Bush bu102zrh50 no longer records
This device has stopped allowing me to record new programmes. it still records programmes that were set on series before I started encountering these problems. I am using the remote that came with recorder
vcrdr1
  • 53 Answers
SOURCE: JVC vcr code needed to control speed of recording when OTR
no available codes. use the vcr plus function.
Posted on Jun 15, 2006
sonysonyman
  • 68 Answers
SOURCE: Canon ZR300 record button no longer works
hi sir just two things to do first 1- restore to factory setings from the menu and check if it is solved 2- if not just try to see does the knub is in its reguler state if yes so you need to replace it
Posted on May 08, 2007
  • 6 Answers
SOURCE: remote no longer controlls recorder
Remote can be used to control more than 1 recorder, on the remote press enter and 1 simultaneously, this should switch the remote to control dvd 1.
Posted on Oct 27, 2007
bestdarngood
  • 3037 Answers
SOURCE: Sony Remote - Acer LCD TV
Here is a list of codes for sony products
Posted on Mar 25, 2008
SOURCE: bush tv remote code
try 0065 or 0443
Posted on Oct 12, 2008
When I record programme from the tv it always cuts of at least one or two minutes before the end of the programme is there any way to fix this
Try setting the time of your DVR to be precise. If the recording starts 2 minutes before the show starts it will cut off 2 minutes before the show ends! My DVR has functions that allow me to add a minute or two before or after the times set to record, but that can cause other problems like if you are recording 2 shows and you try to record a new show after a show that was being recorded, it won't allow you to, because it can only record 2 shows at a time! Best bet is tro synchronize your watch to the Internet time and use that to sync your DVR time.
Dec 03, 2015 | Televison & Video
LG HDD RECORDING WONT STOP
Did you try to contact LG support?
Nov 19, 2015 | LG RH1999H DVD Recorder/HDD Recorder
Hi i have lost my manual for my urc 3940 one for all remote and i am looking the codes for a bush tv and a bush dvd player and a bush bu102zrh50 freeview recorder box pls if any1 can help, thanx
If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls.Common set-up codes to check with TVs and other devices are given, in the order of the "device's brand name" in alphabetical order.Pull up older posts. Surf the site with patience. Surf the sites by type in the brand name to your set, in its search box.
http://remotesearch.blogspot.com/
http://electro-medical.blogspot.com/
http://electrohelponline.blogspot.com/
Type in the brand name of your device, in the search box [at the top right] of the display window and the Search will start at once as you type in, and will show you all the related posts.It will make surf easy.
Mar 01, 2015 | One For All Televison & Video
Why I can't get my machine to record more than one programme, i.e. it will not record a series of programmes?
In the Recording menu of the Humax PVR-9300T (or (9200T), if the start or end times are set to anything other than "On Time", series recording is disabled.
Jan 07, 2015 | Televison & Video
Bush freeview recorder bu102zrh50 factory reset ive forgot my parental pin no its not 0000
Well according to the manual here
http://www.bushaustralia.com.au/wp-content/uploads/2014/03/BVR501FV.pdf
it should an option in settings called factory reset. You will LOOSE all your settings if you do that though.
Dec 02, 2014 | Bush Televison & Video
Why is it not recording when on standby
To select a programme to record, press the OK button, it will then give you options such as HD or SD, One-off or Series.
Aug 28, 2014 | Televison & Video
How do i stop my recorder informing me that it has found new programmes
Dear friend ,you mean if there is something wrong with your recoder or other things ,if you can't stop your recorder ,you can check if the on and open botton is wrong .
Mar 20, 2013 | Panasonic DMR-ES40V DVD-Video Recorder
Grundig GUFSDTR500HD FreeSat PVR Problem
Hi There, I've never had this problem with my Sky box, it knows which programs are repeats. I suspect its a problem with the GUFSDTR500HD. I have had two of these boxes from Costco, and both have both been as buggy as hell. They have recorded random programmes, they have missed recording programs, they often crash (black screen), series link seems to get it's knickers in a twist, and the up and down directional buttons fail to work after coming out of the guide or menu screen. To top it off, I found that the remote control also interferres with my B&Q fireplace... cycling through the colours when I change channel. Both of these boxes have gone back to Costco and I will never touch another Harvard Group (previously Alba, including Bush/Goodmans/Grundig) box again. Back to sky HD for me!
Feb 24, 2010 | Televison & Video
Stop Substitles on a LG RHT497H 160G dvd recorder?
I have the LG DVD recorder DRT389H which has the same problem. You can't switch off the subtitles during timer recording from the Electronic Programme Guide. The only way I could stop this was to go to the main set-up menu then select the A icon. Select DTV Subtitle and choose a language that the TV programme isn't broadcast in. I chose Gaelic. The only disadvantage is that this stops any subtitles being recorded so you can't access them later.
Dec 26, 2009 | LG RH177 DVD Recorder/HDD Recorder
Televison & Video Logo
41 people viewed this question
Top Televison & Video Experts
Electro Med Services...
