Question about Refrigerators
Ice maker won't work and flashing light on left side of panel
  • 236 Answers
SOURCE: ice maker
poss a problem with a blocked filter?
Posted on Jan 20, 2008
Sea Breeze
  • 4654 Answers
SOURCE: Whirlpool Gold Ice maker doesn't work
You definitely have something wrong with the ice maker if the water has turned to ice Schmerold. And the IM is not harvesting. The way it works is the IM needs 28 degrees F to harvest. If the coils below in the condenser are dirty the IM won't try to harvest. The Ice Mold thermostat is mounted on the firewall of the Ice mold in its own little cubby whole. To access it you will need to remove the head. Then remove the shell separating the Ice mold from the heads housing. There you will find the ice mold thermostat. It's only function is to get it on. If the temperature is right in the freezer. To test this precious thermostat one needs only to stick it into a freezer and let it hang out for an hour or so. Then grab it and check it for continuity. If it is open it has failed and belongs in the file 13. It is easily replaced and inexpensive.
On your model, ice maker operation is controlled by an optical sensor mounted on both sides of the freezer liner. The usual failure of this model is a bad emitter board, located in one of these recesses. You may view the service instructions for checking this sensor.
Visit my site, I offer free help and model and parts number search feature. Movies and instruction manuals for most brands. seanreezehvac@yahoo.com click on link below, Thanks, Sea Breeze
I will also send free manual for you through email. And Rate my assistance.
http://servicepartstec.blogspot.com/
Posted on Apr 04, 2009
  • 531 Answers
SOURCE: My Kitchenaid side-by-side KSR125F isn't making ice
1 check frost build up in freezer 2 water valve or icemaker
Posted on Apr 07, 2009
  • 10865 Answers
SOURCE: Ice maker not working
If your ice maker has stopped producing ice completely, check these, in this order:
  • It may be turned off. Look for the wire along the right side of the ice maker that looks a bit like a coat hanger. If the wire is in the raised position, the ice maker is turned off. If so, try one of these:
    • If your ice maker has a small red plastic lever, lower it to lower the wire.
    • If there's no plastic lever, simply lower the wire.
    In either case, the ice maker should begin producing ice again. Also make sure that the temperature is 8 degrees Fahrenheit or lower. If the freezer is too warm, the ice maker won't cycle properly.
  • The ice maker fill tube may be blocked with ice. If so, melt the blockage using a hair dryer-but be careful to not melt any plastic parts! Also replace the water shut-off valve or water-inlet valve, or both, if necessary.
  • The ice maker head assembly may have broken parts. Look to see if the gears are broken. Check to see if the small plastic arms that rest against the ice rake are broken. If the ice maker head assembly is modular and you've found broken parts, you can just replace it.
Posted on May 30, 2009
heatman101
  • 43501 Answers
SOURCE: seee note on ice maker stopped working, blinking red light
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
rtwywy
Posted on Sep 30, 2010
Samsung refrig, side by side, won't eject ice. How do I turn off the left hand light to quit ice?
How to Repair a Refrigerator Ice Maker ' HomeTips
www.hometips.com/repair-fix/freezer-ice-maker.html
If your ice maker doesn't make ice, check out these expert do-it-yourself ice maker repair ... W. Branner Side by side GE fridge, stopped dispensing ice both cubed and crushed. ... But now that it's cleared the motor won't run to dispense any ice (water .... Our Samsung French door ice maker is not working & is making noise.
Jan 01, 2016 | Samsung Refrigerators
Panel board keeps flashing
I have a Samsung rf26xaewp side by side fridge that was built in 11/2009. On the front of ice maker the setting on the left is flashing 88. The setting on the right is bouncing between 88 an 89. I cleaned the back an looked at computer board, there is a red light on. Fridge feels like its thawing. Only thing ice maker will do is expense ice.
Sep 28, 2014 | Samsung Refrigerators
BROKEN INFRARED ICE CONTROL - ON WHIRLPOOL SIDE BY SIDE. CAN I REPLACE THAT PART?
The part you need to replace is 4389102 this comes with both boards and replace them as a pair. I have a question though, is the harvest fingers in the ice maker at position like a clock? Also to confirm the flashing of the light when the flap is depressed it 2 flashes and a pause? Not 1 flash and a pause, this means unit is harvesting and the ice maker should be moving and if not the ice maker could have a broken gear. This control unit could run you about 100 buck so make sure this is what you need before your purchase. Good Luck
Jul 28, 2014 | Whirlpool Refrigerators
The ice maker has stopped working , a red light is flashing.
according to the led flash cycle, you can figure this out. if you open the freezer door and the light flashes two times, that is normal. if you close the flapper on the left side of the freezer, the light should remain lit, and that means that the optic system is functioning correctly. there is a diagram behind the vent panel on the bottom front of the fridge.
Nov 20, 2010 | KitchenAid Superba Architect KSCS25INSS...
Icemaker not working- red light flashes constantly
The red light should flash twice , pause then flash twice constantly . If you close the flap on the left side , then the light should go off . This shows the optics (ice maker cut off ) are good .
Check the black tube ( fill tube ) , which puts water into the ice maker , to see if it is iced inside . If so , then the water valve behind the refrig is bad . It seeps into the tube and freezes , blocking the water flow .
Pour about 2/3 cup of water into the ice maker . If it freezes and dumps , then the water valve needs replaced . If it doesn't dump , and stays frozen in the ice maker , replace the ice maker . Also , make sure the coils under the front of the refrig are clean , as this will cause warmer temp in the freezer and the ice maker needs 5 degrees to operate .
Sep 27, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool side by side Ice maker has quite making ice
Open the freezer door and on the right side , make dure the slide is in the on position . If the red light flashes twice , then pauses , flashes twice , pauses , consistently , then close the flap door on the left side of the freezer . The light should go off . If these tests work , then the cut-off optics are good , and the icemaker needs replaced , due to the cubes not dumping . Also check the coils under the front of the refrig , to make sure they are clean of dust , lint , etc.
Sep 15, 2009 | Whirlpool GS6NBEXR Side by Side...
May 30, 2009 | GE Profile PSW26P Stainless Steel Side by...
Ice maker quit working
good sign its flashing , woth door open depress the left side flap oppiste the blinkin light. does the light then go solid red??? i fso its an indication that the electricl eye is operating ok .
theres a screw 1/4 in. along the right side underneath the icemaker itself, youll need to removeit and the cover its holding down. you can then slide the ice maker assy foward and out of machine,There will be another litle tab along loeft side uder ice maker youll need to depress to ppulll unit out. pry off the white cover from front of the ice maker assy itself and have a look at the main gear 2 in. round, is it broken off, or on its way top breaking( sometimes the tabs that hold it on to the ice maker module itself break preventing operation, if this is the case youll need to repalce the ice maker assy.
Oct 31, 2008 | KitchenAid KSCS25IN Side by Side...
Ice maker not working flashing green
heatman101
dfdf
Jul 28, 2008 | GE PSS29NHP Side by Side Refrigerator
Refrigerators Logo
10 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
