Question about Dell Latitude L400 Notebook
Can I install windows XP on a dell latitude L400 running Windows 2000 professional
    Sergeant:
  • Dell Expert
  • 464 Answers
Yes you can
Posted on May 02, 2014
  • 272 Answers
SOURCE: Dell notebook L400 Will not boot
follow these stapes :) ( click here )
Posted on May 27, 2009
bob_computer
  • 3153 Answers
SOURCE: My Dell Latitude D600 keeps freezing after about
Could be a couple of things.
Its usually an indication of a fault on the hard drive but in most cases it can be fixed and cleared.
If you get a copy of
BARTPE
http://www.nu2.nu/pebuilder/intro/
or
UBCD
http://www.ultimatebootcd.com/
UBCD may be your best option. Set your laptop to boot from them and run the chkdsk utility from there on your hard drive to see if that can fix the errors. UBCD also has some other hard disk checking utils.
There is also a copy of chkdsk on a proper copy of windows xp so if you have one and can boot from that then you can also check out the hard-disk from there.
You may find that you end up with come "bad blocks" too many of these indicate a failing drive. If so you should consider replacement while you still have the ability to clone your old drive onto a newer (larger) one. laptop drives are at about their cheapest right now and it would be a good opportunity to upgrade it.
It is not difficult to do.
Just the odd few could mean the laptop took a small bump while being used and it quite feasible that you could continue using it for a long time
Also get a can of compressed air for cleaning computers and clean out the laptop (do not stick the nozzle inside and make sure the unit is off first) overheating can also cause a very similar problem.
If you get los of dust and gunk out of here consider a laptop coolong pad with preferably 3 fans
If you fund this information useful please click
Posted on Aug 17, 2009
Testimonial: "Thanks! I will look into that."
  • 71 Answers
SOURCE: i installed windows 7 to my dell latitude d430
you need to see if there are drivers for your cdr drive for windows 7 you have to know what cd drive you have befor you install win 7.
Posted on Feb 01, 2010
allanhunt
  • 135 Answers
SOURCE: Restore Factory Settings on Dell Latitude D620 (refurbished)
Restart your system. As soon as the computer reboots and when you see the blue line on top of the screen with a label www.dell.com that the time that you have to hit ctrl+F11. Once Dell PC Restore appears click on the restore button.
Best of Luck
Posted on May 30, 2010
Carl Zuzart
SOURCE: i have dell laptop latitude c400. Ican't reinstall
This laptop will not give you an option to boot from a usb device or even from an external cd rom/dvd. You need to do a network install only for this particular model DEll c400. It is a long process and requires some skill of setting up a RIS server. You will also need a switch or hub to connect your laptop to it. Once your server is setup with dns, dhcp and ris you need to do a network boot and install the os. Get in touch with a professional to do it if your not familiar with this. I tried calling dell as i had a similar issue and they couldnt help me over the phone so they sent over a technician. Technician tried in vbain including removing my hdd and installing the os on his laptop and then putting the hard drive back into mine. It still didnt work. I then researched the net and figured out the only way to do it was via a remote installation.
Posted on Jul 02, 2010
Install Windows XP on Dell latitude L400
but you have to have 256mb of ram (memory)
Feb 06, 2014 | Dell Latitude L400 Notebook
Install windows xp
As it only has 128M of RAM, Win7 needs 2Gb so no. XP needs 256M of RAM or the program will struggle.
I have A dell latitude C510 on windows 2000 how do I turn it into A xp... I have A xp home upgrade cd
ok...u turn on ur pc and log on then insert ur upgrade cd.
the auto run turns on and u click install windows and then select upgrade option and follow the wizard
Jun 25, 2010 | Dell Latitude C510 Notebook
Slow laptop, canot upgrade
It cannot be upgraded farther by hardware. You should be able to run xp there. Any lower requirement linux distro is also fine if you like.
Laptops are now-a-days not too costly. May also think about a new one.
May 21, 2009 | Dell Latitude L400 Notebook
Install o/s on dell l400
Firstly, put cd on the dvd rom drive. Boot up machine and press directly F12, it wil give you an option whether to boot up machine. Choose boot up my cd drive then it will read your cd and install the OS.
May 17, 2009 | Dell Latitude L400 Notebook
Dell l400 problem
1.If you purchase an external USB CD drive you will not need to use your floppy discs for booting. 2. You can connect a USB CD drive to your system. 3. Your system will recognize any device plugged into your USB drive. 4. There is no CD drive available for internal installation in your computer. 5. With the USB CD drive plugged in and the windows installation disc inserted, your computer should take you through the setup program automatically.
Nov 10, 2008 | Dell Latitude L400 (220-3575) PC Notebook
No booting dell l400
you can go 2 a internet caffe and burn whats in the usb 2 disk
Aug 17, 2007 | Dell Latitude L400 (220-3575) PC Notebook
Dell Latitude L400 Notebook Logo
24 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
