be changed
if the sewing machine is using electricity, the it's possible that the
power cord or foot pedal or motor need to be checked to see if some
thing is wrong with them.
Nov 12, 2012 | Euro-Pro Shark 80 - 7133
I have a Kenmore sewing machine Model 158, 1792280. The foot pedal is not working well; I was sewing normally and when I finished, I removed my foot from the foot pedal but the machine continue sewing. I...
Buy a new foot pedal for it, probably one of the electrical components inside the foot has failed.
There are Kenmore footcontrols for sale on www.sewingpartsonline.com. You could email them to check its right for your model if it isn't listed.
Obviously I'm assuming that you are in USA with 110 Voltage and that is what your machine is. If not and your country is 220V, you would need to source it from a reseller in your own country or another with the same voltage.
Jun 12, 2011 | Sewing Machines
Foot pedal does not function on pfaff 7550
my pfaff sewing machine footpedal sticks
May 24, 2009 | PfaFF Creative 7570
Sew Smart Compact Cordless 17390B Sewing Machine Logo
12 people viewed this question
Top Sew Smart Sewing Machines Experts
ray gallant
R.A. Ellis
R.A. Ellis
Debbie
Are you a Sew Smart Sewing Machine Expert? Answer questions, earn points and help others
