Question about Sony STR-DG800 Receiver
Sony Str-KG700 dead, no power
Won't turn on
5 Suggested Answers
rogrrabbit
  • 986 Answers
SOURCE: I HAVE A SONY STR-KG700 5.1 SISTEM, AND SOON I`LL
I would just buy a transformer for the unit 220 to 120. That way when you move back your good to go.
Posted on Jun 14, 2009
  • 49 Answers
SOURCE: can't get surround sound when watching tv
just dont put the jacks in from the tv plug satelite jacks in (use optic cable) dvd use orange digital cable and so on if u do it this way and have the same issues then i would 100% say its a reviever issue
(hope u kept the recipt)
Posted on Sep 27, 2009
  • 11800 Answers
SOURCE: Unit won't turn on.
Failure of the the power source. To see if it's fixable the receiver will have to be opened and the power board tested . This job requires at least a basic experience in electronics - if you don't posses it all you can do is to look for a burned fuse or damaged capacitors. For them follow this
http://www.youtube.com/watch?v=YCSNWi3UHf4
Posted on Sep 05, 2011
dunnbiker
  • 8546 Answers
SOURCE: I have a Sony STR-DE435 that won't turn on
Generally speaking, an amp attempts to protect itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'nekkid'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Check for loose speaker connections at the speaker as another possible root cause for intermittent shutdown.
Posted on Sep 08, 2011
Why is center channel dead?
Sony STR-K840P Sound center speaker - Questions - Fixya
www.fixya.com > ... > Sony > Sony STR-K840P
... sound from center channel during viewing, or during speaker level test- all other speakers emit tone, but center is dead. I have optical digital cable and hdmi ...
Sony STR-K840P Sound center channel - Questions - Fixya
Sony STR-DB940 pulled back from the brink - Page 2 - Badcaps ...
www.badcaps.net > ... > Audio Equipment Discussion
Jan 01, 2016 | Sony STR-K840P
Need a schematic diagram for Sony STR-KG700
str z 2062 checking multimeter method
Dec 23, 2013 | Radio Communications
I've got a Sony STR-K880 Cinema surround system and the remote control won't work it anymore! The only thing it will do is turn the system off when I push the'AV I-O' button and the &#
I had the same problem. Found the fix in this document
STR-K880 service manual
On the amp, while powered off:
"While depressing the INPUT MODE button, press the POWER button to turn on the main power."
You may need to do this more than once.
This switches command mode between AV1 and AV2.
Jul 08, 2012 | Sony Audio Players & Recorders
Sony 2185 mt dead
is k digram nhi hai sony 2165m
Dec 30, 2011 | Televison & Video
Unit won't turn on. There's power to the outlet but the reciever just won't light up! Sony STR-DE 197 It's only a couple of years old and shows no damage.
Sep 05, 2011 | Sony STR-DE197 Receiver
PROTECT shows every time I turn my reciever on. It's a SONY model #STR-DE335
Turn it OFF. Look for shorted speaker wires or shorted speakers.
None found? Disconnect all speaker wires and try to turn it on.
Turns on ok? One of the speakers/cable pairs is shorted. Check them again.
No good? It's dead. take it to a tech.
http://www.retrevo.com/support/Sony-STR-DE335-Receivers-manual/id/387bh942/t/2/
Jan 08, 2011 | Sony STR-DE335 Receiver
No Display, no sound- not working, showing dead. But input Power is ok. Picture tube filamment not getting power. model sony KV-2192M3
Hello
Check the input fuse first. If it is blown, there will be some short inside the power regulator circuit. Usually Sony sets uses STR regulated power supply. You can see this STR, and Ic, screwed onto a heatsink. Replace it with a same type and number. Before replacing the STR, check the diodes used in that section for damage, mainlu zener diodes. They might get shorted along the blowing of the STR. Check that section throughly before resoldering the new STR.
If any further assistance you needs, get me through Fixya. Ok.
Nov 27, 2010 | Sony FD Trinitron WEGA KV-21CL10 21" TV
Can't get surround sound when watching tv
your RCA on your tv is acting like its in mono..it may be a problem with the jacks.  alternatively..you can buy a splitter and split teh side that sounds stronger (L) or (R) with a male to 2 female spliter out of the tv then back into l/r input on your reciever... It wont give you surround stereo...but it will soudn a whole lot better.
Nov 08, 2008 | Sony STR-DG800 Receiver
Automatic Power Up and Power Down
Its your Micro prosseser and the gost of your last dead dog...lol
Jun 24, 2008 | Sony STR-DE597 Receiver
Sony STR-DG800 Receiver Logo
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
