Question about Brother HL 5150D Laser Printer
Brother laserjet printer HL 5150D
Dear Sir
We got a above said printer along with our instrument procured from UK.The printer does not work since the installation.The power on LED is on but there is no further action from printer.The printer holds following sr. no.E62353B4J228073.
Kindly let us know the solution and the nearest service centre.
With regards.
  • Brother Master
  • 990 Answers
Re: brother laserjet printer HL 5150D
Because this unit you bought from UK ,first step I would like you to do is make sure this unit what kind power curency they using ia 220V, or 110V.
Posted on Dec 10, 2008
0 characters
3 Points
Brother 5150d
1. Press the cover release button and open the front cover of the printer
(so you can see the toner cartridge)
2. Press and hold down the Go button until all 4 LEDs are lit. Once all 4
LEDs are lit, release the Go button.
3.Close the front cover.
4. Make sure that the Drum LED is now off
Mar 19, 2012 | Brother HL 5150D Laser Printer
Paper jam btother prinnter 5140
Hi justus1229,
Just click on this link and you'll have the step by step procedure on how you'll clear paper jam. This troubleshooting works for HL-5140, HL-5150D, HL-5170DN brother printers.
Hope it helps.
Thank you for using Fixya.
Apr 14, 2011 | Brother HL 5140 Laser Printer
Leakage onto paper so the one side of each page has black stain right along it.
Could be a leaking toner cartridge or the drum unit is contaminated and needs to be rebuild or replaced.
Feb 14, 2011 | Brother HL 5150D Laser Printer
My hl 5150D will not print. when isend document
1/ Check waste toner may need empty. 2/ You maybe out of toner. remove toner and give it a good shake will get a few more prints usually. Need more info from you. Have you check paper paths. Have you rebooted both printer and computer. Remember you must remove power supply on both for ten seconds for true reboot.. Good luck
Oct 10, 2009 | Brother HL 5150D Laser Printer
Can the Brothers HL 2040 handle printing 65lb
It probably can but only from the front slot, the paper tray has to bend the paper around the roller in the front when feeding.
Aug 28, 2009 | Brother HL-2040 Laser Printer
Brother HL 5150D printer has all lights flashing
switch off your printer. Remove power cable from printer. Open upper cover remove cartridge and then re-install. Wait for 5 minutes. Connect power cable again and restart your printer. It will work fine.
Jun 20, 2009 | Brother HL 5150D Laser Printer
New drum and the copies are extremly light
Drum may be defective must be repalced.
When replacing drum, be sure to reset the drum counter for HL 5150D:
-Open the toner compartment door, and hold the go button for 5 seconds.
Nov 30, 2008 | Brother HL 5150D Laser Printer
Need software to install printer to my computer.
Hello Summermay,
If you need drivers for a Brother Printer ( as listed in the Title block) use this website:
If it is for a different brand.. please provide the barnd and model number as the previous repsonder requestes..
Sep 28, 2008 | Brother Printers & Copiers
Brother HL 5150D Laser Printer Logo
87 people viewed this question
Top Brother Printers & Copiers Experts
Jim Yeh
Level 1 Expert
Jesus  Colon
Jesus Colon
Level 1 Expert
Rick Johnson
Rick Johnson
Are you a Brother Printer and Copier Expert? Answer questions, earn points and help others
