Question about Singer 1507 Sewing Machine
Singer 1507 handwheel jammed
Handwheel jammed. I would bobin for first time and went to thread machine and the handwheel doesnt turn. Machine never used
SOURCE: I can't find my manual and cn not get the bobbin to thread correctly
you need to insert the bobbin so that when the thread pulls off it spins counter clockwise. on the side closest to you there is a notch that you slip the thread into and then pull along the side towards the back of the machine staying on the left. once you've done that you can manually turn the knob on the side to make the needle cycle down so that the upper thread will pull up the bobbin thread.
Posted on Jan 23, 2008
SOURCE: singer simple sewing machine will not sew
need needle threading instructions singer 3116 simple. pictures would help. thank you
Posted on Mar 15, 2009
  • 18 Answers
SOURCE: Rotating Hook won't fully turn-Singer 2210
The nylon gear driving the hook has probably broken a tooth. Replacements are available if you search the web.
Make sure you get the matched set of driving gear and driven gear.
Posted on Oct 05, 2009
  • 980 Answers
SOURCE: My Singer 507 sewing machine keeps on jamming up,
If you have the 507 with the grey or black plastic bobbin case you may need to undo the two screws on the right hand side on the silver bit and push it over to the bobbin case so it is tight or enough gap between the bobbin case and the silver bit about a thread width.
Posted on Apr 09, 2010
  • 139 Answers
SOURCE: How to thread the Singer Sewing Machine Ser NO 1507 ZHV 826606183
You can find Singer threading diagrams at http://www.singerco.com/resources/threading.html.
Posted on Apr 16, 2010
Machine hand wheel will not move.
sounds like it jumped time . take it to a repair shop .
Dec 03, 2016 | Singer Sewing Machines
New Singer 1507- handwheel is stuck.
The bobbin might have a bunch of thread off it inside the compartment here the bobbin is. Also, make sure it's thread correctly, that can goof things up to.
Jun 15, 2017 | Singer 1507
New Singer 1507 user - cotton jamming everytime
try this link for a free manual just in case you don't have one
http://www.singerco.com/uploads/download/36952a1312a6d8436174ef874f3662471a946b64.pdf
if the fabric is real light weight you may have to use a stablizer
also check to make sure the needle is the right one for the fabric being sewed..
make sure the bobbin is turned the correct direction, try putting the bobbin in the opposite direction..
if the machine keeps jamming, take it back up where you bought it and show them what it's doing and see if they can help you..
Jun 20, 2013 | Singer 1507
1507 singer wont stitch
it would be a good idea to change the needle
rethread the machine using every thread guide
make sure the bobbin is turned the correct way in the bobbin case
and that the bobbin case is correctly inserted into the machine
it's also possible that the machine could have jumped time and
needs to be checked at a sewing machine shop.
Apr 16, 2013 | Singer 1507
My turning wheel to manually move the needle out of fabric is jammed. Should I check the bobin compartment for jammed threads.
Yes, by all means, always turn your handwheel towards you never away from you because you can mess up your timing.
Sep 12, 2010 | Euro-Pro Fast and Easy 420 Mechanical...
My Singer 507 sewing machine keeps on jamming up, the thread gets wound around the bobin and jams. I have thread the machine as in the manual. PLEASE, PLEASE could you help.
Apr 05, 2010 | Singer 5070 Mechanical Sewing Machine
When i use my singer 1507 sewing machine i thread the bobin and thread the rest the when i try to pull the bobbin thread up it doesn't work after i spin the hand wheel. then somtimes it does and while i...
"Birdnesting" occurs when there is no tension on the needle thread to pull the bobbin thread. This is easily corrected by rethreading the machine, following the threading path carefully and making sure the thread is fully engaged in the tension mechanism.
Mar 22, 2009 | Singer 1507
Singer 3116 Bobbin
Slowly turn the handwheel towards you, as you hold the top thread and watch it hook the bobbin thread. Also, make sure that your needle is fresh and inserted right (flat side facing away from you). Watch your dvd and read your manual. Never turn the handwheel away from you as you will mess up the timing sooner or later. You can call Singer at 1-800-4singer if you have more trouble.
Mar 09, 2009 | Singer 3116 Simple
Singer 1507 Sewing Machine Logo
19 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
