Question about HP ProLiant ML110 Server
Server asset text
Boot fail
3 Suggested Answers
  • 10406 Answers
SOURCE: Hi, I have a problem
The value does not matter, unless the server is part of a large "monitored" network that is centrally-managed. If this is the case, then ask the centrally-located system-administrator what the value previously was, the last time that the server was monitored. Re-enter that value.
Posted on Jul 13, 2011
nobody322
  • 20706 Answers
ever heard of HP.com
go there,
and find your G6
and read the 25 manuals there.
hyghjacker. above.
State Verginel wants more answers to this question
Posted on Mar 27, 2017
How to flash the tag on poweredge
Look for a command line app called ASSET com and boot into. Just enter original name.
Dec 23, 2012 | Dell PowerEdge R410 Server (bectn5y
ML3670 does not boot as it does not found an boot disk
Replace HDD (Red Flashing ).It seems you have unknowingly disturbed your Raid . If Possible take backup of your server.Reconfigure RAID and Freshly Install OS .
Apr 04, 2012 | HP ProLiant ML370 G4 Server
Server asset test failure messsage when start up
Enter into BIOS
enter server serial no. in Asset TAG .Save it
Restart server.
That's it.
Jul 15, 2011 | HP Compaq ProLiant ML110 G4 Server
Hi, I have a problem with HP server ProLiant ML110 G6. In Bios, I deleted value in line Set Server Asset Text. Help me restore it!
You can put anything you like into that field. It wont affect the server operation. The asset text is only for network management purposes, to assist in identifying the server from a remote location.
Jul 13, 2011 | HP ProLiant ML110 Server
Question: I have one server for IBM X3400. this con't booting that problem was Fatal error: controller monitor failed conterollre not started . .
I have one server for IBM X3400. this can't booting that problem was controller monitor failed controller not started
Dec 15, 2010 | IBM x3400 Server
Hp proliant server dl380 g3. gettting PXE-E61:Media test failure, check cable how to fix it..
Your server tries to "boot" from several sources:
* floppy-disk
* CD/DVD
* disk-drive
* network (if you have a "boot-server" somewhere on your network)
So, if your computer FAILS to boot from the first 3 devices, above, it will try the 4th, namely via your network-adapter.
When your computer finds that its network-adapter is *NOT* connected via an Ethernet cable to a boot-server, it reports "check cable" and "test of the media has failed".
So, why did your server *NOT* boot from the 3rd device, namely your disk-drive? Solve that problem, and the 4th device (the "network-boot") will not be tried, and the error-messages will not appear.
Aug 27, 2010 | Computers & Internet
We connecting an external hdd, the sytem fails to boot up
when booting up keep tapping Delete or F2 it varies on different computers but it will say on the screen what button it is the enter the Bios settings or boot menu, if these ones dont work.
This should take you the the BIOS which most of the time is a blue screen with text on it and different option across the top.
Go to the section which indicates the Boot order. Follow the insturctions to change the order, you want your computer harddrive at the top and others like the CD drive and USB drive below it.
Hope this helps if you need any more info just ask.
Please Rate!
Nov 26, 2009 | IBM x3400 Server
02A2: BMC System Event Log(SEL) Full
In HP prolliant server sets, setup also logs system events. This error is due to that log. Enter setup, trace log and clear all events.
Jan 28, 2009 | HP Compaq ProLiant ML110 G4 Server
Hello, I have 2 Operating Systems in a computer namely Windows XP(SP3) in C:\ & Windows Server 2003 in D:\ . I've deleted the file BOOT.INI accidentaly form X:\ drive(X:\ means all drives like...
That's not a virus. Boot.ini is a default file needed for Windows OS to boot.
Fortunately, you can recreate the boot.ini files
This is a sample of the above Boot.ini file with a previous installation of Windows 2000 on a separate partition. [boot loader]
timeout=30
default=multi(0)disk(0)rdisk(0)partition(1)\WINDOWS
[operating systems]
multi(0)disk(0)rdisk(0)partition(1)\WINDOWS="Windows XP Professional" /fastdetect
multi(0)disk(0)rdisk(0)partition(2)\WINNT="Windows 2000 Professional" /fastdetect
Simple way to add operating system on a separate partition:
At the command prompt, type: bootcfg /copy /d Operating System Description /ID# Where Operating System Description is a text description (e.g. Windows XP Home Edition), and where # specifies the boot entry ID in the operating systems section of the BOOT.INI file from which the copy has to be made.
Dec 28, 2008 | Microsoft Windows XP Professional
HP ProLiant ML110 Server Logo
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
