Question about Minolta bizhub 200 Copier
Touch screen on minolta bizhub 200 not working all the time
Touch screen not functioning properly key pad works fine touch screen is sporadic at best wont allow access to basic menu selections paper pref. etc
  • Minolta Master
  • 6,161 Answers
Need a new touch screen.One other option. Push utility/counter meter count then press stop 00 stop 02. Places machine in maintenance mode. Then press the utiltiy/counter will see maintenance mode press that find touch screen adjustment. follow the screenthen press start. T clear maintenamce mode and flashing start button. Power off machine main power left side of the machine to the rear.
Posted on Jul 04, 2014
5 Suggested Answers
  • 26 Answers
SOURCE: Driver utility of Konika Minolta Bizhub 162
Use the bizhub 180 same family
driver
Posted on Feb 21, 2009
Cogz
  • 1326 Answers
SOURCE: Touch pad very pale
When you say it is pale.... Do you mean you can not read it? There is a display adjustment on the control pannel. If you have adjusted it to the max, you most likely have a blown back light Lamp.
Posted on Apr 17, 2009
xeerie
  • 347 Answers
SOURCE: Put in new toner into KonicaMinoltaBizhub200,says exchange toner
Machine is still saying to exchange toner because toner is not feeding into the machine. to supply the toner always do this, 1-insert the new toner bottle in the toner section and close the cover. 2-Press "Utility/Counter" Button. 3-click on "USER CHOICE" or "USER SETTING" 4-click on "Toner Supply" 5-Toner bottle will start moving and hence the error message will not appear again.
Posted on Jul 06, 2010
wheatlandsvc
  • 1110 Answers
SOURCE: how to fix error c-1183
This code is for a bin/tray raising or lowering failure in the finisher. This can be caused by either the trays not being fully inserted into the finisher or something stropped the bins from raising or lowering. Check the trays and make sure they are as close to the finisher/fully installed as possible. Then turn off then back on the main power switch (NOT the stand by one on the control panel)
You should see the bins raising and lowering into their home position.
Posted on Aug 03, 2010
How do I recalibrate the screen on a Bizhub 250?
Remove the Compact Flash Cover. Located Right side next to where the network cable is installed. Remove the cover, using a small screw driver or small plastic stick depress black button gently. Called the Warm Restart switch.
When "." appears at the center on the left-hand side of the screen, enter "3" from the via 10-Key Pad. Enter the 8-digit service code and touch [END]. (Default value: 00000000) if required.
Touch [Touch Panel Adjustment] from the Initial mode screen.
Following the arrow mark, touch the four points (+) sequentially on the screen using a pen. DO NOT USE A SHARPE POINT!!!!!.
Jun 21, 2016 | Konica Minolta bizhub 250 All-In-One Laser...
C550 cooling fan not functioning, what can i do to make work?
Konica Minolta bizhub cooling fan not working Questions ...
www.fixya.com/tags/cooling_fan_not_working/printers/konica.../bizhub
Konica Minolta bizhub printers & copiers cooling fan not working related questions and answers. Ask your Konica ... Question about Bizhub C550. 1 Answer ...
Konica Minolta Bizhub C550 Cooling fan power - Questions ...
www.fixya.com > ... > bizhub > Konica Minolta Bizhub C550
konica minolta bizhub c252 error c-5351 C - 5351 Is power cooling fan problem.Verify the cooling fan connectors and clean.For reset open/close the front door.
cooling fan not operating properly - HP Support Forum
Nov 29, 2015 | Cars & Trucks
Konica minolta 350 touch screen stopped working
Similar problem with a Canon MG6320 has been solved .There is an updated firmware for this printer that fixest his issue. Download and run it on your computer that is connected via a USB cord directly to the printer.
Jun 16, 2014 | Konica Minolta bizhub 350 All-In-One Laser...
Touch screen not working
Try this first if it does not work you need a new screen/control panel.
1,. Take a paper clip with machine on and stick it in the tiny hole on the right side of the control panel the screen will change when you see the screen with copiers and computer look under the computer on left side of the screen see a small dot. when it shows press the "3" key go touch panel adjust follow the screen see if that reset the screen if not need a new one.
Feb 07, 2014 | Minolta bizhub 200 Copier
Konica Bizhub 200 touch screen doesn't get past the Konica logo screen.
power off the machine and take toner bottle out. Then turn the machine without the toner bottle. let it run it should ask for the toner bottle to be replaced. Please wait is the machine is conducting house chores prior to READY TO COPY. one is to ensure toner in the developer unit is properly mixed. Also might check. Power on the machine while depressing the utiltiy/counter button hold down until you see trouble reset touch ok power off then wait 10 seconds and power on. if neither works get a tech out to look at iti
Mar 30, 2017 | Konica Minolta bizhub 200 Printer
Bizhub 200 touch screen is not working correctly
Utility/Counter Details Stop00 Stop02 Maintenance Mode then touch screen adjust does not work get a new control panel try web site below Precision Roller Printer Toner Cartridges Parts and Supplies Office...
Mar 12, 2012 | Minolta bizhub 200 All-In-One Printer
Hi, We have a Bizhub 200 Model number FK-503 in our office. We are unable to find the user manual or guide. We would like to be able to delete a one-touch dial recipient and add a new one-touch dial...
Your machine is a Konica Minolta Bizhub 200. The FK-503 is just the designation for the Fax Kit. FK = Fax Kit, so just ignore that part.
You can download the user manuals here:
http://kmbs.konicaminolta.us/content/support/supportmanuals.html
Set Category to Office Systems
Model to Bizhub 200
then click on user guides, there are 12 available.
Good Luck and Thank You for using Fixya.
Jul 20, 2010 | Konica Minolta bizhub 200 Printer
Minolta bizhub 200 Copier Logo
205 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
CheckitRight
CheckitRight
David Burkhart
David Burkhart
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
